Go to Post They just kind of sit there chilling, like "Hey I'm a trailer, where's my robot?" - artdutra04 [more]
Unread 21-03-2008, 04:27
holty531 holty531 is offline
FRC #2441
Team Role: Electrical
holty531 is an unknown quantity at this point
Battery charge speed
hi, we have the 12v batteries and the speed charger that came with the kit of parts. the charger can go on 2, 4, and 6 amp charge speeds. What is the best speed to use? or does it not matter?
Unread 21-03-2008, 06:23
Jimmy Nichols's Avatar
Jimmy Nichols Jimmy Nichols is offline
Mentor,QCR Planning
FRC #1038 (The Thunderhawks)
Jimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond reputeJimmy Nichols has a reputation beyond repute
Send a message via Yahoo to Jimmy Nichols
Re: Battery charge speed
You want to use the 6 AMP setting.
Jimmy - Lead Mentor, Pit Boss, Miami Valley FRC Regional Planning Committee
Lakota Robotics - FRC Team 1038
2013 - Crossroads Team Spirit,Quarter-Finalists - Queen City WFFA - Paul George,Quarter-Finalists - Ohio FRC State Championship Champions
2012 - Queen City Volunteer of the Year,Team Spirit,Finalists - Smoky Mountains Engineering Inspiration,Quarterfinalists
2011 - Pittsburgh Semifinalists - Buckeye Engineering Excellence Award,Coopertition Award,SemiFinalists
2010 - Pittsburgh Judge’s Award,Quarterfinalists - Buckeye Industrial Design Award,Finalists - IRI Mentor Round Champions
2009 - Buckeye GM Industrial Design,Champions
2008 - Midwest Engineering Inspiration,Quarterfinalist - IRI Semifinalist
2007 - Pittsburgh Motorola Quality,Finalist - Buckeye Rockwell Automation Innovative Controls,Finalist - Championship Newton Quarterfinalist
Unread 21-03-2008, 07:44
The manufacturer specifies the KOP battery to be charged at no more than 6 amps. This will normally charge a depleted battery in under two hours. Don't forget to check that the charger is set in the 12 volt position.
Unread 21-03-2008, 09:13
Billfred's Avatar
Billfred Billfred is offline
And, just as important, check the charge settings each time you plug in a battery. We've noticed that ours resets to 2A each time. (My solution was to take the label maker and put arrows pointing to the relevant LEDs and a warning on the battery connector. It usually does the job.)
Unread 21-03-2008, 18:02
AKA: Dr. Brooks
no team (WRRF)
If you are charging the battery at a competition, you should swap the
battery every match and use the 6 amp setting.
If you are charging the battery overnight, and in particular if the
battery is significantly discharged, use the 2 amp setting. This
will minimize the damage that high charge currents will do to the
battery.
Eugene
how long does it take to charge the 7.2V backup battery? Nappster16 Electrical 1 17-02-2007 16:33
Charge Ahead!!! RoboMadi Team Organization 7 13-08-2006 08:38
Permanent Static Charge... Melancholy Chit-Chat 10 28-11-2002 16:26
depth charge Greg Perkins Televised Robotics 0 11-09-2002 16:15
Battery weight vs. Charge Chris Tremblay Electrical 12 10-04-2002 11:20
