Go to Post FIRST is a big family and we‘ll get through this together. - Gary Dillard [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
Unread 19-03-2008, 20:58
Maxrobo's Avatar
Maxrobo Maxrobo is offline
Enter into unknown computer program
AKA: Major Coffee
FRC #2343 (Decipticons)
Maxrobo is an unknown quantity at this point
Flag holder
Now the flag holder that we have to put on our robot what are the rules cause the ones they gave us are in to much of a gray area.
Don't be ashamed of it just try harder next year!!
Unread 19-03-2008, 22:01
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Flag holder
<R17> seems quite self-explanatory, except that 1/2” (nominal) Schedule 40 PVC doesn't have any dimension that is 1/2". Is there something in particular that is confusing you?
(since 2004)
Unread 19-03-2008, 22:45
bigbeezy's Avatar
bigbeezy bigbeezy is offline
AKA: Bryan
FRC #2338 (Gear it Forward)
bigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to beholdbigbeezy is a splendid one to behold
Send a message via AIM to bigbeezy
Re: Flag holder
i believe its 12" of 1/2" Inner Diameter Sch 40 PVC w/ the top of the flag holder at 51" above the floor. how you get it up to that height is up to you. o and you cannot alter the PVC (i.e. drilling weight holes). that is really the only specs on it.
Team 1592 Bionic Tigers -- Driver 2005-2008
Winner - Florida Regional 2005
Finalist - Newton Division 2007
Winner - Colorado Regional 2008
Florida State University - BS Mechanical Engineering
Team 2338 Gear it Forward -- Mentor/Drive Coach 2013-Present
Winner - Wisconsin Regional 2013
Chairman's Award - Midwest Regional 2015
Winner - Archimedes Sub-Division 2015
Chairman's Award - Midwest Regional 2016
Unread 20-03-2008, 00:50
Cow Bell Solo's Avatar
Cow Bell Solo Cow Bell Solo is offline
No Stolte No
AKA: Chris
FRC #2194 (Fondy Fire)
Cow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the roughCow Bell Solo is a jewel in the rough
Send a message via AIM to Cow Bell Solo Send a message via MSN to Cow Bell Solo Send a message via Yahoo to Cow Bell Solo
Re: Flag holder
You can if it is to attach it though that is okay, but no drilling for weight.
Also when you are at inspection they will tell you if it is okay or not. Just if it is not either be prepared to change it or have extra PVC to put on.
Who let the Blue Smoke Out
Team 2194 Mentor - 2012-Present - http://fondyfire.com
Team 2207 Alumni - http://whitebearlakerobotics.com
Iowa FIRST LEGO League Planning Team Member - 2010-Present - http://www.isek.iastate.edu/fll
FIRST LEGO League volunteer - 2008-Present
2008: MN Regional Quarterfinalists, Website Excellence
2009: MN North Star Quarterfinalists, recognized for safety, Website Excellence
Unread 20-03-2008, 08:01
Re: Flag holder
<R17> ROBOTS must use one of the two FLAGS provided at the event
queuing location to display their ALLIANCE color (red or blue). The
FLAG shall be held in a flag holder mounted on the ROBOT. The
only acceptable flag holder is a 12 inch long piece of 1/2” (nominal)
Schedule 40 PVC tube. The tube must be a single, contiguous
piece, capped with a commercial PVC pipe cap cemented at the
bottom end.
Please note that the flag holder must be 12" long, Schedule 40 with a pipe cap whose top end is 51" above the floor +/- 1". Mounting holes are acceptable but are under the scrutiny of the Robot Inspector. Further, the flagholder must allow for a two inch radius of at least 180 degrees for the lap indicator to be visible from above. The lap indicator does move a bit during robot operation. The rule this year is specific and does not provide for deviation in design.
Unread 20-03-2008, 10:56
Rosiebotboss's Avatar
Rosiebotboss Rosiebotboss is offline
2015-16 Divisional LRI - Archimedes
AKA: Dana P. Henry
FRC #0839 (Rosie Robotics)
Rosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond reputeRosiebotboss has a reputation beyond repute
Send a message via AIM to Rosiebotboss
Re: Flag holder
bottom end.
If I can add my $.02. 1/2" Sch 40 pvc has an ID of 3/8", NOT an ID of 1/2". (It's a construction thing.) Make sure the printed labeling on the side of the sch 40 says 1/2 inch.
As far as mounting, 2 hose clamps work well wrapped around a piece off 1" x 1" alum angle thats bolted to a structural member.
Co-Founder/Mentor FRC Team 839 / JrFLL Team 137/Rosie Robotics/Agawam HS
Winner NEF District WPI 2016
Regional CA-08 Boston, 12 WPI, Eng'g Excellence, 12-15 UL Safety, 15 Motorola Quality
KPCB Entrepreneurship 04, 05, 06, 07, 10, 11, 13, 14, 15, 16
Rookie All Star and Top Rookie Seed 2002
Paul Harris Fellow, CMP Inspector 05-16, Head LRI NE FIRST JTB 1944-2008 "What did you do with your dash?"
Unread 20-03-2008, 12:26
GaryVoshol's Avatar
Cogito ergo arbitro
Re: Flag holder
See this on Nominal Pipe Size: http://en.wikipedia.org/wiki/Nominal_Pipe_Size
Another source http://www.harvel.com/pipepvc-sch40-80-dim.asp says that the dimensions are .84" od and .6" id.
The key thing to remember is that on a 1/2" nominal schedule 40 PVC, there will be no measurement of .500 inches.
Although the rules say that you may use holes for mounting, you can't put a connector through the interior of the tube. This is because the flag pole itself is wrapped in tape to keep it in place better.
(since 2004)
Unread 20-03-2008, 13:29
Re: Flag holder
Actually the flag shaft has a piece of rubber tubing over it extending from below the rubber stopper to the bottom of the flag. Object of this addition is to prevent vibration from loosening the flag stopper.
Unread 20-03-2008, 17:16
Mark Pendergast Mark Pendergast is offline
FRC #1760 (Robo-Titans)
Mark Pendergast will become famous soon enoughMark Pendergast will become famous soon enough
Re: Flag holder
A good best practice is to ensure the flag will not be destroyed by your robot mechanism. Our flag holder looked great, but when we added the flag and got in the heat of battle, we munched the flag .
Next year we will probably have a flag 'stand-in' when we test the robot.
Unread 20-03-2008, 22:18
bigbeezy's Avatar
AKA: Bryan
Re: Flag holder
we actually had an actual flag from some off season even or (i doubt it but maybe) Atlanta. However we seemed to have lost it when we actually needed it to make our flag holder.
When we designed for the flag we drew it 2D on paper as well as modeled it in Inventor so we could see if it would be affected by our arm. you really dont need a perfect model of your robot to do this. you could make simple boxes that represent your robot and move them through their motions to see if anything will hit your flag. if so then you need to find a new place for it.
Unread 23-03-2008, 14:46
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: Flag holder
bring spare pvc. thats all you need to know.
Flag, Flag Holder vs Trackballs Swampdude Rules/Strategy 29 09-03-2008 09:17
Flag Holder (?) Spiders Technical Discussion 8 24-02-2008 16:48
Flag Holder Mounts RoboGeek99 General Forum 10 17-02-2008 19:32
Flag Holder info Magnechu Kit & Additional Hardware 4 13-02-2008 19:08
Flag holder caps. General Thunder Rules/Strategy 10 28-03-2007 15:00
