Go to Post It takes a special kind of lunatic to be the school sponsor/mentor for an FRC team; when you get one be thankful. - Fusion_Clint [more]
Unread 21-03-2008, 21:21
Joe G.'s Avatar
Joe G. Joe G. is offline
AKA: Josepher
no team (Formerly 1687, 5400)
Bizarre EasyC vex problem -- perpetual autonomous
I am trying to program our bridge battle vex robot. However, I am having a bizarre problem with the switch from autonomous to operator control. Using the 2006/2007 FTC template provided with easyC, the robot will run autonomous as normal, as soon as the controller is on and it recieves a signal from the transmitter. After 20 seconds, it will stop autonomous and pause for a fraction of a second, as usual. However, it then turns on the Rx1 light, while running autonomous again, which then runs perpetually, while not responding to any commands from the controller. It works fine with the default code, and this problem happens with code from past robots using the same template file. Does anyone have any suggestions on how to solve this?
Unread 21-03-2008, 21:32
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: Bizarre EasyC vex problem -- perpetual autonomous
We solved some problems like this at the NJ and PA regionals by reloading the correct master code (the .BIN) file. There is a different one for MPLABs and Easy-C.
Unread 21-03-2008, 21:49
Francis-134's Avatar
Francis-134 Francis-134 is offline
Lifer
FRC #0190 (Gompei and the Herd)
Francis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond reputeFrancis-134 has a reputation beyond repute
The way you are describing this, it definatly soudns like a master code problem. You should download (or redownload) the lastest version of the Vex master code. To do this in easyC, go to the terminal window, click on options, then download master code. Select yes, then navigate to the most recent version of the code (the highest version number is the most recent).
Email | Twitter | Facebook | YouTube | Twitch
iTunes Podcast | Snapchat
A proud alumnus of teams 134 and 40 || Mentor of Team 190 || Director of Fun for BattleCry@WPI
Unread 22-03-2008, 07:54
Joe G.'s Avatar
AKA: Josepher
Working now, thanks guys.
That perpetual machine on the tubes neutrino15 Chit-Chat 3 10-02-2008 14:46
EasyC/IR problems in Autonomous cardinalman86 Programming 2 22-01-2008 15:50
Problem with easyC download link whytheheckme Programming 1 11-01-2008 23:34
EasyC Downloading Problem Jimmy_Team7011 Programming 1 15-11-2007 10:21
EasyC autonomous modes TubaMorg Programming 25 12-04-2006 22:53
