Go to Post Blame it on the programmer. - colt527 [more]
Unread 14-03-2008, 11:01
qpang qpang is offline
qpang is an unknown quantity at this point
Question help --- drive other motors?
I'm able to drive my wheel motors using easy C Pro, the function block "Tank(), and it works fine. But when I try to use the same function to drive my other motors (used for the arm), it just doesn't work. Those motors for the arm are not the same model, but use the same voltage.
My question is whether there is a specific requirement (besides voltage) on the motors for the controller to be able to drive it?
Unread 15-03-2008, 15:31
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: help --- drive other motors?
I have not used Easy C, but here are my thoughts.
Are they connected to the correct PWMs?
Are supposed to be connected to Victors or Spikes?
Do you have the controller in the correct port on the OI?
Are they faulty wires you are using(bad PWM cable, shorted wire)?
Power connections are fully made and have contact?
Have a breaker and that it is not tripped?
Those are more of hardware issues and my thoughts. Hope it helps
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 15-03-2008, 21:50
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
The "Tank" function, in my opinion, sets up drivetrain PWMs only. It takes two axis on joysticks, and sets them pwms (1-4 prob).
You need to use something more like pwm_xx (where xx is arm PWM) = p3_y (or something)
I dont use easy-C though, so i may be wrong.
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 16-03-2008, 14:27
Kev Kev is offline
The Greatest
FRC #0614 (Nighthawks)
Kev is an unknown quantity at this point
Send a message via AIM to Kev
Tank() at my best guess would be something that controls a tank drive (and seeing as it's being passed no arguments, I don't know why you'd think it'd work for any and all PWM connections.)
since I have no idea where Tank() is called, make a new function called Arm() or something and have the pwmxx = p4_x or such.
Unread 16-03-2008, 20:55
Use "OI to PWM" to control a single motor.
Drive Motors Joe_Widen Motors 23 26-05-2006 01:00
Drive Dave's Other Car Like You Stole It.......... JohnBoucher Chit-Chat 7 26-05-2004 19:44
Drive motors archiver 2000 3 24-06-2002 00:25
Globe Motors & other FIRST Suppliers at Design Show archiver 1999 2 23-06-2002 22:07
