Go to Post Don’t get caught in mindsets which will limit the potential that the future may hold. - Jaine Perotti [more]
Unread 17-02-2008, 23:28
holty531 holty531 is offline
FRC #2441
Team Role: Electrical
holty531 is an unknown quantity at this point
picture/diagram of controllable single/double
does anyone have picture or diagram of the controllable actuator system, using a single to control air to the double?
i have tried following the text instructions i have searched however none seem it do it.
Unread 18-03-2008, 08:22
Jeff 801's Avatar
Jeff 801 Jeff 801 is offline
Jeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond reputeJeff 801 has a reputation beyond repute
Re: picture/diagram of controllable single/double
Sorry to bring this back up but does any one out there have this digram or a link to it
Thanks
Unread 18-03-2008, 08:40
Racer26 Racer26 is offline
It looks basically like this
                 --------  EA            ----------  EA
                |        |------\      P |         |-------| (plug)
Pressure In-----|   DS   | EB   |--------|    SS   | EB
                |        |------/        |         |-----> (open to atmosphere)
                  |    |                   A|   B|
                 A|  B |                     \__/
Use the DS to control direction, and the SS to allow/disallow movement.
Unread 18-03-2008, 20:50
DonRotolo's Avatar
Back to humble
FRC #0832
An alternative is to just buy the correct solenoid valve to allow for mid-cycle positions called a "Three-position pressure center" valve. The spec sheet is here. Look at valve type SY3520-6H, for example.
Don
Unread 19-03-2008, 01:30
That works too, under the current rules. The system I laid out above, and personally devised in ~2004 (maybe not the first to do so, but I did it on my own) works with exclusively KOP parts, and I would argue can be made better (with addition of a couple other components) than a center off valve, as far as stability/accuracy goes.
wiring diagram Smaug Electrical 7 01-10-2007 21:39
Single vs double solenoid valve operation Scott358 Pneumatics 0 29-01-2005 11:47
Need instructions for SMC Single/Double solenoid WHou Pneumatics 5 29-01-2005 08:17
using single solenoid like a double SteveO Programming 14 02-02-2004 22:51
Diagram of shelf Joe Johnson Off-Season Events 0 13-10-2001 08:45
