Go to Post Mentors can never receive enough thanks from us students, who don't know even half of what they put into our teams. - Katie_UPS [more]
Unread 19-03-2008, 21:49
Aerex Aerex is offline
FRC #1369 (Minotaur)
Aerex is an unknown quantity at this point
Vex Light Sensor on FRC Bot
We tried to use a vex sensor onto our FRC robot to be used to count revolutions by counting a series of alternating black and white tape on a motor. However there is something wrong with my code.
#include "Main.h"
void Autonomous ( void )
      int c = 1;
      unsigned char light;
      int a = 0;
      int b = 0;
      int value = 0;
      while ( value <= 5 ) //the transition of White to Black five times
            SetPWM ( 10 , 190 ) ; //
            SetPWM ( 11 , 190 ) ;
            light = GetAnalogInput ( 1 ) ;
            if ( light >= 0 && light <= 99 ) //interval of white (Bright)
                  a = 1 ;
                  PrintToScreen ( "a: %d\n" , (int)a ) ;
                  PrintToScreen ( "Light: %d\n" , (int)light ) ;
            if ( light > 99 ) //interval of black (Dark)
                  b = 1 ;
            if ( a == 1 && b == 1 )
                  value++ ; //problem starts here
                  a =0 ;
                  b = 0 ;
      SetPWM ( 10 , 127 ) ;
      SetPWM ( 11 , 127 ) ;
At the incremental of the variable value the RC begins to count continously up to five at the first instance and then it stops. I want it to only increment the variable value one at a time so that I can see a smooth transition. I started to believe that the vex light sensor is not capable to be used for FRC. Anyone know the problem or should I just use at gear tooth sensor. I appreciate the response.
Light Sensor Filter dasmoenator Programming 2 21-11-2007 23:49
Moving bot once targeted on the light bronxbomber92 Programming 10 30-01-2007 12:33
Vex Light Sensor Robots_R_Us Technical Discussion 2 11-08-2006 18:24
Light Sensor Type, Please Help! Alexander McGee Electrical 7 20-11-2004 21:48
How do light sensor(Banner) work? roberthan Programming 9 25-02-2004 14:05
