Go to Post Watch out world, FIRST is going to become mainstream! - Church [more]
Go Back   Chief Delphi > Old Forum Archives > 2000
Unread 23-06-2002, 23:36
archiver archiver is offline
Forum Archival System
#0047 (ChiefDelphi)
Re: Relay fault
Posted by Nate Smith.
Other on team #66, GM Powertrain/Willow Run HS, from Eastern Michigan University and GM Powertrain.
Posted on 8/17/2000 12:23 AM MST
In Reply to: Relay fault posted by Steve Prairie on 8/16/2000 5:35 PM MST:
: The terminal that joined the relay with the wire was very loose. And oddly enough, this was the second faulty relay we had this year. Has anyone else had this problem with the innovation FIRST relays?
I'm assuming that you're talking about the terminals that the motor and power supply connect to on the relay. I was talking to Dave from Innovation FIRST at the Great Lakes regional, after having one terminal simply fall off of a relay during shipping, and it turns out that the production company that they contracted out the actual fabrication of the relays and other components did not press the terminals into the boards as was requested before soldering the board, causing for loose relays. I would recommend contacting Innovation FIRST to get information on exchanging the defective relays for new ones.
Nate
[IMG] code is Off
Wiring the relay for the pnumatics Placebo OCCRA 3 05-11-2002 23:04
Spike Relay Input nwagers Electrical 3 16-07-2002 22:23
NEED HELP with Delay loop for compressor relay switch archiver 2001 10 24-06-2002 02:11
Relay Outputs OddOne Technical Discussion 3 01-02-2002 19:52
downtime, not ours or venturesonline fault Brandon Martus Announcements 0 26-12-2001 16:05
