Go to Post "Pimp my shopping cart"?!?! - dlavery [more]
Unread 21-03-2008, 20:03
Aerex Aerex is offline
FRC #1369 (Minotaur)
Aerex is an unknown quantity at this point
Re: Gyro Rate
Regarding this topic I have a similar questions about the gyo
1.) If the gryo's results give a 10 bit value would 1024 represent a 360 degree angle.
2.) Can I take the assumption that the gryoscope uses flat plane of x and y coordinates.
3.) When you start the robot is the value initialized at 0 or at some angle that it captures
a.) if you were to turn a robot backwards would the values be the opposite value (ie. 25 to -25)
Myspace/Facebook + Academics = NoobsHelp.com
Gyro ADXRS150 rate out hinewwiner Programming 2 17-02-2008 11:24
Yaw Rate Gyro Problems RetroKamikaze Programming 3 27-01-2006 20:55
ADXRS150 gyro yaw rate sensor Brian M. Electrical 13 17-10-2004 02:28
ADXRS300EB Rate Gyro rmeenaks Electrical 18 05-04-2004 22:37
ADXRS300EB Rate Gyro rmeenaks Technical Discussion 0 31-03-2004 16:48
