Go to Post FIRST has a funny way of connecting people... - Jaine Perotti [more]
Unread 09-03-2008, 21:01
copperhead47's Avatar
copperhead47 copperhead47 is offline
AKA: Grant "gunner" T.
FRC #1647 (Lenape Regional Iron Devils)
Team Role: Electrical
copperhead47 is an unknown quantity at this point
Send a message via AIM to copperhead47
Re: 1726 Electric Problem
I dont know if somebodys already posted this scenario, b/c i didnt bother to read all posts. your issue could in fact be that you are loading your drive motors too high- we at team 1647 from new jersey have had the same problem and we had the same assumptions (one of the questions i would like to ask is what kind of drive system are you using?) we used the omni drive setup where we have 2 sets of wheels on perpindicular axis to each other- one CIM to a transmission (4 trannys) and the gearing and the diameter of the wheels were factors in overloading on the amperage needed. we solved the problem by creating a whole new drive system that we are goin to swap out at the philadelphia regional. what i would suggest instead of such a darastic change that we did would be to change the gearing inside the tranny or change out to a different brand tranny if thats possible- or maybe find a more powerful matter of CIM. (that can still handle the 40 amp breakers- which may not be possible) other than that... i cant tell you anything else. basically we solved our problem by keeping the same number of motors but dropping trannys by 2 and shifting drive to one axis instead of 2 and shifting to a more tacky wheel for defense... aight thats all i ahve to say... oops i wrote alot sry!
Unread 09-03-2008, 21:18
Jim,
There is one other possibility but you are not going to like it. On rare occassions, the screws that hold the 40 amp Maxi block together come loose. They can only be accessed from the bottom side of the block. If they loosen up, the contact between the input and output terminals of the breakers do not make good contact. If you remove the cover and then pull all of the 40 amp breakers, try moving each of the contacts. If they move, the screws underneath have come loose. I am betting you are going to find a loose wire on the input to the block or on the Rockwell block. Let us know what you find.
Unread 09-03-2008, 21:59
Matt H. Matt H. is offline
Long Distance Mentor
FRC #1726 (N.E.R.D.S.)
Matt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond reputeMatt H. has a reputation beyond repute
Thank you all for the advice, I don't believe that the problem is a loose connection as we checked and double checked all of the connections frantically on Saturday and were unable to find anything loose. We also redid the majority of connections examining the wiring for signs of damage.
We did not however fold over the wiring in the maxi fuse block, of check to see if the screws were loose.
Unread 09-03-2008, 22:23
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Originally Posted by Vikesrock View Post
If it is just the victors that are losing power, one thing I would make sure to check is the Rockwell Distribution block. If the wire to the maxi panel comes out of a different block than the wire coming in from the main breaker, check and recheck the jumper block. That yellow block can cause all sorts of issues if not seated well and tightened down properly (my team had this issue this year).
We had this same problem. The robot would flicker on and off as we drove. The main wire going into the distribution block was the culprit. It had come loose and would lose contact when bumped . A very quick fix by screwing it back in.
It was very sad when I saw you guys just sitting there. I honestly think you guys would have won Arizona. 1726 is one of my favorite teams this year. Viva las launchers
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 13-03-2008, 12:11
Ken Streeter's Avatar
Ken Streeter Ken Streeter is offline
Let the MAYHEM begin!
FRC #1519 (Mechanical Mayhem)
Ken Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond reputeKen Streeter has a reputation beyond repute
Originally Posted by Qbranch View Post
Originally Posted by Tapoore View Post
Funny story: this year, our hurdle bot weighed only 87 lbs when we got to the competition. We decided to add some weight to get it closer to 120lbs using a couple of dumbbells. We figured that the easiest way to "secure" them would be to use zipties. We put two dumbbells in the front and one in the back near to our electronics board. During our final qualification match, we slammed into the alliance wall pretty fast and the dumbbell came loose and unplugged all of our motor connections! Ooops...
As a quick aside:
Have you tried running your robot without the extra weight? Since there isn't as much defense this year, you may gain critical extra performance from your robot's drive system.
We ran our hurdling configuration all day on Thursday and Friday without the extra weight. (In hopes that our other configuration could be added on Saturday if we received permission to do so from the GDC.) We found that our robot was a little tippy in a situation we hadn't anticipated -- when carrying a trackball and then bumping up sideways against a trackball which was wedged against the side wall, the two trackballs would smoosh together, storing up energy which would then rebound and flip our robot over onto its side. Amazingly, this happened not just once, but twice in qualifying rounds while driving around the field with a trackball while the arm (and the trackball) where in the "stowed" position!)
