Go to Post Corrected, math isn't my strong point (I went to art school for a reason) - KelliV [more]
  #61   Spotlight this post!
Unread 18-03-2008, 00:50
MFS766's Avatar
MFS766 MFS766 is offline
FRC #0766
MFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of lightMFS766 is a glorious beacon of light
Re: surefire ways to break you robot
This one makes me laugh in retrospect.
The robot was 80 pounds overweight. Someone hands me a grinder with a cutoff wheel and says "starting trimming.....everything!"
  #62   Spotlight this post!
CurseofDragon33's Avatar
CurseofDragon33 CurseofDragon33 is offline
AKA: Thomas Yuricek
FRC #0048 (Delphi E.L.I.T.E.)
Team Role: Scout
CurseofDragon33 will become famous soon enoughCurseofDragon33 will become famous soon enough
Send a message via AIM to CurseofDragon33
Use Super Glue on the gears instead of Gear Lube.
Use wood instead of aluminum.
Drill a hole into a motor.
Enter the robot in a Demolition Derby.
Thomas Yuricek
Delphi E.L.I.T.E.
Team 48
Competition/ Scouting Collegiate Mentor
  #63   Spotlight this post!
Unread 18-03-2008, 08:21
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Herodotus View Post
I can think of many surefire ways to break a robot.
Fire it from a canon.
Yeah, them prelates can be darn tough on robots.
(since 2004)
  #64   Spotlight this post!
Unread 18-03-2008, 08:25
BanksKid's Avatar
BanksKid BanksKid is offline
..as The Circuitrunner.
AKA: Banks, Ethan Banks
FRC #1002 (Circuitrunners)
BanksKid will become famous soon enoughBanksKid will become famous soon enough
Send a message via AIM to BanksKid
who needs to unplug a backup batterie at the connector when you can rip the pins straight out of the robot board?
"WE HAVE A CAMERA RIGHT NOW!"
R.I.P. SAM
  #65   Spotlight this post!
Unread 18-03-2008, 08:41
technoL's Avatar
technoL technoL is offline
AKA: Noelle Manning
FRC #0108 (SigmaC@T)
technoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud oftechnoL has much to be proud of
Send a message via AIM to technoL
- attempt to drive backwards under the overpass with the arm up (last 15 seconds)
- pay attention to people in the stands
- leave the autonomous switch on while testing
Team Leader | Mechanical | Driver | SOAP | Anything
2008: NJ GM Industrial Design Award, 4th Seed | FL Rockwell Automation Innovation in Control Award, 1st Seed, Semifinalists
2007: FL Finalists | LV Xerox Creativity Award, Quarterfinalists | Mission Mayhem Champs
2006: FL Delphi's Driving Tomorrow's Technology | Curie Quarterfinalists
  #66   Spotlight this post!
Unread 18-03-2008, 08:43
swamp_child's Avatar
swamp_child swamp_child is offline
AKA: Cody
FRC #0179 (Children Of The Swamp)
swamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to allswamp_child is a name known to all
use a globe motor to manipulate the part fo the arm which lifts the trackball.
They really arent made for that much force.
2009 Florida Champions thanks to 233 and 1649!
2008 UCF finalists thanks to 69 and 342
2007 world Finalist, thanks to 233 and 71, we love you guys
2007 Archemedies undefeated champions, thanks to 233 and 71
2007 UCF finalists thanks to 1902 108 and 386
  #67   Spotlight this post!
Unread 18-03-2008, 09:52
Cappeh's Avatar
Cappeh Cappeh is offline
the loveable one
AKA: Emily VanValkenburg
FRC #0716 (Who'sCTEKS)
Cappeh is a jewel in the roughCappeh is a jewel in the roughCappeh is a jewel in the roughCappeh is a jewel in the rough
Send a message via AIM to Cappeh
Run matches with a small crack/hole in your chassis where your air compressor is? 8D Thank god we found that.
Let me show you my Pokemans. <3
  #68   Spotlight this post!
