Go to Post FIRST is the best thing I could have ever done. It shows me where I think my limits are, and it destroys them right in front of my eyes. My experiences with FIRST have defined who I am, and I am beyond blessed to have had them. - Audrey Chu [more]
Unread 19-03-2008, 01:26
EricVicenti EricVicenti is offline
FRC #0008 (Paly Robotics)
EricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura aboutEricVicenti has a spectacular aura about
Re: how does one go about making a 6 wheel config drivetrain?
Some teams won't touch #25 in the drive with the length of the overpass. They say it's too weak. It isn't, but if not done right, it can be. (The last time 330 used #25 on a robot was the second stage of their shooter wheel drive in 2006 going to the wheel. It was the first time since 2001, when contact was minimal and #25 was used in the drive. Later, we had a lot of problems with drive chains jumping while using 2001 as a practice bot.)
Agreed, in 2007 we didn't do it right, and chain was snapping all the time. I am trying to remember what exactly went wrong, but our tensioning system was terribly designed, if at all. I dont think we had a plan for tensioning at all untill we were mostly built. Alignment might have also been an issue. (IE, if the sprockets were not close enough to coplanar, the chain would pop off.)
Unread 19-03-2008, 07:32
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
I surprised that nobody has mentioned that 6WD can be done without wheel drop.
488 accomplishes this by using omni wheels on the corners. This style is shown in Madison's preso on FIRST Drivetrains... http://www.chiefdelphi.com/media/papers/2037
A variation of this I've seen on a few bots (45-2007) uses high traction wheels in the center and middle and lower traction wheels on the remaining corners. I'm pretty sure they used no wheel drop in this config. http://www.chiefdelphi.com/media/photos/28857
Mark
Brick walls are for other people. - Randy Pausch
Unread 19-03-2008, 09:25
Mr. Lim Mr. Lim is offline
AKA: Mr. Lim
Here's a link for FIRST Robotics Canada's Robot Design Gallery. There is a section dedicated to drivetrains, many of which are 6-wheel.
http://www.firstroboticscanada.org/site/node/71
In life, what you give, you keep. What you fail to give, you lose forever...
Unread 19-03-2008, 09:28
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
Team 95 has used variants on this team for several year (two primary drive wheels coupled with driven omniwheels to avoid scrub) for several years now, this year in 6WD mode mentioned here.
Unread 19-03-2008, 09:37
Brandon Holley's Avatar
A few clarifications:
-Center wheel drop isn't *necessarily necessary (See any of 25's drivetrains from the '03 and on)
-#25 chain can be just as effective as #35 chain
On the 2nd note there, if your team feels like taking a little risk go for the #25 chain, and make sure you do it right. Tension obviously is key. I have used #25 on my '04 drivetrain (where we did all reduction through chain and sprocket to pair the CIM with the drill and then finally drive the wheels, I believe it was 11 or 12 chains per side) I did it in '05 and I did it in '07...I HAVE NEVER SEEN A #25 CHAIN BREAK so I may be slightly biased, but honestly do not let the age old "#25 is too weak" stop you from trying it.
This year however, we used kevlar reinforced timing belts with aluminum pulleys. Around 1/6 of the weight of a comparable chain and sprocket setup, with very little noise and a very sleak design. I love them, and I see no reason to stop using them. See here: http://www.chiefdelphi.com/media/photos/30256
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 19-03-2008, 11:41
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
Team Fusion has used #25 chain for many years now, and have only suffered once. This was last year, during the Bayou Regional when we used some Chinese chain that wasn't worth the weight it took on our robot and cost us the regional. We are now using Diamond chain, and are very happy with it. We have never had a chain break before in the 4 year's I've been on the team. Tensioning is the key. You cannot have slack with #25 chain in your drive train, as a whiplash can cause it to snap. In 2007 and before, we went with plastic sprockets for idlers, but this caused some trouble last year when we snapped the axle that the idler was running on. Now we're using nylon blocks and some hardened steel for tensioners (We put these on in Houston last year, and made something very similar this year). We have been very happy with this method. We use nylon block, but some certain type from McMaster Carr that has some lubrication fused into the nylon. I don't remember what it was called, but it works very well.
How are the belts working this year? We used belts in 2003, and I know it slips real bad, but the belts are 6 years old now and the idler is stretched to the max.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
Unread 19-03-2008, 12:13
jax1488's Avatar
jax1488 jax1488 is offline
The Northern Chicken Wizards
AKA: jack stone
FRC #0522 (Robo Wizards)
jax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to alljax1488 is a name known to all
Send a message via AIM to jax1488 Send a message via MSN to jax1488 Send a message via Yahoo to jax1488
i would just like to ask, whats the pro's and con's of using 6 wheel drive, as against 4-wheel or treads(which are generally 2 wheel)?
"i dont like it, but i cant tell u why!" -"Dearrin"
2006 "aim high" national championship champions. (ty 296 and 217, NOTHERN CHICKEN WIZARDS... UNITE!)
2006 Greater Toronto Regional Chairman's Award
2004 N.Y.C. Regional Champion
2004 N.Y.C. GM Industrial Design
2004 N.Y.C. Daimler Chrysler Team Spirit
2003 N.Y.C. Regional Champion
Unread 19-03-2008, 12:28
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
6 wheel gives you the ability to turn on center. It also allows you to in general, turn better than 4WD robots (unless using omni's in some way).
