Go to Post When we find bugs at work, we don't ask "who wrote that section of code?" We ask "Who is the best, most knowledgeable person to work on fixing this bug?" - Jon Stratis [more]
Unread 13-03-2008, 09:49
schmidtz schmidtz is offline
FRC #2518
schmidtz is an unknown quantity at this point
High Power Remote
I dont know if this has been posted yet....
Has anybody come across a high-power universal remote?
Do they make such a thing?
Our IR board is mounted under Lexan which significantly reduces our range. Rather than change the position, we figure it would be easier to make the remote super high powered.
I saw that harmony remote and on the website it said it had high powered infrared LEDs, but I dont know whether that was just a sales pitch or if it is serious. (but that remote is realllly expensive )
Unread 13-03-2008, 10:58
Steve W Steve W is offline
Grow Up? Why?
Steve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond reputeSteve W has a reputation beyond repute
Re: High Power Remote
Our team has been working on this issue and we have tried many remotes. I went to the school yesterday and it seems that they have designed a huge array. They are telling me that it works but until we go to competition we won't know as things are always different at the venues.
We do not stop playing because we grow old;
we grow old because we stop playing.
Unread 13-03-2008, 11:58
I have a harmony remote for my home (880), and I can't say anything about the power, but it does have a very wide view, just a little less then 180 degrees.
Unread 13-03-2008, 23:33
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
not commercially, but 599 has an array of 33 leds
We are just waiting to have a robot that wont keep having some sort of problem so that programming can get the program tweaked out.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 14-03-2008, 09:53
FRC #2518
Now is there any place where we could obtain schematics for a super awesome home-made remote? Possibly one we could tweak for high powerness?
Unread 15-03-2008, 15:43
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
see TSAL6100 on http://www.rentron.com/remote_control/IRLED.htm
(also available from www.digikey.com or .ca)
"....Radiant Intensity:
If = 100mA, Radiant Intensity = 40 min - 60 typ mW/sr
If = 1A, Radiant Intensity = 340 min - 500 typ mW/sr
Can handle a "Surge Forward Current" up to 1.5A.
TSAL6100 -- +/- 10 degree angle of half intensity
Use For "Long-Range" IR Applications..."
With new batteries, my basic sony remote went 60 feet. Unsoldered detector and installed TSAL6100 (no changes to resistor etc) and range was beyond 100ft (ran out of space to test further).
Was originally going to build one of the below items and put in multiple high power IRs but doesn't seem to be a need for it.
http://www.rentron.com/remote_control/TINY-IR2.htm
Your real issue is shielding the IR receiver from other remotes and directing it at the hybrid driver even when the robot turns.
Last edited by de_ : 15-03-2008 at 15:46. Reason: Forgot to mention IR available at www.digikey.com
Unread 16-03-2008, 10:33
spiffyspleen's Avatar
spiffyspleen spiffyspleen is offline
FRC #2635
spiffyspleen will become famous soon enoughspiffyspleen will become famous soon enough
Our team was having problems with ours. It would only go a few feet in hhybrid mode. Then we put aluminum foil around the reciever. It worked very well after that and we were able to go 3/4 of the way around before losing control.
Unread 16-03-2008, 10:40
Jazonk's Avatar
Jazonk Jazonk is offline
It's all a balancing act.
AKA: Dino
FRC #0027 (Team RUSH)
Team Role: Driver
Jazonk will become famous soon enough
Send a message via MSN to Jazonk
we built a super high powered remote. ew just ran wires out of the actual remote from where the signal pulses are sent and put them in an array of six LED transmitters. In testing we got it to go over 150 feet (the hallway was not long enough!).
Unread 16-03-2008, 11:00
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
we took a standard remote and soldered 4 more high powered LEDs into it at different angles, to improve our range in both directions.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 02-04-2008, 10:22
FRC #2518
so at the regionals we could control our bot just past the first line but then we lost it. Now if we just put some more IR LEDs in series around the one that's already in the remote would we be able to control it farther? is it legal?
i figure in Atlanta it would help if we can get lots o' points in autonomous
thanks for all of the help :-D
Unread 06-04-2008, 20:04
mrbob1000's Avatar
mrbob1000 mrbob1000 is offline
I feel smarter already!
AKA: Stephen Johnston
FRC #2377 (CCompany)
mrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to beholdmrbob1000 is a splendid one to behold
Send a message via AIM to mrbob1000
put them in parallel
also, use ones with low current drain but high output (look around!) this will make it so you dont kill your batterys every match!
also, look at the front of the remote through a camera. (to check if they work and to check if your batterys are dead)
Unread 11-04-2008, 15:06
de_ de_ is offline
AKA: Dave Edwards
We swapped out the standard led and used 3 high power LEDs in a remote (but did not change the current limiting resistor due to time and risk limitations). We found that we could make it to the end of the field most times and a very few times turn across the end line. (our robot's IR sensor turned to face the hybrid driver as the robot turned using the gyro and a servo). But in a few matches we (nor our alliance hybrid drivers) could not move more than a few feet from the starting point. Our best guess is the opponents IR transmitters IR light was powerful and it bounced off the plexiglass (or lexan) (non-hybrid) driver "window" to reflect into our robot IR sensor.
Unread 11-04-2008, 16:11
adman adman is offline
Engineering Support
FRC #1024
adman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant futureadman has a brilliant future
Anything past a 100 feet is not going to do you much good. An array
of 33 leds makes the beam very wide. The idea of looking at
the wall with ccd based camera is good since most see in the infrared.
Experiments with a glass partition shows that quite a lot of the infrared
beam glances off ( relfects ) so you don't get a whole lot through the
plexiglass center ( and posts! ).
Cross talk between remotes is the big problem.
pic: Aiming High, even before 2006 FIRST Aim High RoboMadi Extra Discussion 7 29-10-2012 12:23
Remote sportman3333333 Control System 2 27-01-2008 12:41
Wheeler High Breaks Bread With Wheeler High dangerousdave Championship Event 0 20-04-2005 23:28
Remote Remote Kickoff for Southern California ChrisH Southern California Regional Robotics Forum 0 05-01-2004 12:36
Remote Remote Kick off at University High School George1902 Off-Season Events 4 04-01-2004 21:05
