Go to Post If you want to win, steal from the best, invent the rest. - Michael Corsetto [more]
  #31   Spotlight this post!
Unread 11-03-2008, 20:09
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
Re: Most Exciting Final?
Johnathan, link please? Or are the matches being uploaded to TBA?
  #32   Spotlight this post!
Unread 11-03-2008, 21:38
GBilletdeaux930's Avatar
GBilletdeaux930 GBilletdeaux930 is offline
AKA: Greg
FRC #0930 (Mukwonago Bears)
GBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to allGBilletdeaux930 is a name known to all
wow...all i can say is wow. That third san diego final... Blue lap bot kept one of the two red hurdlers in that quadrant for about 1:07. During that time the other red hurdler only made 3 hurdles and the two blue hurdlers only made 3 hurdles also because one got stuck between the two stuck bots and the red lap bot, and the other looks like it got stuck on the bumps near the centerstructure...
wow
  #33   Spotlight this post!
Unread 11-03-2008, 22:57
Drwurm's Avatar
Drwurm Drwurm is offline
Electrical Alumni
AKA: Jason "Powercoach" Osmann
Drwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of lightDrwurm is a glorious beacon of light
Send a message via AIM to Drwurm
Basically what happened in FM3 of SD is 330 turned around and went back to obtain a trackball with their ball arms open. 294 was rounding the corner and the 2 robots plowed into each other. One of 330's highly powerful ball corralling arms got jammed into 294's lift system and they became entangled. Fortunately they were able to break apart near the end.
294 went on to keep 330 from getting a trackball to place and then got in front of 987, sent up their lift, to make sure they could not place.
Upon closer inspection after the match, it was discovered that we had actually sustained a bit of damage from the entanglement. The 3rd stage of our lift became dislodged and there were scrapes of yellow paint inside o_0. Luckily, this was repaired before recrating so 294 should be ready to swing when LA comes around. This time, we hope to prove the functionality of our lift hurdling during practice and qualifications so that we end up being seeded and not 47th. Also look for us to be testing out new autonomous.
We hope that 330 and 294 get to compete or even get to be allied together at LA. We also look forward to seeing our partners again: 1717 in LA and 968 in Atlanta.
Electrical Engineer (in training)
Also grows carnivorous plants.
BEACH CITIES ROBOTICS:
2007 FTC "Quad Quandary" World Champions
  #34   Spotlight this post!
Unread 11-03-2008, 23:57
mark johnson's Avatar
mark johnson mark johnson is offline
FRC #3175 (knight vision)
mark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud ofmark johnson has much to be proud of
HANDS DOWN SD WAS BY FAR WAS THE BEST FINALS THIS YEAR TO DATE. GREAT JOB TO ALL!!!!!!
K.I.S.S.
  #35   Spotlight this post!
Unread 12-03-2008, 00:39
Jonathan Norris Jonathan Norris is offline
Jno
FRC #0610 (Crescent Robotics)
Jonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond reputeJonathan Norris has a reputation beyond repute
check out this link for now: http://www.travisusd.k12.ca.us/vande...Ahomepage.html
click on video gallery and go down to 2008.
Co-Founder of Taplytics.com
2013 World Champions (1241, 1477, 610)
Crescent Robotics Team 610 Mentor
K-Botics Team 2809 Founding Mentor ('09-'11)
Queen's University Mechanical Engineering, Applied Science '11
Crescent Robotics Team 610 Alumni
  #36   Spotlight this post!
Unread 12-03-2008, 01:36
Aces's Avatar
Aces Aces is offline
President 2102
AKA: Asa
FRC #2102 (Team Paradox Robotics)
Aces has a spectacular aura aboutAces has a spectacular aura about
Send a message via AIM to Aces
I thought it was pretty incredible when our [2102's] motors on the inside our our left transmission came loose, and in 8 minutes we managed to take off the transmission, open it up, tighten the motors, put it all back together, and drive beautifully.
That was semi-final match 2; 2102, 1138, and 1572 VS. 968, 1717, and 294. We ended up losing that match, and the match after, but I think the crowd was very impressed seeing only us students working on our robot, and managing to fix it, and have it running for the next two matches.
