Go to Post Take it from a team that mastered tank treads and still hasn't built them in over a decade - it's not worth it. - Isaac501 [more]
Unread 20-03-2008, 00:56
mr_yes mr_yes is offline
FRC #1248 (The TITANium Allies)
mr_yes has a spectacular aura aboutmr_yes has a spectacular aura about
Strategy: The robot checklist
One part of our strategy this year is to learn from the problems of last year (and the year before, and...) by having a checklist of things to make sure the robot is ready to go. I can think of a few things (mostly things we've had problems with) like:
  • check screws holding radio modem cable to modem and controller
  • replace main battery
  • replace backup battery
  • check tension on belts/chains
  • check drivetrain for loose bolts
  • circle the robot 3 times chanting "Hold Together, Hold Together"
Anyone care to add to this list?
Unread 20-03-2008, 00:58
fatjoe3833's Avatar
fatjoe3833 fatjoe3833 is offline
Your GP is showing!
AKA: Joe
FRC #0545 (Robodawgs)
fatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud offatjoe3833 has much to be proud of
Re: Strategy: The robot checklist
lube/WD-40 as needed
Unread 20-03-2008, 01:00
SU 39 SU 39 is offline
AKA: Andrew Su
FRC #0846 (Funky Monkeys)
SU 39 will become famous soon enoughSU 39 will become famous soon enough
In the second match of our semis at SVR, our robot went right crashing into another robot instead of our usual 4-5 lines in hybrid. Afterwards, we discovered that the PWM cable for the enconders came loose and detached.
Sooo I'd add to check all cable connections.
Lynbrook Robotics
Team 846
The Funky Monkeys
Vice-President 2007-2008
Driver 2007 - SVR: (6-2), 4th seeded, semi-finalists
LSR: (8-1), 1st seeded, semi-finalists
Driver 2008 - SVR: (5-2-3), 5th seeded, semi-finalists
Hawaii: (7-3), 6th seeded, semi-finalists
Unread 20-03-2008, 01:01
Blue_Mist's Avatar
Blue_Mist Blue_Mist is offline
will return to 766 soon!
AKA: Mika Lai
FRC #0766 (M-A Bears)
Blue_Mist is a jewel in the roughBlue_Mist is a jewel in the roughBlue_Mist is a jewel in the rough
After every match if possible, do a complete top-to-bottom check of everything, from drive train to extraneous decorations. We lost driving control for a couple of matches because we disregarded the loose tread on our wheels when we put it on, all the way back in Week 3. And tighten down those bumpers!
"There's no finer engineering than pit engineering." -kaszeta
"Show a girl how to use a wrench, and she'll put those skills to use for a lifetime. Hand it to her and tell her she's probably better off shopping, and she'll clonk you over the head with it, do your pneumatics system, and CAD the robot." -Amanda Morrison
'09
Unread 20-03-2008, 01:42
danshaffer's Avatar
danshaffer danshaffer is offline
Stanford 2012
AKA: if it quacks like a duck...
FRC #0008 (Paly Robotics)
danshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nicedanshaffer is just really nice
Robot on, make sure all victors light up and spin
Check for comm with field/OI
Pneumatics valve closed, charged
Remove safeties, cords, pins, etc
FRC8 Co-Captain 2007-2008
FRC8 Mentor 2008-present
CalGames Ref 2008, 2009
Stanford 2012, Computer Science
Unread 20-03-2008, 01:48
Stephi Rae's Avatar
Stephi Rae Stephi Rae is offline
Lets play robots!
AKA: Stephanie Morrison
FRC #5803 (Apex Robotics)
Stephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to beholdStephi Rae is a splendid one to behold
Send a message via AIM to Stephi Rae
Team 1983 has adopted a very similar approach this year. Everything you have looks very necessary, and very close to what we have done. We completely took the idea and ran with it. We have a 5 stage checklist that goes through multiple team members to get the ok for a match. Since we started fully using this system, we have almost eliminated pre-match problems of things being overlooked. It has proved very efficient for us. I believe our checklist is in the white papers section as part of our safety plan. I will double check, and edit if not, but I'm assuming it is there. => scratch that, the entire plan, for example how we use the checklist can be found in the white papers under the Skunkworks 1983 Safety and Health Plan, and the appendices, including the actual safety checklist (Appendix A) can be found on our website www.ahsrobotics.us.
Anyways, this has proved a very very good thing for our team this year.
~Stephanie Morrison (Hoag)~
Student - Team 1983 (2007-2008)
Mentor - Team 190 (2009-2012)
Mentor - Team 1983 (2013-2014)
Mentor - Team 1318 (2015)
Coach - Apex Robotics 5803 (2016-Present)
Last edited by Stephi Rae : 20-03-2008 at 02:05. Reason: where to find the checklist confirmed
Unread 20-03-2008, 06:45
Sunshine's Avatar
Sunshine Sunshine is offline
Mr. S
FRC #2062 (C.O.R.E)
Sunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to beholdSunshine is a splendid one to behold
Team 2062 has developed a very extensive checklist that we use similar to a preflight checklist before flying. We go over it every time the robot comes back into the pit. I'll see if I can get one of my students to share it here.
I know that they were planning on handing copies out at Atlanta to show people.
It's pretty cool.
