Go to Post Step 1: Get a blue banner. Step 2: Wave it everywhere until your School Board acknowledges your existence. We haven't gotten to Step 1 yet, unfortunately. - Chris is me [more]
Unread 13-03-2008, 20:40
Jrocklz's Avatar
Jrocklz Jrocklz is offline
FRC #1341 (Knights Who Say Ni)
Jrocklz is an unknown quantity at this point
help w/ drivetrain
our robot is having issues. When we try driving the wheels dont turn but jerk violently. With much frustration we can get a few laps out but it is not perfoming like it should be. We tried new joysticks, new motors, and even put heat sinks on them. What could be the problem? Is itpossible hat we just dont have enough torque to drive our robot. Could it be programming flaws? If any one could help us out that would be great.
Team 1341
Florida regional
Unread 13-03-2008, 20:45
in between teams
AKA: Luke Van Oort
Re: help w/ drivetrain
Do you have a backup battery hooked up? If you use main batteries that are a bit low on the juice, not having one can result in the exact behavior you are desribing.
Team 1219: 2009 - Mentor
Unread 13-03-2008, 20:52
,4lex S.'s Avatar
,4lex S. ,4lex S. is offline
University Mentor
AKA: Alex Strong
FRC #2702 (REBotics)
,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of,4lex S. has much to be proud of
What is your weight, drive motor type and quantity, speed reduction and mass?
It would be easier to determine if you have a mechanical issue if I knew this stuff. However I can't see this being a mechanical issue if it is not readily visible...
University of Waterloo Mechanical Engineering Class of 2014- 2B School Term
University of Waterloo Formula SAE Race Team 2010-Eternity
FRC 2702: REBotics 2011 Mentor ::: FRC 1006: Fast Eddie Robotics 2005-2009 Alumni ::: FLL 4050: 2004 Alumni
Unread 13-03-2008, 21:24
Branden Ghena's Avatar
Branden Ghena Branden Ghena is offline
Previously: tawnos23
FRC #0240 (TEMPEST)
Branden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura aboutBranden Ghena has a spectacular aura about
Do you have a four-wheel drive system based on traction wheels?
This sounds a lot like what happened to Team 240 last year. We built the robot with four-wheel drive using four traction wheels, and while our robot was good on the straight paths, it just couldn't turn. We ended up taking off the front wheels for omnis and a two-wheel drive system.
Branden Ghena - Michigan Tech Student and Team 240 Alumnus
Working Towards: Electrical Engineering and Computer Engineering Double Major
"All we have to decide is what to do with the time that is given to us." - Gandalf
Unread 13-03-2008, 22:14
Can you describe your drivetrain?
Something like what you're describing could be caused by having two motors on the same gearbox running in opposite directions. One will occasionally trip its circuit breaker and let the other one move the robot for a while until the breaker resets. Test that possibility by removing all but one breaker to your motors' Victors, and running each motor in isolation to make sure it's turning in the direction you expect.
Unread 16-03-2008, 00:48
Team1341TechMan's Avatar
Team1341TechMan Team1341TechMan is offline
Konrad Coutinho
AKA: Konrad Coutinho
FRC #1341 (The Knights who Say Ne)
Team1341TechMan is an unknown quantity at this point
Send a message via AIM to Team1341TechMan
although it's a moot point now that our florida regional is over, our robot had a two wheel drivetrain with caster wheels in the front. We had two large bicycle wheels in the back, each with 1 CIM Motor and 1 AndyMarks Gearbox. When speaking with an engineer from Team 79 (Krunch), he said that our wheels did not have enough torque. We would tether it up and be driving it full speed forward and he could completely stop it by pressing it down. We tried everything from all-or-nothing driving (any push of the joystick results in full speed for the motor) to taping the wheels with electrical tape to reduce traction. Attached is a photo of our robot. This issue was so upsetting because, due to favorable matchups in the qualifying round, we had a real chance of being a top seed. We ended up 5-3 and 16th and not getting picked.
Unread 16-03-2008, 01:04
Mike8519's Avatar
Mike8519 Mike8519 is offline
FRC #0303 (TEST Team)
Mike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really niceMike8519 is just really nice
Given the diameter of your wheels you needed a higher torque to move your machine, likely adding a 2nd CIM would have solved your issues.
Unread 16-03-2008, 13:24
,4lex S.'s Avatar
University Mentor
AKA: Alex Strong
Sounds like a direct drive from a Toughbox... am I not correct?
If you want to grab more torque just increase the reduction with a sprocket setup. A lot of teams seem to be going with a very high speed and it seems to be hurting their acceleration.
Unread 16-03-2008, 18:13
Sam N.'s Avatar
Sam N. Sam N. is offline
FRC #1351 (TKO)
Sam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to beholdSam N. is a splendid one to behold
Send a message via AIM to Sam N.
what battery volatage is your robot controller giving back to your OI?
(it may not seem important but it is important to diagnose IFI errors)
Mitty Robotics Alumni
TKO 1351
Unread 16-03-2008, 21:33
tennispro9911 tennispro9911 is offline
Alumni
AKA: Matt
FRC #2053 (TigerTronics)
tennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to beholdtennispro9911 is a splendid one to behold
Send a message via AIM to tennispro9911
Those look like huge wheels. CIM wheels have 64 oz in torque under "normal load" which is 27 A and 12 V. I've found that at a high current, the battery cannot sustain 12 V even if it is fully charged, so you could use the figure for 40 A, 12 V but I personally doubt you will get that ideal figure.
64 oz in * 12.75 (toughbox speed reduction, torque multiplier) = 816 oz in, although the toughbox is only 80% or 90% effecient so multiply by .8 or .9 depending on your assumptions.
816 oz in * 1lb/ 16 oz = 51 lb in
I don't know the diameter of your wheel but my guess is a 16" bike tire so 8 in radius and 8in lever arm.
51 lb in / 8 in = 6.375 lb force from each wheel/motor. If you had a sprocket drive then you can multiply this number by whatever speed reduction you would use. Of course, you would go slower but thats a small price to pay for being able to turn.
To quote the possibly overused but completely accurate words of an announcer from last year "And this is why we do the math."
So I don't know how much force you need. That depends on the radius that the frictional force is acting on the turning of your robot and at what angle, and at what angle and radius the force of your wheels are acting on the turning of the robot and the frictional force of your caster wheels. I don't even know how you would go about figuring out some of those things, but just a does this number make sense check would tell you that 12.75 lbs from all of your wheels will not sufficiently power a 150 lb robot (15 lb battery and 15 lb bumpers).
2053 Alumni
Need help with clutch in drivetrain AdamHeard Technical Discussion 8 13-11-2007 03:18
HELP with drivetrain decision geowasp Motors 14 08-04-2006 13:03
Please Help: FIRST Drivetrain xxmaddjxx Technical Discussion 5 24-04-2004 23:48
Drivetrain help thedillybar Technical Discussion 9 08-01-2002 21:54
Drivetrain Help Jordan Technical Discussion 16 02-12-2001 12:14
