Go to Post if it was up to me, id just get one of those spinning BINGO things and do it that way - dodar [more]
Unread 11-03-2008, 19:43
ZP8892's Avatar
ZP8892 ZP8892 is offline
FRC #0369
ZP8892 is an unknown quantity at this point
Send a message via AIM to ZP8892
Exclamation Last minute autonomous programming!
We need help using a counting variable for programming autonomous. The counter should be incrementing but its not. It sorta looks like this:
unsigned counter = 0;
counter++;
printf ( "counter value: ", counter);
Any suggestions would be very much appreciated!
Unread 11-03-2008, 19:45
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Re: Last minute autonomous programming!
your variable declaration is executed every loop, meaning it will be initialized to 0 every loop. declare it as a static unsigned, and your counter will work.
Unread 11-03-2008, 19:59
scottanderson's Avatar
scottanderson scottanderson is offline
AKA: Scott Anderson
FRC #2608 (MiGHT)
scottanderson is an unknown quantity at this point
Actual code would help...
I see several problems with what you posted:
No type on counter:
unsigned int counter = 0;
No spec in the printf to actually print the value:
printf( "counter value: %d\n", (int) counter);
As was pointed out, is this all in the same loop?
Regards,
Scott Anderson
Team 2608 MiGHT Mentor
Unread 12-03-2008, 01:17
slavik262's Avatar
slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
If it is all within the loop, to prevent the counter from being reset every iteration of the loop, declare it in the following manner:
static unsigned char counter;
Unread 12-03-2008, 01:20
Guy Davidson Guy Davidson is offline
AKA: formerly sumadin
FRC #0008 (Paly Robotics)
Guy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to beholdGuy Davidson is a splendid one to behold
Send a message via ICQ to Guy Davidson Send a message via AIM to Guy Davidson Send a message via MSN to Guy Davidson
I'd referain from making it a char. A char will overflow after 256 cycles. Running around 26.2hz, the main loop will make 256 cycles in around 9.8 seconds. After that, it will drop to zero and start rising again. I'd suggest you make it
static unsigned int counter;
Unread 12-03-2008, 01:21
slavik262's Avatar
AKA: Matt Kline
True. It depends how fast this loop is running. If it is running constantly, then a larger type should be used.
Unread 16-03-2008, 21:04
Loubear's Avatar
Loubear Loubear is offline
AKA: YLou
FRC #0075 (RoboRaiders)
Loubear will become famous soon enoughLoubear will become famous soon enough
Autonomous only lasts 15 seconds. And teleop is 2 minutes. With about only 39 iterations per second, an unsigned int is more than enough to hold the tick counter.
Unread 16-03-2008, 22:43
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
26.2ms/packet is actually about 38.17Hz.
Also, I believe this variable would overflow in about 6.7 seconds. I suggest you blow the extra byte of memory and go for an unsigned integer just to cover everything, as this won't overflow until after a whole 28 minutes at the 26.2ms rate.
I suggest a switch statement to run your time based autonomous.
If you are going to Cleveland, i'd be happy to give you some 'pointers'.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Last Minute Work! Aratarin Chit-Chat 0 18-02-2007 16:08
Last Minute Programming Failures robobrain0101 Programming 3 11-02-2007 14:30
pic: last minute cheeseholing Veselin Kolev Robot Showcase 8 22-02-2005 19:25
Last-Minute changes? Iain McLeod General Forum 9 09-04-2003 02:51
Last Minute Mouse Robots Hamster_Power58 Rules/Strategy 1 12-03-2002 14:32