When it comes to ramps and uneven surfaces, the middle wheel on a 6WD prevents the robot from bottoming out as well.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 19-03-2008, 12:45
jax1488's Avatar
AKA: jack stone
and im assuming the con factor is the extreme weight added on by all that chain?
also if using the 6 wheels on the same level configuration, wouldnt one have problems with traction, as well as weight if used omni wheels? if its a defensive game i.e. 06, wouldnt u get pushed around a lot?
Unread 19-03-2008, 12:49
AndyB's Avatar
AKA: Andy Burchardt
Well, MOST 6WD drive configurations lower the center wheel at least 1/8".
I don't understand your question about being pushed.
There is significant weight added. However, the bonus to that is that it is also lowering your CG. Omni wheels weigh just as much as regular wheels in most cases. You lose no traction. In fact, if using a grippy tread, like the KOP wheels or IFI nitrile tread, you gain a little traction.
Unread 19-03-2008, 12:53
RyanN's Avatar
RyanN
For two more wheels on our robot, it probably adds at most 3lbs. We only have 4 #25 chains on our drive train, which is probably only a pound once you add them all up. The only way someone can push you with 6WD is if they get in front of you and push you back against your motors, or if they get on a corner and push, but then all they do is turn you.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 19-03-2008, 12:55
jagman2882 jagman2882 is offline
former driver, now mentor
AKA: Cory Gramlich
FRC #1126 (SparX)
jagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura aboutjagman2882 has a spectacular aura about
Send a message via AIM to jagman2882
on the chain subject...i have seen a #25 chain break and it wasnt crappy chain either....IMO its worth it to spend a little more weight to get the #35 chain which you know will not break with the amount of force that is put on it....again thats just my personal opinion but 1126 used #25 from '03-'06 and then we had a severe failure in 06 that caused us to switch to #35
2003-2008 Match record 132-59-1
'04 Newton Division Champ, '06 Galileo Division Champ
'03, '04, '08 Buckeye Champs, '07 Finalist
'06 Finger Lakes Champs, '08 Finalists
'08 Buckeye Motorola Quality Award
'07 Buckeye General Motors Industrial Design Award
'05 Buckeye Radioshack Inovation in Control award, '06, '07 Finger Lakes Rockwell Automation Innovation in Control Award
Unread 19-03-2008, 12:56
jax1488's Avatar
AKA: jack stone
say a robot is to come and push against a corner, wouldnt you spin and not be able to push back, if u have omni wheels for front and back?
and for the 1/8th lowered, why would u only want 4 wheels on the floor at the same time? i wouldnt think that the weight added would be worth the extra 2 wheels if u dont use them. you lose traction for the wheels that arent on the ground, say someone bumps into u around that area, you would spin
im not bashing 6wd, im trying to find out pros and cons
Unread 19-03-2008, 12:57
Billfred's Avatar
Billfred Billfred is offline
Weight's never been an issue for us--neither of 1618's 6WDs have really broken 100 pounds. This year's robot weighed in around 78 pounds at Chesapeake, minus the forks we'd removed. That's all with #35 chain, and last year's robot was bolted together. A judicious application of #25 chain (or, if you're 125 this year, belts) and rivets could drive that down further.
Omniwheels don't have to weigh much either--compare the without-bearings weight of the 2007 kit wheel (0.75 pounds) and the AndyMark 6" plastic omniwheel (0.75 pounds).
I know there have been teams that have had defensive-oriented robots with omnis on the corners--488 last year comes to mind--but I'll yield to them since we've always run traction wheels in our 6WDs.
I'm still yielding on the omnis-on-corner discussion, but I'll bite on the other.
We actually use all six wheels on our 6WD, just not at the same time. Consider a robot that didn't have the front two wheels, with the other two left where they are. If you stop, the parts of the robot still doing 14 fps are going to want the robot to tip forward. Without those wheels, we're digging into the ground or rolling on some type of caster that affects how we turn (read: easily). The added weight is a non-zero amount--probably about a pound and a quarter or a pound and a half per side for us--but it's worth it in our determination.
As for traction, you're not really losing any. Granted, that particular wheel has zero traction with the floor if it's raised, but your four wheels in contact with the ground make up for it well enough to make up for it in most situations. Also consider that their front probably takes enough room to hit the middle wheel as well--unless they clip a corner and clip it well, you're still probably not turning.
And, since 6WD can enable easier turning, you can readjust quickly.
Unread 19-03-2008, 13:54
As with any good drive system that uses some form of drive like chain and sprocket/belt or whatever else, tension is key.
The fact that chain "stretches" was enough to make us consider using something else. Kevlar does not stretch, or at least, the stretch is minimal to the point that we dont need to adjust tension. This allowed for a very simple solution to tensioning, which was putting a piece of delrin, turned down to the proper diameter, placed over one of the standoffs already in place on the drivetrain. The results so far?? No skipping, slipping or sliding. I couldn't be happier with belts.
A LOT OF THOUGHT needs to be put into a drive system. You have to try and be adjustable for different situations, but you need to really commit to something from the start. I love how our drive train came out this year. If you have any more specific questions let me know.
1519 - One Dual-Config Robot or Two Robots? Ken Streeter General Forum 127 12-03-2008 15:26
What do you think about how easy theyre making programming? Leav Programming 76 11-01-2005 12:07
How does one become a ref? minic@HYPER69 General Forum 11 05-05-2004 01:08
How does one go about ordering more motors... Team852 General Forum 3 27-01-2003 14:37
How Do I Program My RC To Spot One wheel From Going faster than the other Kyle1010 Programming 5 12-01-2003 15:30
