Go to Post FRC2010 - The flying purses :P - Bharat Nain [more]
Unread 14-03-2008, 14:08
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
Popsicle Stick Tower
So for my physics class we have to build a Popsicle stick tower 10 inches high that holds at least 10 pounds. Now we are trying to win teh contest and hold as much as possible. I know this is not remotely close to robotics but i know all of you might have some sweet ideas. Let me know!
Thanks
Matt Rybar
894
Unread 14-03-2008, 14:09
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Re: Popsicle Stick Tower
2 words: Think Pink.
GitHub
Unread 14-03-2008, 14:11
Racer26 Racer26 is offline
Is there a limitation on your tower's weight/popsicle stick count or similar that we should know about?
Unread 14-03-2008, 14:12
I had to think about that one for a bit--then I got it. That's actually the best advice for a strong tower.
Unread 14-03-2008, 14:13
I dont get it... but I have a feeling I know the team its referring to...
EDIT: Looking at 233's robot, I think I get it now.
Unread 14-03-2008, 14:15
IKE's Avatar
IKE IKE is offline
Not so Custom User Title
AKA: Isaac Rife
no team (N/A)
what are the rules? What are the dimensions of the posicle sticks.
Unread 14-03-2008, 14:18
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
well you can go about this 2 ways . . 1 make a brick of popsicle sticks 10 inches tall kinda in a flat pyramid shape . . yes I said brick, solid wood, that will 10 lb no prob. but if efficiency is part of it might I suggest you take the "you can use glue" rule to the extreme get your self some epoxy and put your sticks in a blender . . make kinda a fiberglass composite, then mold that in to the shape you want.
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 14-03-2008, 14:23
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
i don't know much about Popsicle stick towers but in grade 5 we split up into groups and had to make bridges out of just glue and straws so we made our stable bridge and it worked OK but we decided to cover it in glue and fill all the straws in glue
all the glue inside the straws and outside dried and hardened making the bridge really stable
we ended up winning the competition
so put a ton of glue on your tower!!!
I believe that would go against the spirit, and intent of the rules, regardless of whether or not it violates the letter of the rules.
Unread 14-03-2008, 14:25
Emily Horsman
actually we built the same one without glue and it won, but the teacher said the glue idea was really clever anyway
Unread 14-03-2008, 14:35
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
I don't know about 10lbs on popsicle sticks, but I can do 3/4 ton on note cards . If there is a limit on sticks may I suggest a really simple shape, tetrahedrons. they use fewer sticks than pyramids and about just as strong.
Unread 14-03-2008, 14:46
Emily Horsman
cool! picture?
Unread 14-03-2008, 15:54
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Originally Posted by basicxman View Post
cool! picture?
It took me a while to find but this structure held 256 bricks without buckling, we were stopped because of the height of the stack of bricks was around 8 ft.
http://img442.imageshack.us/img442/3622/img0759nc7.jpg
Unread 15-03-2008, 14:55
merybar's Avatar
AKA: Matt
Yep sorry i thought i included limitations. 60 popsicle sticks, elmers glue but NOT in excess and it can not be for structural integrity.
Unread 16-03-2008, 18:08
merybar's Avatar
AKA: Matt
Any ideas?
Icy Tower DanDon Chit-Chat 16 02-11-2006 14:05
[OCCRA]: tower dimensions mikaela50 OCCRA Q&A 1 26-09-2005 16:16
pic: Team 358 - Tower DarkJedi613 Robot Showcase 6 21-02-2005 19:40
pic: New Tower Iain McLeod Robot Showcase 1 12-02-2005 07:01
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
