Go to Post You can never have enough figurative language. - Travis Hoffman [more]
Unread 18-03-2008, 09:14
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
Re: Legality of Team 190's Mechanism?
Originally Posted by Ricksta121 View Post
Thanks Paul. It really is cut and dry.
Even if this was legal why would you do it? Teams with shooters and arms can hurdle 5,6, and even 7 times a match. 190 has hurdled once, twice this way?
You would do it because it is a creative design solution to the competition.
I understand the problem and why it is not legal yet this question clearly lays out EXACTLY what 190 does. And even though rule G22 was not mentioned, the question only asks if the move is legal, it does not ask if it breaks such-and-such a rule. Therefore, GDC should of mentioned G22 in there response and said it was not legal, yet they didn't.
As for my contrubution to the brainstorming. I suggest the add a "wrist" and a suction "lock" to the end of there arm, this way you can lock the suction cup in place when it is reeled back to the top of the arm, rotate the wrist (so now the ball sits beside the arm, as oppose to underneath it) and rotate you arm until the ball has passed into Q4 yet the arm has not. Then retract the arm (which they can already do, I think) back into Q1, and extend back into Q2, dropping the ball.
I hope they find a good solution to the problems they now have!
pic: Team 1178 Robot - Hand mechanism Jake M Robot Showcase 0 01-03-2007 19:41
Introducing 190's Gompei the Burninator ahecht Robot Showcase 7 22-02-2005 23:55
pic: Introducing 190's M.O.H. Goat CD47-Bot Robot Showcase 24 01-03-2004 00:53
pic: Team 60 Mechanism CD47-Bot Robot Showcase 2 11-02-2004 21:47
