Go to Post For me Gracious Professionalism is about helping other teams make their ideas work. We do everything we can to help other teams program, or lend them parts from our pit. On the field we play to win. - Alpha Beta [more]
Unread 21-03-2008, 22:27
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Re: DC Motor and Gearing
Originally Posted by Vikesrock View Post
Don't gear ratios multiply?
Yeah they do, lol.
3:1 and 3:1 is 9:1
Unread 21-03-2008, 22:44
Red-Rx7 Red-Rx7 is offline
Red-Rx7 is an unknown quantity at this point
I did some quick research, and the gear stages do multiply.
I found an online calculator which can compute up to three stages:
http://www.technobots.co.uk/Technica...Calculator.htm
Playing with the User Defined section, I can come up with a few wild teeth combinations to equal what I need. I was browsing SDP-SI for parts, and found a simple combination of:
- 14 tooth on the motor shaft
- 50 tooth and 14 tooth on shaft # 2
- 32 tooth on the starter shaft.
This would mean that the 14 tooth on the motor would turn the 50 tooth, which would rotate the 14 tooth also on the same shaft; which is connected to the 32 tooth on the starter shaft.
This would create an 8.16:1 ratio.
Until I design it all with the actual gear sizes and such, I don't know what exact formula of gear teeth I will use. But, this is an example of something that I could use. That calculator comes in handy.
Next question:
- How to secure the gear shafts to the bracket plate?
For some reason, I am having a blonde moment here... I cannot figure out how the shafts that the gears would be secured too would attach to the bracket itself.
My original planned design was to take two aluminum plates to create a "top" and a "bottom" for the gearbox. I was going to put studs on each of the 4 corners to create the box. I was then planning on having the aluminum plates drilled out in the exact same spots with flanged ballbearings placed in them. Then, I was going to place the gearshaft in these bearings with the gears attached to the shaft. But... what prevents the shaft from just falling out (other than the gear being screwed to the shaft, and the gear resting on the aluminum plate)? Or is this how it is suppose to be held together?
Does that make since?
Unread 22-03-2008, 13:06
DonRotolo's Avatar
Back to humble
FRC #0832
Edit: Yes, gear ratios multiply.
Let's say you have a 1 to 4 reducer - 1000 RPM gets reduced to 250 RPM, right? Now, the second reducer is also 1:4, so 250 RPM gets reduced to 62.5
1000 / 62.5 = 16, so two stages of 1:4 is the same as 1:16
In this case, for 1:8 you'd want 1:4 and 1:2
Don
Last edited by DonRotolo : 22-03-2008 at 16:15. Reason: What An Idiot I am, I was just plain WRONG.
Unread 22-03-2008, 16:35
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Having flown gas models in the past, I think you will find the starter motor required to be too large. Since you only need a few revs to start the engine, perhaps a smaller motor to wind a spring, with a latch to release. (like the old .049 airplane engines)
Motor Gearing Help!!!! Bee-k Motors 3 20-01-2006 03:39
pic: Wheels and gearing Wayne C. Robot Showcase 20 06-02-2005 17:54
Gearing/motor questions. Josh Siegel Motors 8 25-01-2005 09:49
link: 1014 guts and gearing Skillz Robot Showcase 2 24-02-2004 13:24
Chiaphua gearing (Chippy and Bosch) honky Motors 3 31-01-2002 10:28
