Go to Post Some companies cut costs (and cut corners to do so). Some work hard to build loyal customers. Which would you rather purchase from? - sanddrag [more]
Unread 22-03-2008, 08:57
starsROBOTICS starsROBOTICS is offline
FRC #2276 (S.T.A.R.S)
starsROBOTICS is on a distinguished road
motor/gear ratio
if i wanted to make our robot really fast do i gear it up or do i find a different motor?
Unread 22-03-2008, 09:11
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: motor/gear ratio
You probably want to gear it up, and if you only have one CIM motor per side you probably want to add one more per side (assuming you don't have any more of them on the robot already, because you can only have 4 maximum). If you're using the kit Toughbox transmissions, it's not too difficult to remove the second stage of gear reduction, then play with the drive chain sprocket sizes to get the overall ratio just right.
Unread 22-03-2008, 09:27
Billfred's Avatar
Billfred Billfred is offline
There are a few ways to make your robot go faster:
-Larger (though not necessarily wider) wheels
-Gearing up, either in gears or (probably easier) sprockets
That said, there are upper limits on that. You're always trading off top speed for acceleration abilities, and demanding too much torque from your motors (read: more than they can put out at stall) is a sure-fire way to trip breakers. The often-used rule of thumb around here is that a robot should be able to slip its wheels when pushing against a wall on carpet. If you want to be able to go faster than that condition allows, you'll need to integrate a multiple-speed transmission.
If you're really up for number-crunching, try JVN's spreadsheet on the topic. Ask around on anything that's fuzzy, and you should get the answers you need.
Unread 23-03-2008, 15:32
Andy L's Avatar
Andy L Andy L is offline
FRC #1458
Andy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud ofAndy L has much to be proud of
Send a message via AIM to Andy L
Doing this took us about an hour while pits were closing on Saturday of Silicon Valley. AM made it very easy to remove that second stage.
If you want to know how I can go over how to do it from memory
Unread 23-03-2008, 19:15
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
here what we use, to 1:6 ratio in tough box, out of tough box a 24:36 ratio to the wheels, our wheels are 8 inches in diameter, 2 cim's per tough box, we get good accleration, and a descent top speed, we would be better but were to wide...
Is now an engineer thanks to FIRST.
Unread 24-03-2008, 10:02
kramarczyk's Avatar
kramarczyk kramarczyk is offline
is getting his kicks.
AKA: Mark Kramarczyk
FRC #3096 (Highlanders)
kramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond reputekramarczyk has a reputation beyond repute
A. John's white paper rocks, although I prefer his earlier one (http://www.chiefdelphi.com/media/papers/1469) because it provides plots for acceleration, velocity, distance, current draw and such.
B. Be careful in speeding up the drive train a lot because it's very easy to make a drive train the won't turn. The exact number is dependent on the type of wheels being used and where they are located. I'd suggest that upwards of about 10 fps and you need to put conscious thought into this problem. This white paper on turning is quite helpful http://www.chiefdelphi.com/media/papers/1443
If it's a 4x4 drive train this supporting spreadsheet may be helpful http://www.chiefdelphi.com/media/papers/1917
C. Finally, with super high gearing it is very easy to give up some initial acceleration to win the 30' lane sprint... for the first half of the match. The second half of the match can be spent motionless with a dead battery. Again this is extremely dependent on the type of wheels and their location, but I'd suggest that anything higher than 15 fps starts to run this risk.
D. Go Fast, Turn Left!!!
Mark
Brick walls are for other people. - Randy Pausch
Last Year's Gear Ratio AndyB Technical Discussion 4 11-11-2007 01:17
Gear Ratio Math for Cim Motor FP801-005 KogaVanDragon Motors 2 14-01-2006 02:38
Transmission gear ratio MASherry Technical Discussion 6 13-01-2005 10:32
Help with gear ratio Wayne C. General Forum 6 26-01-2004 12:30
Gear Ratio Doesn't Matter Paul Copioli Technical Discussion 2 27-09-2001 08:18
