Go to Post I could say that the decline in the population of pirates is responsible for global warming, the statistics correlate, but its obvious there's no causation there. - Racer26 [more]
Unread 22-03-2008, 21:54
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
program port in computer
if i was going to buy a laptop and i wanted to use programming from there what type of port should i have? If i also wated to do it from a home computer is the port labeled "I0I0" ok?
Unread 22-03-2008, 22:04
Foster Foster is offline
Engineering Program Management
VRC #8081 (STEMRobotics)
Foster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond reputeFoster has a reputation beyond repute
Re: program port in computer
You want a serial port, it has a 9 pin female connector. It is often labeled IOIOIO.
Otherwise a USB port works if you get a USB to Serial converter, about $20.
Unread 22-03-2008, 22:58
what if the port is labeled "com 1"?
Unread 23-03-2008, 00:57
programMORT11
Posts: n/a
that should work too- i'd say its really better to use serial compared to a usb-to-serial cable, since that is a lot slower (at least on my AVR )
Unread 23-03-2008, 16:08
whitetiger0990's Avatar
whitetiger0990 whitetiger0990 is offline
whitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of lightwhitetiger0990 is a glorious beacon of light
In order to program the bot, you need a USB converter or a computer with a standard db9 female port (9 pins). These are labeled 1010 or COM1. These are the same. (I'm pretty sure those are 1s and 0s, not Is and Os).
http://en.wikipedia.org/wiki/RS-232
http://en.wikipedia.org/wiki/Serial_port
http://en.wikipedia.org/wiki/COM_%28...e_interface%29
print$q=chr(ord($q)+$1)while("7443-0201-8465130105-12-03135-82482113-06-7672-070208-0613-70"=~/(-?\d\d)/g);
Unread 23-03-2008, 22:35
Smile Re: program port in computer
thanks
Setting up a new computer to program hipsterjr Programming 4 11-03-2008 22:38
Program Port Specs Jake M Programming 2 19-02-2008 09:59
Program Port Y-cable CyberWolf_22 Control System 5 01-02-2005 21:21
Program Port Y-cable CyberWolf_22 Electrical 5 01-02-2005 21:21
LCD wiring to Program port jgannon Control System 10 30-01-2005 23:28
