Go to Post 2010 game piece--- participation medals - johnr [more]
  #46   Spotlight this post!
Unread 24-12-2007, 16:53
HighLife's Avatar
HighLife HighLife is offline
FRC #0245 (Adambots)
HighLife will become famous soon enough
Send a message via AIM to HighLife
Re: I want a version of the mplab compiler for Linux.
Originally Posted by whitetiger0990 View Post
Could that be the pathlength thing of mcc18? Make a drive letter point directly into your code (or put your code in /tmp for testing) and try it.
Nope that didn't work.
AdamBots.com- Winner of 7 Best Website Awards!
  #47   Spotlight this post!
Unread 24-12-2007, 17:37
Originally Posted by HighLife View Post
I'm getting this same exact error.
The error you are getting means the type of PIC hasn't been defined, so the ifi_utilities.c file can pick the proper system defines that match what the PIC has built into it.
Simply put, you are missing a compile flag (-D__18F8722).
  #48   Spotlight this post!
Unread 24-12-2007, 17:39
bagawk bagawk is offline
AKA: LeeP
FRC #0997 (Spartan Robotics)
bagawk is an unknown quantity at this point
Could you try the makefile that I wrote? I have been using it for almost 3 years now with no problems.
http://team997.org/files/software/Makefile
  #49   Spotlight this post!
Unread 24-12-2007, 18:15
HighLife's Avatar
Nvm guys I reinstalled mcc18 and everything worked! But thx for the help
  #50   Spotlight this post!
Unread 24-12-2007, 18:25
I must have missed something when I setup mcc18.
What version of mcc18 are you using? It looks like it might be the latest version 3.x when it should be v2.4.
  #51   Spotlight this post!
Unread 24-12-2007, 23:52
HighLife's Avatar
Umm not really sure it's an older version (At least 2004).
  #52   Spotlight this post!
Unread 15-03-2008, 09:22
sea_master's Avatar
sea_master sea_master is offline
AKA: the $@#$@#$@#$@#$@#$@# guy
FRC #1947 (the black knights)
Team Role: Driver
sea_master is on a distinguished road
Send a message via ICQ to sea_master Send a message via MSN to sea_master
Hi.
I'm trying to compile some new code on a Xubuntu Linux machine.
I've modified the relatively newer makefile in:
I've modified it according to my needs and it all seemed to work well,
until I tried to remove the intermediate files . when it tries to
complie the source files, it can't get the headers from the include
dir of mcc even tough the path seems right.
I've checked and the syntax used by the Makefile is /i <path> while
mmc18.exe expects -I="<path>".
I tried to change the makefile anyway I thought might work, but could
not get it to work, so I gave up and
I've made a script shell, and it works, but since I'm unfamiliar with
the tricks of Linux shell, it's butt ugly (with lot's of lines like
this: wine c:/mcc18/bin/mcc18.exe -p=18f8722 -I="c:\mcc18\h"
"ifi_frc.c" -fo="ifi_frc.o" -k -mL -Ou- -Ot- -Op- -Or--Od- -Opa-)
So please Chief Delphi! pimp my script!
phase 1: collect underpants
phase 2:???
phase 3: profit!
  #53   Spotlight this post!
Unread 16-03-2008, 22:54
HighLife's Avatar
You don't have to create your own makefile. You can just use this little python program that creates one for you based on the files in your code directory.
MPLAB C18 problem Justyn Programming 0 09-03-2005 11:37
IMPORTANT regarding the new C Compiler dlavery General Forum 12 14-01-2005 05:05
Makefile and stripped down compiler Venkatesh Programming 0 09-01-2005 18:55
MPLAB IDE 6.60 Error mchan1111 Programming 8 08-11-2004 20:17
using the MPLAB IDE MPLAB SIM simulator WizardOfAz Programming 1 03-11-2003 01:24
