Go to Post They are "Human Dream and Inspiration Enablement Devices" but since that takes too long to say and explain I use the word "robot". - Foster [more]
Unread 13-03-2008, 23:00
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Re: Simple way to plug pressure lines?
Originally Posted by Travis Covington View Post
McMaster Part # 51055K429
Man, that sounds kinda familiar.
Originally Posted by jgannon View Post
McMaster part number 51055K429
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 13-03-2008, 23:11
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
Sorry dude... It was kinda buried in your post. No one else really took note of that either. By far the simplest solution mentioned.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 14-03-2008, 02:10
monty1540's Avatar
monty1540 monty1540 is offline
College Student Mentor
AKA: Eric
FRC #1540 (The Flaming Chickens)
monty1540 is an unknown quantity at this point
Send a message via Yahoo to monty1540
you said you're using festo valves? If my memory is correct, they have built-in push to connect fittings?
We have some plastic plugs from SMC that are designed to go into a push to connect port and plug it. They're basically a special plastic version of pneumatic tube - specifically; without the hole in the middle.
SMC Push To Connect Port Plug
[ .02 $ ] Fewer push-to-connect[ions] on the robot means less air leakage - they don't leak much, but they all do slowly leak. Connecting a hose, and then a cap, is two connections, versus a plug, which is only one. [ / .02 $ ]
-Eric
Current WPI Student and college mentor to 1540
1540:
2008 Portland Regional Winner
2008 Portland Regional Engineering Inspiration Award
2007 Pacific Northwest Regional Finalist
2007 Pacific Northwest Reigonal Chariman's Award
Unread 14-03-2008, 06:29
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Easiest way using the KoP
-Borna Emami
Team 0x27
Does the Norgren Pressure Regulator show working pressure or stored pressure? Madison Pneumatics 7 14-02-2008 17:40
battery plug itay_ms Electrical 3 03-02-2007 21:32
cruise lines robot180 Chit-Chat 9 29-06-2004 22:03
pic: Another one from way, WAY up CD47-Bot Extra Discussion 18 01-05-2004 02:31
Translating pressure sensor readout into actual pressure Mercutio Pneumatics 0 13-02-2004 16:29
