Go to Post The worst that happens is we try our best and lose. And there's no shame in that. - pfreivald [more]
Unread 23-03-2008, 00:44
vivek16's Avatar
vivek16 vivek16 is offline
Whoa! college pilot.
AKA: vivek
FRC #2264 (trojan robotics)
vivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond reputevivek16 has a reputation beyond repute
Send a message via AIM to vivek16 Send a message via MSN to vivek16
pic: A good day's cheeseholing
Unread 23-03-2008, 00:45
AndyB's Avatar
AndyB AndyB is offline
Ambitiously Disappointing
AKA: Andy Burchardt
FRC #0171 (Cheese Curd Herd)
AndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond reputeAndyB has a reputation beyond repute
Re: pic: A good day's cheeseholing
Weight reduction means you guys built something a little more interesting than a box with a big old sign on it... although it was a pretty nice box...
Can't wait to see you guys in Minnesota. I'll be inspecting on Thursday and doing field reset on Friday and Saturday.
Team 171 :: Cheese Curd Herd :: College Mentor, 2008-Present
Team 269 :: CooneyTech Robotics :: Student, 2005-2007
Unread 23-03-2008, 07:58
Madwolvez Madwolvez is offline
Madwolvez is an unknown quantity at this point
It looks like you put a robot through a paper shredder.
Unread 23-03-2008, 10:59
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
I hope you recycle all that aluminum!
How overweight were you? Do you make weight now? How many batteries did you go through?
...Is there anything left of your robot?
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 23-03-2008, 12:15
Golto's Avatar
Golto Golto is offline
AKA: Pat Plude
FRC #4572 (BArlow RobAutics)
Golto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of lightGolto is a glorious beacon of light
Wow! And the last few years we have ADDED weight to the bot!
Unread 23-03-2008, 13:22
vivek16's Avatar
AKA: vivek
this is actually from two 4'6" lengths of 3x1" tubing that are tiers on our bot. We did these week 3 I think on our big old mill.
We saved about 4 pounds. (there is a bunch of other stuff under the aluminum. there is only a 2 foot cake of it. Its kinda cool because it all sticks together!)
**sigh** we took apart the box for plywood, victors, and CIM's
So, come Saturday before Shipday, we were 10 pounds overweight (and we thought we were keeping track very well!) so we ditched our 2 globe motor tranny for our manipulator, replaced it with a CIM from our Omniwheel drivetrain, and took a sawzall to all of the extra bolt ends.
We are now just barely making weight and use only 4 CIM's on our bot.
our drivetrain has 5 omniwheels now and is essentially 4wd with omniwheels and an extra wheel to turn (turns almost as well as castor drive last year ).
| _ |
-Vivek
p.s. I will get pictures up as soon as I can of the bot.
"we don't build robots, we build people"
Unread 23-03-2008, 18:32
vivek16's Avatar
AKA: vivek
Here are the cheeseholes:
the long tiers on the left side of the bot.
-Vivek
Unread 23-03-2008, 20:36
AndyB's Avatar
AKA: Andy Burchardt
So the claw follows that shape around... very interesting. I look forward to seeing it. What is the advantage of doing a rounded curve over a straight line/triangular shape?
Looks pretty effective though.
Unread 23-03-2008, 21:03
vivek16's Avatar
AKA: vivek
The advantage is that it goes from being parallel to the ground to being perpendicular to it without any jerks that could bump the ball off.
I am not sure if you say this sketch from the other picture thread:
Garage rails weigh a lot... hence those cheese holes (all those cheese holes make convenient places to put surgical tubing!)
EDIT: Also, it was much easier to make one weld in the garage rail than to cut carefully, measure perfectly and make multiple. The rollers slide better on the preformed shape too.
Unread 25-03-2008, 16:03
Racer26 Racer26 is offline
This design looks VERY similar to the way 1075 launches. We have a system that looks a bit like this:
and the carriage runs up it a bit like a roller coaster. Its all custom though, no garage rails here.
Unread 25-03-2008, 16:58
647techangel's Avatar
647techangel 647techangel is offline
K.I.S.S (Keep It Simple Stupid!!)
AKA: Tech_Angel
FRC #0647 (Cyber Wolf Corps)
Team Role: Driver
647techangel has a spectacular aura about647techangel has a spectacular aura about
that looks like you had fun with
!!!!647 HOOAH!!!!
pic: Spares are good. ZZII 527 Extra Discussion 2 23-02-2007 19:51
Good Night, and Good Luck. Ken Leung Chit-Chat 2 25-10-2005 11:09
pic: last minute cheeseholing Veselin Kolev Robot Showcase 8 22-02-2005 19:25
Cheeseholing suggestions Alex1072 Technical Discussion 10 02-02-2005 10:10
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
