Go to Post I personally hope they change the terrain of the playing field ... if only to "level" the playing field. - Daniel_LaFleur [more]
Unread 18-03-2008, 17:24
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
FRC #0647 (Cyber Wolf Corps)
SL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud ofSL8 has much to be proud of
Send a message via Yahoo to SL8
Finding heading from camera.
I am not sure how you find a heading to the tracked object base on the camera data.
Unread 18-03-2008, 19:10
bear24rw's Avatar
bear24rw bear24rw is offline
Team 11 Programming Captain
AKA: Max T
FRC #0011 (MORT)
bear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to beholdbear24rw is a splendid one to behold
Send a message via AIM to bear24rw
Re: Finding heading from camera.
Could you explain your question in more detail?
Unread 18-03-2008, 19:43
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
Well, if you want a heading based on the current robot heading (instead of an absolute heading), you can figure out the field of view of the camera (an angle measure). Then, using the x-coordinates of the center of the ball, you can approximate a heading.
Unread 18-03-2008, 21:29
SL8's Avatar
SL8 SL8 is offline
AKA: Jesus
I mean that I would like to the program to figure out what the pwm outputs need to be to drive to the ball based on data from the camera.
trasmitting data from a second camera iwdu15 Programming 1 02-02-2007 19:25
Camera won't initialize when reset from RC - reset from OI and Power-up works, krunal Programming 7 15-01-2007 00:13
Help needed with finding stud terminal block from KOP amirjpl Electrical 11 25-01-2006 19:32
Camera Range Finding russell Programming 9 31-01-2005 19:54
Animation Question- Material from Camera Alexander McGee 3D Animation and Competition 11 19-11-2003 22:29
