Go to Post We should all just be humble, courteous, and act like gentlemen (or ladies) on these forums, and not fill it with yakking about who's drive train is better. - Veselin Kolev [more]
Unread 22-03-2008, 23:51
StevenB StevenB is offline
is having FRC withdrawal symptoms.
AKA: Steven Bell
StevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond reputeStevenB has a reputation beyond repute
Re: Holonomic vs Mecanum Help!!
Note: When I refer to omni, I mean a robot which has 90 degree omniwheels, one on each side of a square (or rectangle). That square can be rotated from the robot frame, meaning you have a wheel diagonally in each corner.
Originally Posted by daltore View Post
I think it would be a little simpler to program mechanum reliably as apposed to omni
Unless I'm misunderstanding you, not really. As said before:
Originally Posted by Abwehr
The same exact code can be used with either configuration.
From what I've seen in VEX, Mindstorms, and FRC, mechanum tends to lend itself to a slightly more powerful drive train, as omni holonomic has almost no resistance to movement, basically making it a hockey puck on wheels (note the incessant fishtailing of 2158's robot from 2007 FRC, where we only had 2 omniwheels, and were pushed around easily).
Power-wise, mecanum and 4-wheel omni are exactly the same. You get ~71% (sqrt(2)) power in one set of directions, and 50% in the directions 45 degrees from the first. Any differences are in the construction of the wheels.
Need a physics refresher? Want to know if that motor is big enough for your arm? A FIRST Encounter with Physics
2005-2007: Student | Team #1519, Mechanical Mayhem | Milford, NH
2008-2011: Mentor | Team #2359, RoboLobos | Edmond, OK
2014-??: Mentor | Looking for a team...
Unread 25-03-2008, 16:57
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
you should go with the 1565 Linkage drive system (that's IMHO of course ) thats the best bet lol! (look it up!!)
Mecanum Drive - Help Smoking_Gun Programming 22 04-12-2007 20:51
Holonomic/Omni vs Defense Alex Burman Technical Discussion 15 15-02-2006 20:35
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
Holonomic... Greg Perkins Technical Discussion 2 02-02-2005 11:59
holonomic drives Max Lobovsky Technical Discussion 5 10-03-2004 21:31
