| View Poll Results: Which environment? | |||
| MPlab |
44 | 53.66% |
| EasyC Pro |
24 | 29.27% |
| Eclipse |
14 | 17.07% |
| Other |
16 | 19.51% |
| Multiple Choice Poll. Voters: 82. You may not vote on this poll | |||
#18
Re: What programming environment do you use?
SVN or Subversion is a software control system for tracking software changes. It is similar to Concurrent Version System.
What it means is there is a central site that you check in and check out versions of your robot software. That way you can track what changes are made. It works well if you have 2 or more developers. They can all work on the software and put their changes in. You can roll back to prior versions if you find that something did not work the way you expected it to. Even single developers will find it useful for the roll back features. |
| What programming tool does your team use? | ham90mack | Programming | 15 | 13-10-2007 15:52 |
| What environment will you use? | Astronouth7303 | Programming | 14 | 09-01-2007 14:58 |
| What programming environment did you use? | StevenB | Programming | 10 | 18-03-2006 09:32 |
| What kind of computer do you use for programming? | Rohan_DHS | Programming | 21 | 05-01-2006 11:52 |
