Go to Post "I have cut this piece 4 times and it is still too short!" - Betty_Krocker [more]
Unread 18-03-2008, 12:16
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Help: wiring ADXRS300EB Gyro Eval Boards
Just got our Eval board from Digikey.
I presume I wire red to AVCC, Black to AGND, & white to RATEOUT.
But the documentation says " Note the... charge pump supply ... PDD.. are not connected on the ADXR... and the user must connect these as appropriate.
What do I do with PDD ? connect it to red as well ?
ADXRS300EB gyro help Chris Bright Programming 4 08-02-2005 17:59
2003 Gyro Wiring Harness DukesAZ Electrical 3 03-02-2005 18:20
2003 Gyro Wiring Harness DukesAZ Technical Discussion 3 03-02-2005 18:20
ADXRS300EB Rate Gyro rmeenaks Electrical 18 05-04-2004 22:37
ADXRS300EB Rate Gyro rmeenaks Technical Discussion 0 31-03-2004 16:48
