Go to Post ...and that is exactly why Dave is the coolest nerd I know. - Rich Kressly [more]
Unread 16-03-2008, 18:38
Re: Popsicle Stick Tower
Originally Posted by merybar View Post
Any ideas?
See the references to 233. Looking at their robots should help. (Not the motion, just the metal.)
Unread 16-03-2008, 18:45
dtengineering's Avatar
AKA: Jason Brett
Can you cut the popsicle sticks?
What determines the winning structure? Greatest weight held? Lowest mass of the structure?
Build prototypes, talk to your woodwork teacher (or read up on line) about making successful glue joints in wood, and think triangular.
Jason
Unread 16-03-2008, 19:34
merybar's Avatar
merybar merybar is offline
AKA: Matt
FRC #0894 (Chargers Robotics)
merybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of lightmerybar is a glorious beacon of light
Send a message via AIM to merybar
No cutting is allowed. Winner is determined by highest weight and tie breaker is lowest mass.
I have prototyped a design and it holds 90 pounds.
Unread 16-03-2008, 19:54
IBdrummer's Avatar
IBdrummer IBdrummer is offline
AKA: Beau Muniz
FRC #5492 (Winners Circle Robotics)
IBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of lightIBdrummer is a glorious beacon of light
Yea, the triangles really work wonders, but if you end up having extra ps's then you should add more to the bottom.The trick with most pattern structures is to make sure the openings are smaller on the top to increase stability and overall strength
Unread 16-03-2008, 22:11
Are you allowed to cut the popsicle sticks? Does the load move? How big is the load? Do you have support the load in a horizontal plane (can the weight move around, or is it suspended)?
Remember that these sticks are made from wood, and wood is extremely strong in compression, just like trees are. Those 250-foot redwoods and Douglas firs are just great big round popsicle sticks standing around. So, make sure you use the sticks like trees -- keep them standing up as much as possible. If you could glue together six sticks together in a long triangular solid structure (picture three sticks glued together in a triangle along their long sides -- it would be as long as a single stick, and only about a half-inch across) it would easily hold 10 pounds, but it would also fall over. That's why I wanted to know how big the weight is. Gluing up a web of that many popsicle sticks on end would probably hold you 10 inches off the ground, as long as you could keep it from tipping over and make sure the force goes along the wood and not through glue joints.
Unread 16-03-2008, 23:45
Question answered...
Unread 17-03-2008, 00:11
Cooley744's Avatar
Cooley744 Cooley744 is offline
Cooley744
AKA: Lauren
FRC #0744 (Shark Attack)
Cooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to beholdCooley744 is a splendid one to behold
Send a message via AIM to Cooley744
triangles and have supports going throughout the tower like if you were looking at an arial view with no top it would look like this: X
For whatever you do, work at it with all your heart, as working for the Lord, not for men.
Colossians 3:23
Proud graduate and now lead strategy mentor and driving coach for 744 Shark Attack.
Unread 17-03-2008, 17:11
Ljohn2040's Avatar
Ljohn2040 Ljohn2040 is offline
FRC #2040 (D.E.R.T)
Ljohn2040 will become famous soon enough
Try to match your popsicle sticks lengths, eliminate those with warps, cracks, etc.
Assuming there will be some sort of board supporting the weight on the top, make absolutely sure each corner of your structure is the exact same height so that no one corner is supporting more load than another.
Also, google Odyssey of the Mind, they have a similar competition with balsa wood, the structures hold an incredible amount of weight, see the link below.
http://www.odysseyofthemind.com/wf20.../bdsc_0141.jpg
Unread 17-03-2008, 21:43
alex1699's Avatar
alex1699 alex1699 is offline
ummmm thats meee......
FRC #1699 (robocats)
alex1699 has a spectacular aura aboutalex1699 has a spectacular aura aboutalex1699 has a spectacular aura about
Send a message via AIM to alex1699
wow now im going to go get some stick and glue.. lets have a contest.... and see who can win.. first to hold the front of a car with a video wins..
Unread 17-03-2008, 21:54
CraigHickman
Posts: n/a
I've built a Popsicle stick bridge that held 500+ pounds... The key is I beams. Start by making as many of them as possible, then build your triangular structure out of said I beams.
Unread 17-03-2008, 22:14
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
A nice strong structural shape is an arch. I didn't see any rules against using water. Build a perfect arch template then soak your popsickle sticks in water to make them more flexible and fit them over your template. Clamp them in place and allow them to dry. Maybe double layer of overlapping sticks for each arch. When dry glue them together. Use sticks on base to keep the legs from spreading apart. Make several arches and frame them together with adequate platform to support the weight.
Icy Tower DanDon Chit-Chat 16 02-11-2006 14:05
[OCCRA]: tower dimensions mikaela50 OCCRA Q&A 1 26-09-2005 16:16
pic: Team 358 - Tower DarkJedi613 Robot Showcase 6 21-02-2005 19:40
pic: New Tower Iain McLeod Robot Showcase 1 12-02-2005 07:01
LEGO IR tower cable Jeff Rodriguez Chit-Chat 1 31-10-2003 16:23
