Go to Post Welcome to adulthood. Remember, patience is your friend. Denial is your shield. Bitter disinterest your salve. Your endless hours of crushing workload will be your strength. Good luck, soldier. - Koko Ed [more]
Unread 16-03-2008, 16:04
Re: Batteries in Parallel
Uber,
Perhaps you should let us know what inverter you are planning on using and what kind of load. Are the 35 amp fuses in the input side or the output side? Remember that although we demand some pretty high intermittant currents from these batteries, they are not meant for long term high currents. In the constant load at which you are hinting, the manufacturer specification is much lower than the 17 amp hour. At 17 amps, this battery will fall to 10 volts in about 30 minutes. At 30 amps, that falls in about 10 minutes.
Parallel Tanks AdamC Pneumatics 12 13-11-2007 20:14
Parallel Processor rohandalvi Kit & Additional Hardware 25 27-10-2004 20:21
Serial/Parallel Interface mchan1111 Programming 2 22-10-2004 23:36
Parallel Motor Connection Don Wright Electrical 12 30-03-2004 21:23
Working in Parallel dubya404 3D Animation and Competition 7 28-01-2003 11:48