Ken Streeter - Team 1519 - Mechanical Mayhem (Milford Area Youth Homeschoolers Enriching Minds)
2015 NE District Winners with 195 & 2067, 125 & 1786, 230 & 4908, and 95 & 1307
2013 World Finalists & Archimedes Division Winners with 33 & 469
2013 & 2012 North Carolina Regional Winners with teams 435 & 4828 and 1311 & 2642
2011, 2010, 2006 Granite State Regional Winners with teams 175 & 176, 1073 & 1058, and 1276 & 133
Team 1519 Video Gallery - including Chairman's Video, and the infamous "Speed Racer!"
Unread 13-03-2008, 22:31
dpc131's Avatar
dpc131 dpc131 is offline
AKA: Dan
FRC #0836 (Robobees)
dpc131 is a jewel in the roughdpc131 is a jewel in the roughdpc131 is a jewel in the rough
I'm not going to be a big help here, but during semifinals last year, we had a similiar problem. The left motor of our drive system cut out during the first 15 secs. of the tele-operated period. We frantically tried to figure out what was wrong. We tethered and everything worked fine. During our second match the exact same thing happened with the same duration. The IFI guys ensured us it was not a field fault. We hadn't made any program changes for both regionals we went to and still have never been able to duplicate the fault outside the field.
Anyway, I would also take a look at the backup battery charge and connection, we have had issues with large current draws dropping the RC voltage just for a fraction of a second and resetting itself if the backup battery is low or not connected well. Sometimes the terminals in the molex connector can get loose. Just a thought
Dan Cell
Systems Eng. Mentor
Team 836 - The Robobee's
Unread 20-03-2008, 22:46
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
We found the problem pretty quickly this morning,the screw that holds the 6 gage feed wire into the Maxi fuse block was loose, so we put in a new wire (stripped a bit longer) and tightened all the connections on it and the Rockwell block, and it worked fine all day.
Thanks for all the help!
Unread 20-03-2008, 23:05
Jim,
I hate to say it but... This is a great photo of the damage done by loose wires and high current. Note the melted copper on one or two of the strands. This is why I recommend folding over the #6 before insertion (see my earlier post). It then fills the hole in the block and makes the screw a more effective clamp.
Jim, may I use this photo in my electrical presentation for the Championship?
Unread 20-03-2008, 23:16
MrForbes's Avatar
AKA: Jim
Yes, you're certainly welcome to use the picture! We'll discuss putting in a longer wire with the end folded over, I just forgot to reread this thread last night...oops!
I would take a bigger close up picture of the wire, but it's pretty well mangled after being in my pocket all day and showing it off to people here
Also, the screw was discolored from the heat, we swapped it with an undamaged one.
Unread 20-03-2008, 23:30
RyanN's Avatar
RyanN RyanN is offline
RyanN
AKA: Ryan Nazaretian
FRC #4901 (Garnet Squadron)
I must agree with Al on this... it's a great photo of what can happen with a bad connection. Although I've never had an issue with it, I will tell our electrical team to fold over the wire upon pushing it into the maxi-fuse block. I've done this before with other connections, but I've always considered it trashy to do this, so I've never done this with our 6AWG wire. I've done it before with the small muffin fan wires to the little red ring connectors when they were just too big, then they kept on pulling out, so I soldered the wires one, and haven't had too much trouble since then. I'm not at all surprised that the copper melted with so much of a load at such a weak point. I'm sorry this happened to you, but take it as a learning experience that I'm sure you'll never forget, and will make sure that next year this will not happen.
For preventative maintenance, at the beginning of any regional/championship, and before the finals, I reinspect my electrical and make sure everything is all tight, nothing is chaffed, and that nothing in my control will go wrong.
Some preventative measures I have taken with our robot:
All PWM cables are held in with a small dab of hot glue. Hot glue works well for this, and easily comes off if I want it to. All the PWM wires that go to the controller are also hot glued in place.
Solder fan wires, and solder in the 40AMP ring connectors to the wire. (Unfortunately I didn't do this this year, but I still may, but it will have to be with lead free solder. I have never soldered with lead free solder before, so hopefully it won't be a bad experience)
Label EVERYTHING!!! It makes fixing something so much easier. Every victor, spike, circuit breaker, pwm cable, etc... is labeled.
Al, this is a question for you... I placed a label on top of our circuit breakers since the BUSS fuse block is hard to label. I did put a label on the long ways that says that all circuit breakers are 20AMP's... will an inspector ask me to verify that all breakers are 20AMP's? Should I put some temporary circuit breakers in for inspection? Is this fine? I don't remember anything in the rules about being able to read all the circuit breakers. <R50> states that "Circuit breakers must be accessible for inspection at each FIRST Robotics Competition
event." The breakers are accessible by opening our hood, and an inspector can easily see that these are the snap action breakers by the shape and the colors of the legs of the breakers. Will they take my word that they are all 20AMP, not that they all are required to be 20AMP, just the RC, and 3 spikes. Since you're an inspector, I wanted your input on this.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Previous mentor and student from Team Fusion, FRC 364
DonRotolo's Avatar
Back to humble
FRC #0832
Think about the heat required to melt copper - those 'pearls' on the end of some strands were formed by heat.
