Go to Post Honor is doing the right thing when nobody is watching. - Daniel_LaFleur [more]
Unread 16-03-2008, 14:57
Chris_Elston's Avatar
Chris_Elston Chris_Elston is offline
Controls Engineer
AKA: chakorules
FRC #1501 (Team THRUST)
Chris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond reputeChris_Elston has a reputation beyond repute
Metal Shavings and RC don't mix
Just a quick note to the CD community...watch your metal shavings around your RC.
1501 fried our 2008 RC Friday morning at Boilermaker, but luckily took our 2007 RC as a spare with us. If you do this, make sure you have master code version 15 installed in your 2007 controller. You can check this within the first 5 seconds of power on, then quickly press the select button on your OI, and you should see U15 if your good to go.
What's ironic about this...was Digital Goats 829 handed us a safety flyer in our pits right when we figured out what was wrong with our robot after 3 crazy acting matches on Friday of stuff not working…on the flyer it said to "watch our metal shaving"...
I about croaked over in laughter, we had to laugh because it was crazy trying to figure out what was wrong….I am pretty sure we are going to frame it I think.
And just to let you know the metal shaving shorted out in the output pins of the digital I/O. Between the GND and +5V. By match #3 of our qualifying, FINALLY the RC Hardware light came on, it illumined yellow, and right where your main power connects, the RC was very hot to touch.
Then to later find out 1024 fried their RC as well in the finals at Boilermaker, really makes it a “spooky” weekend at Boilermaker for sure…
Team T.H.R.U.S.T. 1501
Download all of our past robot's source code here:Repository
Favorite CD quote:
"That can't be their 'bot. not nearly enough (if any) rivets to be a 1501 machine." ~RogerR: Team #1369
Unread 16-03-2008, 15:36
chrisstruttmann chrisstruttmann is offline
FRC #0386 (Team Voltage)
chrisstruttmann will become famous soon enough
Send a message via AIM to chrisstruttmann
Re: Metal Shavings and RC don't mix
Team Voltage got bitten by a similar scenario at the Florida Regional.
Delayed our inspection by about 20 minutes.
Unread 16-03-2008, 16:02
Richard Wallace's Avatar
Richard Wallace Richard Wallace is online now
I live for the details.
FRC #3620 (Average Joes)
I about croaked over in laughter, we had to laugh because it was crazy trying to figure out what was wrong….I am pretty sure we are going to frame it I think. …
The D-Goats' advice is good and they practice what they preach. I was one of the robot inspectors on duty in their row of the Boilermaker pits. When they found out, after a configuration change, that their 'bot needed to drop a pound or so, their first step was to cover the entire control system with a large sheet of plastic. Their second step was to set up a shop-vac. Their third step was get out the hole saw and go to work. No short-circuits for 829.
Other teams have skipped steps one and two above, and regretted it.
Richard Wallace
since 2003
Unread 16-03-2008, 16:10
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
We've had issues with shavings in victors, but never with the RC. Ouch. We have a nice plastic sheet we use whenever we work on something which produces metal shavings, or any other kind of shaving. Always a good idea.
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 16-03-2008, 16:49
When making metal shavings on a finished robot, make sure that your burnt offering to the gods does not include 'bot electronics.
Unread 16-03-2008, 16:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I've got a semi-related question: does anyone know of a good way to straighten heavily-bent pins on an RC? Specifically, the digital inputs, after having been smashed with a robot arm (prior to the guarding being installed). That progressive damage due to a low-current short sounds like a worrisome possibility, if the pins are left alone.
Unread 16-03-2008, 17:13
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Fire doesn't mix well with RC's either.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 16-03-2008, 17:45
galewind's Avatar
galewind galewind is offline
... more like a temperate breeze
AKA: Chris Gregory
FRC #1089 (Team Mercury)
galewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond reputegalewind has a reputation beyond repute
Send a message via AIM to galewind
hey, could metal shavings on the RC cause the Low +5v output LED to light up? I think that might be what happened to 1089's RC this weekend, too. We're going to bring our 2007 RC to Atlanta, and hope and pray we get our 2008 back from IFI in time.
Chris G
Advisor, Team Mercury (1089), Hightstown High School
Unread 16-03-2008, 22:46
That's a very common symptom of an unseen whisker of metal touching the RC's pins. All of the analog and digital pins have ground and +5 right next to each other, and shorting them together will definitely set off the low +5v detector.
Unread 17-03-2008, 08:15
I had a robot in Chicago that had a metal shaving between two pins. It gave an RC hardware light that indicated that one of the 5 volt power supplies was down. The RC was also very warm to the touch in the one corner outlined above. Obviously, a 5 volt regulator lives under that section of the RC cover. The shaving was only noticable under a very bright light and I could not dislodge it with a paint brush. I ended up using the fine tip screwdriver of my Leatherman to move it out of the pins.
Tristan,
The pins on the RC can be bent to almost straight with a pair of needle nose pliers. Be very careful as the pins can be a little brittle and will break if you are too agressive. This operation is best done out of the robot under a bright light, at a table or bench. If you are coming to Atlanta and do not need the RC before then, just look me up and I will help you through a few of the pins. I am lead inspecting again, so you know how to find me.
Unread 17-03-2008, 12:24
diesel's Avatar
diesel diesel is offline
FRC #2077
diesel has a spectacular aura aboutdiesel has a spectacular aura about
Metal Shavings and Rc don't mix.
How 'bout soda and an O.I.
It happened to us Saturday morning at the Wisconsin Regional
our coaches fault, and it cost us a match.
Design. Build. Dew.
Unread 19-03-2008, 14:06
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
This happend to team 339 at VCU. When the problem first manifested itself, we noticed that we had lost 5V power to the geartooth sensors, causing the robot to slam into the opposing alliance's wall in hybrid mode.
The next match, we noticed that we had lost 5V power to the "disable autonomous" switch, causing the robot to slam into the opposing alliance's wall in hybrid mode.
After that, we saw the "5V output low" light on the RC. Unable to find the short, we had to use a loaner (from 2004!) for the rest of the day.
After returning from VCU, I held the RC up to the light and noticed a metal shaving under one of the digital inputs. Clearing it solved the problem.
Unread 16-03-2008, 17:47
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
Just a quick note to the CD community...watch your metal shavings around your RC...
And that would be why our robot is shipped with a pink blanket. It's not just to comfort our robot as it endures hours of loneliness in the dark, enclosed crate, bumping over asphalt in a FedEx truck!
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 16-03-2008, 21:20
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
We had problems at SV with shavings but they only made our RC Hardware light glow yellow until we got them out.
pic: Cats and Tetras do mix Jessica Boucher Extra Discussion 8 03-01-2008 12:51
<R34> and Metal on Carpet Ben Piecuch Rules/Strategy 4 06-02-2007 14:10
pic: PSA: Watch your metal shavings Chriszuma Extra Discussion 14 06-04-2006 00:21
Thanks to Metal in Motion and Operation Oxidation! Zack Ghahramani Thanks and/or Congrats 0 09-03-2003 17:18
mix and match animals oreocookeee Chit-Chat 4 10-07-2002 21:51
