Go to Post Losing, like criticism, is the only thing that makes you improve. - MooreteP [more]
Unread 22-03-2008, 18:24
Maxpower57's Avatar
Maxpower57 Maxpower57 is offline
Fabuloso
AKA: Maxwell V.
FRC #2574 (RoboHuskie)
Maxpower57 will become famous soon enoughMaxpower57 will become famous soon enough
Send a message via AIM to Maxpower57
Re: KoP Revamp?
Originally Posted by thefro526 View Post
most likely the OI will not use gameports.
THANK YOU GOD!!!!!!!!!!!!
hahaha
what would they use instead though?
hope to god they don't shoot for usb. that would suck for custom circuits.
eitherway i'm excited to see some new stuff roll out!
Unread 22-03-2008, 18:28
Daniel_LaFleur's Avatar
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: KoP Revamp?
Originally Posted by Maxpower57 View Post
T
Why? Just get a USB to serial (or joystick) adaptor and create your own custom circuits
Or better get one of the ~$99 daq modules and make whatever controller you want.
___________________
- Tennyson, Ulysses
Unread 22-03-2008, 18:31
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Re: KoP Revamp?
those are slow as .... something slow.... (Apple computers? *ducks to get out of fanboy's aim*)
i wouldn't trust any circuit with it.
Unread 22-03-2008, 18:35
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
Re: KoP Revamp?
What about an FTDI Chip. They're normally used to go from RS232 to USB, but I don't see why you couldn't do it in reverse.
They're relatively cheap, and fast enough for input.
Unread 22-03-2008, 18:47
Mad Scientist
AKA: Me
FRC #2040 (DERT)
Re: KoP Revamp?
The USB to serial or USB to joystick??? Yup slow but effective.
The USB DAQs can be quite fast though ... depending on the overhead of the DAQ driver.
Something like This or this could be a real possibility.
___________________
- Tennyson, Ulysses
Unread 22-03-2008, 18:51
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: KoP Revamp?
hahaha
You can get an adapter that goes from a gameport input to a USB output for 20 dollars or less. Ex. http://cgi.ebay.com/NEW-Game-Joystick-adapter-DB-15-F-to-4-pin-USB-Port_W0QQitemZ260221285250QQihZ016QQcategoryZ42322 QQssPageNameZWDVWQQrdZ1QQcmdZViewItem. Trossen robotics also has some mini joysticks and other stuff that works with USB: http://www.trossenrobotics.com/robot-parts.aspx
-Dustin Benedict
Unread 22-03-2008, 19:14
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Re: KoP Revamp?
also you're forgetting that all usb things need drivers.
and its hard enough going through that mess with operating systems,
Unread 22-03-2008, 19:28
thefro526's Avatar
Mentor for Hire.
Re: KoP Revamp?
I understand that USB things need drivers, I was just saying If you wanted to do it there is a way. Next year will be a learning year for almost every team and you will see a lot of people sharing their experiences on how to interface with the robot, so I wouldn't worry about too much of anything yet. Also I highly doubt FIRST will give us this new control system without some technical documents to help us out. In the past almost anything you could ever want to know about the current control system has been published and in time it will be the same in time, just you watch.
-Dustin Benedict
Unread 22-03-2008, 19:34
Golto's Avatar
AKA: Pat Plude
Re: KoP Revamp?
As far as drivers go, here's my thought.
Childboarding is your friend.
Unread 22-03-2008, 20:18
KTorak's Avatar
KTorak KTorak is offline
Fire Rescue 47
AKA: Kyle Dersch
FRC #1023 (Bedford Express)
Team Role: Driver
KTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond reputeKTorak has a reputation beyond repute
Send a message via AIM to KTorak
Re: KoP Revamp?
I remember FIRST sending out a huge survey last year about the KoP. Maybe they will change some stuff around with the new control system.
Kyle D- Myspace - Facebook
2008 Bedford Express Driver & Build & Design (Team) Co-Leader
2007 Bedford Express Driver & Build & Design (Team) Leader
2006 Bedford Express Driver, Build Team Member, & Board of Directors
2005 Bedford Express Rookie, Build Team Member & Robot Operator
2008 - GLR Quarter Finalist
2007 - GLR Finalist & Boilermaker Finalist & MARC Off Season Event Winner
2006 - GLR Johnson & Johnson Sportsmanship Award & Archimedes 7th Seed Quarter Finalist
2005 - GLR Finalist & Judges Award.
2004 - GLR Semi Finalist.
2003 - GLR/DTR Quarter Finalist & GLR/NAT'L Rookie All Star.
Unread 22-03-2008, 20:46
Golto's Avatar
AKA: Pat Plude
Re: KoP Revamp?
do you have a link to the survey?
Unread 23-03-2008, 14:40
Maxpower57's Avatar
Fabuloso
AKA: Maxwell V.
Re: KoP Revamp?
Hahah that'd be awesome.
Heres a box with some wires.
Build a robot. go.
we'd figure it out eventually.
Unread 23-03-2008, 15:53
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: KoP Revamp?
If IFI is really leaving (i hope not),
What will happen with the Kit Frame?
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 23-03-2008, 16:07
GBIT's Avatar
GBIT GBIT is offline
Lexantologist/Team Lead
AKA: Jared
FRC #0811 (Cardinals)
GBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really niceGBIT is just really nice
Send a message via AIM to GBIT
Re: KoP Revamp?
It might just not come in the kit. I don't believe the company is disbanding. i would think you could still buy parts from them. I hope you can anyway....
-Mentor-
-WPI '13-
-Former Team Lead-
-Past Driver-
Unread 23-03-2008, 16:30
AdamHeard's Avatar
Lead Mentor
Re: KoP Revamp?
IFI most definitely won't be disbanding, very little of their revenue is from FIRST. IFI seems to enjoy supporting robotics in general, so whether or not the KOP frame will be in the KOP, it will probably still be sold.
KOP Sprockets Bsteckler Kit & Additional Hardware 0 02-02-2008 10:38
KOP photos? Gary Dillard Rumor Mill 13 04-01-2006 20:56
KOP Gyro John Gutmann Programming 12 12-12-2005 21:59
