Go to Post I love the dedication of Robotics kids. :) - Danielle H [more]
Unread 21-03-2008, 18:06
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
Smile my first time programming
i want to practice programming so next year i can program our robot for frc competition. does anyone know a website where i can learn all of the features to program the onboard controller myself?
Unread 21-03-2008, 18:09
Re: my first time programming
There's tons of stuff right here on CD to help with programming.
http://www.chiefdelphi.com/media/search/results/82519
If you need any other help just PM
Unread 21-03-2008, 18:19
whytheheckme's Avatar
whytheheckme whytheheckme is offline
AKA: Jacob Komar
whytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond reputewhytheheckme has a reputation beyond repute
Send a message via ICQ to whytheheckme Send a message via AIM to whytheheckme Send a message via MSN to whytheheckme Send a message via Yahoo to whytheheckme
Or post here! We'd be glad to help!
Welcome to Chief Delphi. We hope you enjoy your stay.
Jacob
Unread 21-03-2008, 18:38
Abrakadabra Abrakadabra is offline
Here We Go !!!
AKA: Scott Kukshtel, Mr. K
FRC #3467 (The Windham Windup!)
Abrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant futureAbrakadabra has a brilliant future
Be forewarned that programming next year's robot controller is likely to be a very different experience from years past, as FIRST is moving to an entirely new system. The details have not been released, but there are several rumors floating around here on CD. Word is that we will get the details no later than the Championships in Atlanta next month, so stay tuned!
However, it's never a bad idea to learn C (and maybe C++), as it is still widely used in business and industry, and the knowledge will serve you well next year and into the future.
Good luck!
Unread 21-03-2008, 18:50
popnbrown's Avatar
popnbrown popnbrown is offline
FIRST 5125 HOTH Lead Mentor
AKA: Sravan S
FRC #5125 (Hawks on the Horizon)
popnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond reputepopnbrown has a reputation beyond repute
Robot programming is not that hard as a matter of fact, Kevin Watson and all those who have made libraries, have made it very easy to program. You should learn some basic C and then code a very simple program.
The main thing that you will need to get used to is where to place your code within the numerous files Kevin Watson and others have written.
First place to start is to get acquainted with C. Many tutorials online or else go to B&N and sit there for an hour or two and read the book or simply buy a book.
Anyother help PM me.
I am an employee of FIRST. However, the postings on this site are of my own perspective as a FIRST mentor and volunteer and do not necessarily reflect the views of FIRST.
FIRST Team 5125 Hawks on the Horizon Lead Mentor
FRC Team 4096 Ctrl-Z Former Mentor
FTC Team 5203 #19@! Former Mentor
FRC Team 1403 Cougar Robotics Alumni
Unread 21-03-2008, 19:09
ok. is c++ used on websites also? because if it is then i know very little becasue i customized my myspace by cut and paste and trial and error. and if i make just a program to run autonomous will it affect the joystick controllers or do i have to program them to? just a little update- i just got back from our first competition day. we are 11th place with a good chance of making top 5 maybe!
Unread 21-03-2008, 19:13
AKA: Jacob Komar
HTML, javscript and XML are typically used on webpages. MySpace modding is generally HTML and javascript. This is absolutely nothing like C or C++.
If you have the time, I'd recommend trying a simpler language, like BASIC, just to get the feel of a program flow. Then you can start on C, and maybe eventually C++
My 2 cents,
Jacob
P.S. I'd be glad to help you with any of this.
Unread 21-03-2008, 19:16
My 2 cents,
Jacob
Another thing i would like to ask is do you know how to program the robot controller to read the pressure switch to the pneumatic system? i've done all of the pneumatics but its not good for inspections... they let us pass because it works good but they recommend that we use the robot controller.
Unread 21-03-2008, 19:32
AKA: Jacob Komar
I'm REALLY surprised they let you pass inspection.
If you want to get started writing a simple program, fire up easyC. In the initialize block, you can put in the pressure switch (found under Outputs). This will take care of everything for you.
Jacob
Unread 21-03-2008, 19:46
Have you gone to your competiton yet? if so, how are you guys doing?
Unread 21-03-2008, 20:34
popnbrown's Avatar
AKA: Sravan S
Second Jacob's idea, try using EasyC.
Other than that what are you using right now to program the robot?
I'm using Kevin Watson's code.
Thing about the Pressure Switch, is that whenever the Pressure gets ablve a certain point it sends a signal out to the RC (there should be a connection between the Pressure Switch and the RC). What you do is you check and see if this signal is on (usually a 1) or off (a 0). When its on you will want to turn off the compressor.
The pressure switch is a digital input and the compressor is a relay output.
Figure out which port number for your compressor and pressure switch.
Then using Kevin Watson's code, where XX stands for your port number
relayXX_fwd = !rc_dig_inXX;
relayXX_rev = 0;
Hope that helps!
Sravan
Unread 21-03-2008, 20:47
basicxman basicxman is offline
Emily Horsman
FRC #2200 (MMRambotics)
basicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant futurebasicxman has a brilliant future
Send a message via AIM to basicxman Send a message via MSN to basicxman Send a message via Yahoo to basicxman
the robot controller uses C but there are similar programming languages, i recommend http://hacketyhack.net/ this is a interactive tutorial that you download that teaches you Ruby but is good for learning basic programming
although i like the idea of learning through easyC
Unread 21-03-2008, 20:57
learning through easyc is still hard because overall what i want to program is the autonomous code, the pressure switch, to control the driving with one joystick, and stuff like that but i dont know how to use the integers and stuff in that catagory.
Unread 21-03-2008, 21:01
erikstotle's Avatar
erikstotle erikstotle is offline
Quendi
AKA: Erik
FRC #0107
erikstotle is an unknown quantity at this point
Send a message via MSN to erikstotle
It would probably be a good idea to use easyC for this year at least, just as you learn. It lets you see whats going on in the code, but it also lets someone inexperienced in programming see the general flow of the program, and the code that goes along with that flow. At the same time, though, I highly suggest actively trying to read up on how to program in C, and try to understand why the code works the way it does. Trust me, once you get the hang of it, programming by hand is a whole lot funner than using easyC. I found http://www.chiefdelphi.com/forums/sh...ad.php?t=30976 to be fairly helpful when I got started. I think about the 9th post down has a link to a good tutorial to learn the basics of C. Have fun and good luck at the competitions!
Unread 21-03-2008, 21:50
man this easyc is actually easy thanks guys for all your help! if i still need help ill come ask you
For the first time ever, Sanddrag, appearing at the 2007 FIRST Championship! sanddrag Chit-Chat 5 26-03-2007 23:15
First Time Pneumatics SuperBK Pneumatics 6 17-01-2007 20:22
FIRST time FIRST is in CEPHAS Carlos Felipe General Forum 3 14-12-2005 17:53
FIRST in Time Magazine? Dr.Bot FIRST In the News... 3 02-02-2005 23:19
Time Magazine mentions FIRST Venkatesh FIRST In the News... 5 29-12-2004 23:25