Unread 18-03-2008, 10:32
deshirider430's Avatar
deshirider430 deshirider430 is offline
AKA: Shan Rammah
FRC #0612 (Chantilly Robotics)
deshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nicedeshirider430 is just really nice
Forget to tighten down all the bolts when replacing parts on the elevator.
http://www.thebluealliance.net/tbatv...p?matchid=6050
Focus in at about 60 seconds left in the match, our support brace which runs from the elevator to the back of the robot snaps off and the whole elevator dips forward. Lucky for us this was an easy fix, and we got some points for herding the ball across the red finish line
2008 NASA/VCU Chrysler Team Spirit Award
2008 Buckeye KPC&B Entrepreunership
2008 Buckeye Regional Chairman's Award
  #69   Spotlight this post!
Unread 18-03-2008, 11:12
Ian G Ian G is offline
BUILD SUCCEEDED
FRC #2415 (WiredCats)
Ian G is an unknown quantity at this point
Send a message via AIM to Ian G
A few things that happened to us:
Driver is egged on by a mentor to spin the robot with a arm holding a trackball straight up...
During the pre-ship scrimmage, my team didn't tell me they were testing automode... which consisted of the robot running full speed down the track and then reversing... sometimes I think 127 and type 0, which is why I tell them to test it on blocks.
On Thursday afternoon, I finally get to download code to test... and the robot inexplicably wouldn't turn on.
Try to add more IR receivers 30 seconds before the match...
  #70   Spotlight this post!
Unread 18-03-2008, 11:17
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Upon entering FIRST you immediately apply Murphy's Laws.
  #71   Spotlight this post!
Unread 18-03-2008, 11:41
Jaime65's Avatar
Jaime65 Jaime65 is offline
AKA: Jaime
FRC #3398
Jaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud ofJaime65 has much to be proud of
Re: surefire ways to break your robot
Originally Posted by boiler View Post
Look across the field to see 1024, 111, and 1114 on the other alliance. Your robot may not break, but your drivers will.
Hahahaha
True!
2015 • Team #3398 Crushing Crusaders • Mentor
2008 – 2009 • Team #65 Huskie Brigade • Mentor
2003 – 2007 • Team #65 Huskie Brigade • Human Player
Most Of The Time You Will Fail, But You Will Also Occasionally Succeed.
Those Occasional Successes Make All The Hard Work And Sacrifice Worthwhile. - Dean Kamen
  #72   Spotlight this post!
Unread 18-03-2008, 12:28
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
Let a programmer try to fix a manual problem with the solinoid.
Programmer:"I got it to work"
Me:"How"
Programmer:"This was the problem" Hands me solinoid.
so so true.
Is now an engineer thanks to FIRST.
  #73   Spotlight this post!
Unread 18-03-2008, 14:56
Engineer's Avatar
Engineer Engineer is offline
KØBR
AKA: Rick - KØBR
FRC #3007 (RoboTitans)
Engineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of lightEngineer is a glorious beacon of light
Originally Posted by Jim E View Post
Any action following the phrase:
"Hey! Watch this!"
For those old enough, this statement is usually preceded by the words "hold my beer" and then followed by a trip to the hospital.
2008 GM Industrial Design Award (2232)
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming -- WOW -- What A Ride!" Anonymous
Hello, from KØBR.
  #74   Spotlight this post!
Unread 18-03-2008, 16:11
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Spend thirty minutes preparing everything for the practice field - turning on print statements, making a list of what you're going to do, writing test code for different situations...etc.
After we did this at the Chesapeake regional, we went to the practice field and started to test hybrid. The robot would go forward, stop, go forward, stop...etc. We wasted our entire practice field session figuring out that our battery was low.
  #75   Spotlight this post!
Unread 18-03-2008, 16:33
Rick Thornbro Rick Thornbro is offline
#0217 (ThunderChickens)
Rick Thornbro will become famous soon enoughRick Thornbro will become famous soon enough
Turn on power
MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 0 03-02-2008 16:37
pic: strange ways you test stuff out? DarkFlame145 Robot Showcase 1 13-01-2008 15:10
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" Mr MOE General Forum 6 09-02-2007 08:40
What do you do when its time to take a break from building?? Leo 1529 Chit-Chat 23 13-02-2006 00:26
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 3 15-02-2005 11:38