That heat came not form contact resistance, but from arcing. An arc is electricity forming a plasma, reaching temperatures of several thousand degrees (often around 10k) in a split second. This is how many home fires start, because the plasma is not a dead short (which would trip a breaker) but a 'high resistance short' usually permitting around 15-18 Amps at 12 VDC. For homes, you can now buy an "arc-fault' circuit breaker, which detects the characteristic high-frequencies of an arc and cuts the power.
Glad the robot didn't catch fire.
Don
Unread 20-03-2008, 23:59
I'm not Al, and I don't play him on TV, but I'm going to chime in here and say that labeling the breakers doesn't seem very helpful to me. It's the position on the breaker panel that determines what device gets the power, and any given breaker is easily moved from one slot to another regardless of how it's labeled. If you pull two breakers, the labels don't help you put them back in the same place they came from, and you can thus lose track of which breaker slot is associated with what circuit.
I updated our electrical tracking spreadsheet this year to produce a worksheet full of wire and component labels that we printed on sticker paper and cut out. One part of the sheet is sized to fit in the recessed line between the rows of breakers, and it labels each of the twelve breaker slots. One slot's label is 0.6" wide and 0.25" high, enough for a short line of easily-read text or two lines of tiny but still readable letters.
Unread 21-03-2008, 00:05
RyanN's Avatar
RyanN
I see your point... I think I will make a spreadsheet with all the breakers and label them by using the spreadsheet. I was anticipating that we would not need to take more than one breaker out at a time, but it could happen, and I do see where an inspector may ask about the breakers. Hopefully the electrical tape used to keep the labels on didn't break down and become gooey.
Garnet Squadron
FRC 4901
Controls Mentor
@rnazaretian
Unread 21-03-2008, 07:34
Ryan,
A good inspector needs to follow a certain size breaker to a certain size wire. 20 amps can be 18 AWG and so on for the larger breakers. So the answer is yes, they need to see the rating on the top. We mark everything with a 3M EIA (10 color smae as resistor color codes) marking tape. It comes in a convenient size dispenser with tape that is only 3/16 wide. It is a little pricey at $30 but worth every penny when looking for a problem.
The position on the breaker panel is marked with a color relating to a particular load. The breaker has the same color as does the wire(s) leading to the Victor or Spike and so also the wire leading from the Victor or Spike to the load. We also mark the Victor fan or the top of the Spike and the device it is controlling. Finally, we mark the RC output and the PWM cable with the same color. That way if the RED motor is not running we look to see if the RED fan on a Victor is not turning, then we look to see if the red breaker is in place at the RED position on the breaker panel. If The RED Victor fan is turning we then check to see if the RED PWM is inserted at both ends. All of this can be accomplished without referrring to documentation. Even the chassis is marked for our drive motors and steering motors. Likewise the pneumatic cylinders and the valves. We can even figure out problems on past robots without docs. Thanks to a former Motorola engineer who I shared electrical with many years ago, Steve Tine, we have been using his idea ever since.
BTW, we also produce a spreadsheet (in color) that lists all of this info for all devices including sensors, motors and valves so that software, hardware and electrical sub teams are all "on the same page".
Unread 21-03-2008, 09:47
SteveJanesch SteveJanesch is offline
hopes he has enough oomph
FRC #1533 (Triple Strange)
SteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to beholdSteveJanesch is a splendid one to behold
Going a little off-topic, here....
At my insistence this year, 1533 copied Al's method of marking devices, wire ends, and PWM cable ends with color-coded tape. I cheaped-out and found a set of small rolls with five colors (plus we had black) at the local Home Depot, but that gave enough color combinations to give everything unique markings. This really saved us when we had to strip the robot down to the chassis and wheels on Thursday at Peachtree to rebuild the transmissions (which we'll have to do again at Champs, darn it). Everything went back together smoothly, quickly and properly.
Thanks, Al. Thank you, thank you, thank you.
One thing where we may have differed was combine colors for similar functions. We have two CIMs in AM Supershifters on each side. The right side motors are blue and white, the left side are red and yellow (single colors), and their Victors are each marked with a single color. The PWM cables and shaft encoders are then colored blue+white and red+yellow for the two sides, and the shifter servo cables are similar. When the shifter cables are connected together in a Y-cable, the single end becomes blue+white+yellow+red.
- Steve (thanks again, Al)
Overall electric help Aces Electrical 6 12-01-2007 20:16
Electric Bicycle RudimentaryPeni Chit-Chat 6 05-10-2006 14:24
Electric Solenoids BerserkerSpyke Rules/Strategy 3 01-02-2006 17:36
Electric Solenoid ThomasP Motors 5 10-01-2006 16:47
Gas or Electric?? Clark Gilbert Chit-Chat 14 11-08-2001 12:16
