Go to Post Remember, if FIRST is your top priority, you need to look at your priorities. - Billfred [more]
Unread 18-03-2008, 12:16
de_ de_ is offline
AKA: Dave Edwards
FRC #1310 (Runnymede Robotics)
de_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the roughde_ is a jewel in the rough
Help: wiring ADXRS300EB Gyro Eval Boards
Just got our Eval board from Digikey.
I presume I wire red to AVCC, Black to AGND, & white to RATEOUT.
But the documentation says " Note the... charge pump supply ... PDD.. are not connected on the ADXR... and the user must connect these as appropriate.
What do I do with PDD ? connect it to red as well ?
Unread 18-03-2008, 14:49
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Re: Help: wiring ADXRS300EB Gyro Eval Boards
There are directions here: http://www.kevin.org/frc/gyro/
You may also find the gyro zip file here useful: http://www.kevin.org/frc/
Unread 18-03-2008, 19:49
de_ de_ is offline
AKA: Dave Edwards
Thanks. I did find a datasheet specifically showing the charge pump supply (PDD) being connected to AVCC (ie red 5v) and have since successfully wired it up. Slightly more complicated than the www.sparkfun.com version but they are out of stock for weeks!
Now to make (intelligent) use of it !
Unread 18-03-2008, 22:21
We have used both Kevin's FRC drivers & Easy C.
ADXRS300EB gyro help Chris Bright Programming 4 08-02-2005 17:59
2003 Gyro Wiring Harness DukesAZ Electrical 3 03-02-2005 18:20
2003 Gyro Wiring Harness DukesAZ Technical Discussion 3 03-02-2005 18:20
ADXRS300EB Rate Gyro rmeenaks Electrical 18 05-04-2004 22:37
ADXRS300EB Rate Gyro rmeenaks Technical Discussion 0 31-03-2004 16:48
