Go to Post The GDC made something easier??? Link or it didn't happen! - JesseK [more]
Unread 21-03-2008, 19:26
DonRotolo's Avatar
Back to humble
FRC #0832
Re: DC Motor and Gearing
Yes, gear ratios add like you stated.
WRONG - Gear radios multiply. Oops.
You can use the last 40 tooth gear for the output, or another one of the same size (but why?) for 1:1 if you like.
The peak current from a battery may surprise you, but I^2R losses in the wiring will keep that peak current well below the theoretical 92 Amps. The 12 volt lead-acid battery FIRST uses can deliver 720 Amps for 3 seconds... So a small lead-acid will run your starter no problem.
Don
Motor Gearing Help!!!! Bee-k Motors 3 20-01-2006 03:39
pic: Wheels and gearing Wayne C. Robot Showcase 20 06-02-2005 17:54
Gearing/motor questions. Josh Siegel Motors 8 25-01-2005 09:49
link: 1014 guts and gearing Skillz Robot Showcase 2 24-02-2004 13:24
Chiaphua gearing (Chippy and Bosch) honky Motors 3 31-01-2002 10:28
