Go to Post Like fishing, some may get away as you are reeling them in, but never letting out enough line to get the big ones at the bottom is just disappointing. - Eric O [more]
Unread 18-03-2008, 16:27
FRC4ME FRC4ME is offline
FRC #0339
FRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant futureFRC4ME has a brilliant future
Wireless Programming
I was wondering if something like this would be able to wirelessly program the robot. It appears to have all of the required pins and can take +5V power from one of the inputs or outputs on the RC. It claims a maximum speed of 115kbps which is faster than the speed at which a program downloads.
I've heard of others using devices like these to get debug information from the robot, but I've never heard of anyone actually programming the robot this way. Can it be done?
Unread 18-03-2008, 16:43
Re: Wireless Programming
It seems like it should work, but I've never heard of anyone getting it to work reliably. The "packetizing" of the serial data as it travels across the Bluetooth layer apparently interferes severely with the IFI Loader protocol. If programming works at all, it works extremely slowly.
Cross The Road Electronics planned to produce a wireless programming solution called the Chicken Wire last year. I think the prototype works fine, but I haven't seen it made available for purchase.
Unread 18-03-2008, 23:37
slavik262's Avatar
Happy Birthday! slavik262 slavik262 is offline
We do what we must because we can.
AKA: Matt Kline
FRC #0537 (Charger Robotics)
slavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to beholdslavik262 is a splendid one to behold
Send a message via AIM to slavik262
Any additional packet-management seriously messes with IFI Loader. Just using a USB to serial cord caused the code to download extremely slowly and even time out occasionally.
An alternative would be wireless serial, but from what we've seen they run at about $300 a piece for what you would need to program a robot with.
Unread 19-03-2008, 01:54
Racer26 Racer26 is offline
I know Ewave (the company that made the old pre-2007 radios) made a product called the STAMPER (Our radios were SCREAMER422s, as opposed to their standard SCREAMER, difference being RS-232/RS-422 serial comms)
The STAMPER was designed to load code to our old pre-2004 IFI RCs, which ran on a Parallax Basic Stamp 2sx. I don't know if it will work with the newer ones or not... I can't really see why not, but you never know.
Unread 19-03-2008, 08:01
Gdeaver Gdeaver is offline
FRC #1640
I wouldn't invest in any hardware untill the details of the new control system are released. First as already indicated that FTC is going to be Blue tooth and I would expect FRC to follow
Unread 19-03-2008, 11:58
FRC #0339
That's strange. We use a USB-to-serial cord all of the time and never experience those problems.
A few years ago, we thought the USB-to-serial cord was unreliable and stopped using it. This year, however, we discovered that the real problem was the inability of the laptop to power the adapter when its battery level was below 50%.
Now, we just plug in the laptop before downloading and it works at full speed every time.
Unread 19-03-2008, 20:40
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Yeah we haven't had any problems with the USB-to-Serial after we had the correct configurations set.
I can see having a wireless handy for all those times the programmer might forget to unconnect the laptop and the robot(it wasn't me )
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 25-03-2008, 19:41
rpgcubed's Avatar
rpgcubed rpgcubed is offline
AKA: Nick
FRC #2456 (Recycle-It!)
rpgcubed is an unknown quantity at this point
I actually did use a bluetooth to serial bus to program and debug my robot, and it worked quite well. There was no noticeable lag until you got quite far away.
"The scientists of today think deeply instead of clearly. One must be sane to think clearly, but one can think deeply and be quite insane."
Nikola Tesla (1857 - 1943)
Unread 25-03-2008, 20:03
Details, please! What kind of computer, what version of the OS, what brand and model of bluetooth adapter, what configuration settings for the emulated serial port, etc., etc.?
Unread 02-04-2008, 18:57
mluckham's Avatar
mluckham mluckham is offline
FRC #0758 (Sky Robotics)
mluckham will become famous soon enoughmluckham will become famous soon enough
Yes, please tell!
We used a Bluetooth-to-RS232 device this year, connected to the Programming Port - for sending telemetry data back to the PC. BUT EasyC would not recognize the Windows Bluetooth port and so we had to keep switching the cable back and forth between the Programming Cable and the Bluetooth device.
We did power the Bluetooth RS232 device using 5 volts from the Robot Controller - it worked fine (very fast, sending the data).
Unread 02-04-2008, 20:15
FRC #0339
I just ordered the BlueSMIRF Gold Bluetooth modem and a Bluetooth dongle.
Any configuration tips to help make this work would be very much appreciated. Thanks!
Unread 11-04-2008, 21:58
3DWolf's Avatar
3DWolf 3DWolf is offline
Boots - Head Programmer / 3D
AKA: Jake
FRC #1502 (Technical Difficulties)
3DWolf is on a distinguished road
Send a message via AIM to 3DWolf Send a message via MSN to 3DWolf
What about something like this?
http://www.a7eng.com/products/embedd...FQLylgod2ig2AA
Has the +5v option, 250kbps
I've often thought about a wireless option to programming - because that darn cable can come out so easy. Especially when you hear your last call 1/2 way through your download and you don't move the laptop fast enough and your robot gets stuck in program state on the playing field (again, I swear it wasn't me)
I don't know much about the logistics behind bluetooth or anything like that - I only know the most simple of programming to get by and program the robot
You can call it the programming teams fault, but we'll just force your arguments nil.
There are 10 kinds of people in the world -> Those who understand binary and those who don't.
WYSIWYG - In FIRST: Greatness
Unread 11-04-2008, 22:03
tdlrali tdlrali is offline
FRC #0469 (Las Guerrillas)
tdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud oftdlrali has much to be proud of
I'd hold off on those expensive Bluetooth/Serial/whatever purchases, you never know what next year's control system will throw at us. I'm willing to bet there won't be much RS232 going on.
Unread 11-04-2008, 22:15
Shadow503's Avatar
Shadow503 Shadow503 is offline
printf("\r\n Moo!");
Team Role: Human Player
Rookie Year: 1991
Shadow503 will become famous soon enoughShadow503 will become famous soon enough
We experimented with something a wireless serial device (I think it was called the xbee). I don't know what all the other people mean with all this "packetizing" talk, but I have gotten both this and a usb to rs232 cable to work perfectly.
Both were slower than the standard serial, but I found the wireless adapter was worth it. We could read data from a bot without having to keep it tethered all the time.
Unread 14-04-2008, 00:22
Jared Russell's Avatar
Taking a year (mostly) off
I've successfully used an HCS12 microcontroller with ZigBee (802.15.4) to program a robot controller before (did it as a project in a digital systems course ). Speed was almost as good as with wired serial. One PC would connect with serial to one HCS12 and transmit - the other is connected to the RC and simply buffers and passes through the data.
So...if you happen to have two HCS12s with ZigBee hardware lying around - go for it?
Wireless programming Calvin_1631 Programming 9 09-03-2007 21:39
Wireless programming and debugging link heydowns Programming 2 23-01-2006 21:39
2 Wireless routers MattK Chit-Chat 7 02-06-2004 20:46
2 Wireless routers MattK IT / Communications 0 02-06-2004 06:30
wireless camera Stephen P General Forum 1 11-01-2003 13:58