C.O.R.E. Community Of Robotic Engineers
2015 Wisconsin Regional Champs, Safety Award
2015 Midwest Regional Champs, Safety Award, Industrial Controls Award
2014 Midwest Regional Judges Award
2013 Lake Superior Champs
2012 World Championship Safety Award, World Finalist for the Autodesk Award
2011 Wisconsin Regional - Website Award 10,000 Lakes - Innovation in Control, Safety Award
2010 World Championship - Archimedes Semi-Finalists -World Finalist for the Autodesk Award
2010 10,000 Lakes Regional Champs, Entrepreneurship Award; Wisconsin Regional- Entrepreneurship Award, Safety Award
2009 WI Regional- Quality Award, Safety Award 10,000 Lakes - Safety Award, Motorola Quality Award, Animation Award
2008 World Championship Safety Award
2008 Wisconsin Regional Champs, Safety Award
2008 St. Louis Regional Entrepreneurship Award, Safety Award, Website Award
2007 Wisconsin Regional All-Star Rookie Award
Unread 20-03-2008, 07:40
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Get the programmer there and make sure he uploads the most recent, most bug-free copy of the code with the correct autonomous mode.
My old teams have had blown matches because I had left testing code on the robot that was useful for debugging, but not for actually driving the thing.
Unread 20-03-2008, 07:45
James1902's Avatar
James1902 James1902 is offline
Chopsaw??
FRC #1902 (Exploding Bacon)
Team Role: Marketing
James1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond reputeJames1902 has a reputation beyond repute
Yeah, checklists are a very good idea. Definatly make sure to do a post match check as well. At the Florida regional this year we were in the quarter finals and after our first match we neglected to do a post match and check our drivetrain because we were fixing our flag holder. (it fell off the robot every match.) As a result we didnt notice our ceter wheel on our left side had sheared through the bolts hoding the sprocket on. So yes, it's always good to have pre match and post match checks.
-In case of major discrepancies it's reality that's got it wrong
-oink oink boooooooooooooooooooooooooom
-Iz it can b pig go boom time now plz?...kthanxbye!!
Unread 20-03-2008, 09:54
Elgin Clock's Avatar
FRC #0237 (Black Magic)
(After a match)
Check any known damage cause on field - check
Do a full systems check (including checking the drive system for loose bolts, and putting the robot in Home position) - check
Put battery on charge.
(Random programming tweaking)
(Right before we leave the pits for a match or while in queing area)
Tether up.
Put in new battery.
(With controls)
Drive forward - check.
Drive back - check.
Arm up - check
Arm down - check
Home it! (Return to starting configuration) - check.
(With remote)
Check remote operation - check
Check battery voltage at OI - check
Untether - check
(On field)
Place it where it needs to go / check field position - check
Power on - check
Plug in OI to field radio - check
Check disable button in players station / make sure it's deactivated* - check
Wait for match to start.
Good to go.
*Often overlooked, we've gotten our drivers into the habit of making sure the E-Stop button is fully operational and not in the Stop position (checking for a bad flashing beacon light on player's station) before the match starts
Unread 20-03-2008, 09:57
MegaSparks's Avatar
MegaSparks MegaSparks is offline
FRC #2062 (C.O.R.E.)
MegaSparks will become famous soon enoughMegaSparks will become famous soon enough
We keep the latest revision of the checklist up on Windchill. Does any other team use Windchill?
Unread 20-03-2008, 10:04
MegaSparks's Avatar
Smile Re: Strategy: The robot checklist
Attached is what we used at the Wisconsin regional. It looks like it will have things added before we go to Atlanta, but these items are very robot specific. Lets us know if this is any help.
Unread 02-04-2008, 12:38
Shadow503's Avatar
Shadow503 Shadow503 is offline
printf("\r\n Moo!");
Team Role: Human Player
Rookie Year: 1991
Shadow503 will become famous soon enoughShadow503 will become famous soon enough
I'd recommend turning the robot on, doing a complete controls diagnostic, and then checking the battery voltage.
Unread 02-04-2008, 21:14
Curt_Bagne's Avatar
Curt_Bagne Curt_Bagne is offline
FRC #0573 (Mech Warriors)
Team Role: Electrical
Curt_Bagne is an unknown quantity at this point
Send a message via AIM to Curt_Bagne
My team has a checklist that we go over before every match and I do a quick visual check on the field as I'm turning on the robot.
Some items that are often overlooked are the screws that hold the wires in the rockwell power distribution block and fuse blocks.
Make sure that the wires are tightly connected to the battery. We used to have a problem with people lifting batteries by the cables and causing the connections to come loose. The robot was disabled for an entire match because one of the battery leads came undone within the first 10 seconds. Learn from our mistakes, being disabled by a simple battery problem is very embarrassing.
Curt Bagne, driver and electronics leader
Team 573
2007 GLR Champions
2008 Pittsburgh semifinalists
2008 GLR quarterfinalists
Unread 03-04-2008, 12:37
Bongle's Avatar
Oh, something I forgot:
It is of extreme importance that you not only have items in your checklist, but ASSIGN THEM TO PEOPLE. People will work harder to make sure something gets done if any failure of that system has their name written on it.
Robot Size- R11 vs. Inspection Checklist Toby314 Rules/Strategy 4 07-01-2008 10:09
Robot Inspection Checklist ChuckDickerson Technical Discussion 2 16-02-2006 21:30
Driver Skill v. The Robot v. Strategy tenfour General Forum 14 25-03-2003 21:59
Have you seen the Inspection Checklist? Matthew_H General Forum 20 23-02-2003 19:55
Kamikaze Robot Strategy... Joe Johnson Rules/Strategy 30 07-04-2002 21:42