____________
Asa
  #37   Spotlight this post!
Unread 15-03-2008, 19:27
rsilverstein's Avatar
rsilverstein rsilverstein is offline
Ross Silverstein
FRC #1717 (D'Penguineers)
rsilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant futurersilverstein has a brilliant future
Send a message via AIM to rsilverstein
Does Week 3 compare? I know the scores at SVR were close...
Team 1717
9x Regional Winner
2x Division Finalist
16x Engineering/Design Awards
www.dpengineering.org
  #38   Spotlight this post!
Unread 15-03-2008, 19:29
SVR compares. They were close... and reminiscent of L.A. finals 2006.
  #39   Spotlight this post!
Unread 15-03-2008, 19:37
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Close, yes. But the same caliber as SD? A quick look at the scores says no:
San Diego:
106 - 108
122 - 94
60 - 64
SVR:
76 - 34
30 - 36
66 - 58 (and this is one of great debate...)
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
  #40   Spotlight this post!
Unread 15-03-2008, 19:47
Ross Silverstein
Bitter about LA-2006? That was a really exciting regional final too
Team 1717
9x Regional Winner
  #41   Spotlight this post!
Unread 15-03-2008, 19:49
chaoticprout's Avatar
chaoticprout chaoticprout is offline
can't wait for next years VRC
AKA: Michael Montazeri
FRC #1138 (Eagle Engineering)
chaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant futurechaoticprout has a brilliant future
Send a message via AIM to chaoticprout Send a message via MSN to chaoticprout
I think he meant that a game that was scored incorrectly was called a tie and there was a rematch, which does make it reminiscent.
2009 Los Angeles Regional - Chairman's Award
2009 Granite State Regional - Engineering Inspiration Award
2007 Los Angeles Regional - Engineering Inspiration Award
2006 Southern California Regional - Regional Champions
  #42   Spotlight this post!
Unread 15-03-2008, 20:06
ZakuAce's Avatar
ZakuAce ZakuAce is offline
AKA: Garrett
FRC #2077 (Laser Robotics (Alumni))
ZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of lightZakuAce is a glorious beacon of light
Match 1 of the finals for Wisconsin was awesome, I was really cheering for 93 to win! Was extremely disappointed that King Tec's robot failed in the 3rd round, leaving 93 to do pretty much all the work.
  #43   Spotlight this post!
Unread 15-03-2008, 20:51
johnr johnr is offline
FRC #0910
johnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond reputejohnr has a reputation beyond repute
detroit regional-last match i think- team rush shoots over center wall and scores hurdle. only thing better would be if it won it for them.
  #44   Spotlight this post!
Unread 15-03-2008, 21:16
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Detroit had some pretty good finals.
RED:217, 440 ,469 vs.BLUE: 47, 27, 453 score= 98 for RED, 84 for BLUE
RED:440, 469, 217 vs.BLUE: 47, 453, 27 score= 124for RED, 106for BLUE
-Josh Murphy-
  #45   Spotlight this post!
Unread 15-03-2008, 22:22
bduddy bduddy is offline
FRC #0840 (ART)
bduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond reputebduddy has a reputation beyond repute
Whatever your opinion on SVR was, I think it has to be it. It literally came down to inches three times. The second game was decided by a penalty (not exactly desirable, but indicative of a close game), and in terms of the fourth game, even though the score wasn't -that- close (a whole 8 points!), 8 was literally less than a foot away from knocking off the red trackball and winning the game. Of course, the third game is a thing in itself, but this is not the topic for that discussion...
Does anyone else remember when TBA signatures actually worked?
Most Exciting Regional. Pavan Dave Regional Competitions 62 25-04-2007 00:00
What is your most loved and most hated video games of all time? Elgin Clock Chit-Chat 64 25-10-2004 09:41
What is your most loved and most hated video games of all time? Elgin Clock IT / Communications 8 14-07-2004 18:31
Exciting Meetings shyra1353 Team Organization 17 10-11-2003 22:37
Qotw [03-23-03]: Most exciting match you have seen Ken Leung Rumor Mill 22 21-05-2003 18:36
