Go to Post There's a fine line between cockiness and confidence. Confidence is one of the major keys to success and happiness in life. As long as one can carefully stay on the right side of the line, staying connfident while remaining humble, and ego can be quite beneficial. - Karthik [more]
Unread 24-03-2008, 13:32
hipsterjr's Avatar
hipsterjr hipsterjr is offline
Your bot can score but can it dance
AKA: CJ
FRC #4451 (The Burning Magnetos)
hipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond reputehipsterjr has a reputation beyond repute
Send a message via AIM to hipsterjr
Re: Fork type End Defectors & Ball acquisition
Originally Posted by M. Krass View Post
That's probably not something you should be too proud of.
Our forks pick up the ball very easily no matter where we are, provided we can get the ball in between them. It's hard to see the other side of the barrier.
Our biggest problem was seeing the forks on the other side of the field and smashing them against the wall. I think it may be easier to lift the ball if we make our forks longer and picking up around our home wall.
2010 Palmetto Chairmens Winner
2009 Peachtree Finalist Thanks 1319 & 590 "Sure your robot can score, but can it dance?!"
2008 Palmetto Regional Finalist Thanks 343 & 804
2008 Florida Regional Finalist Thanks 179 & 69
2007 Palmetto Regional winners Thanks 1319 & 832
2005 Palmetto Chairmens Winner
Unread 24-03-2008, 15:18
Bob Steele's Avatar
AKA: Bob Steele
We have a set of forks that have the same radius as the ball at the height we grab it. A pneumatic cylinder opens them and when the button is released it remains closed around the ball. Our forks are made of carbon fiber and we have had them broken twice so far. (we have spares) Once we ran them into the end wall (in Portland) and another time another team rammed them (I think it was not intentional). They are pretty sturdy and they have a shock absorber of our own design that allows them to flex when hit...
Our third claw (we call it the talon) comes down from the top and traps the ball in a three point grip. It is quite effective at holding the ball.
The entire lift mechanism tilts back when we have the ball and keeps the ball centered on our robot for traveling to the scoring quadrant.
The talon is also powered by a pneumatic cylinder.
The third appendage is our kicker which we affectionately call "the tongue"
which gives the ball a small kick at the top of the overpass allowing us to quickly hurdle.
We had some problems in Portland but re-designed two pieces and now we ar working pretty well.
With the curved claws we can pick up the ball without having to push it against the wall.
Unread 24-03-2008, 15:31
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
team 1086 just uses straight PVC tube, our "twin" 384 put a bend into the end of their forks which prevents the ball from rolling out once they get possesion of it... we did notice 103's brushes and plan on testing a version of these once we get to championship... but overall we havent had too big of a problem lifting the ball, we just take it nice and slow while lining up with the ball, so we dont bump it out of position.
Unread 24-03-2008, 15:54
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
1885 Used Straight forks and 2 arced "paws" that come down over the ball. The arcs extend over the top crest of the ball to keep it from coming out the front, and they are angled sideways to keep them from coming out the sides. They are actuated to "pounce" on a big ball o' yarn via a 4" pneumatic piston. (edit) Capturing the ball via this method actually worked very well; we had issues with a weak motor on the lift that prevented us from hurdling well, but that will be fixed in Philly.
We had a huge problem with our forks at VCU because they were, by design, supposed to stick out the front of the bot for the entirety of the match. However whenever we ran into the wall all of the impact force was transferred up to the forlift arm mounts. By the end of Friday, all of the welds on that mount were completely broken and any chance of hurdling was practically gone.
We have plans to upgrade this in Philly with a 2" wide 1/8" thick lexan piece that we bend around to make a semi-circle. Prototyping it suggests that the lexan may wear out in the course of the matches, so we're going to work on an upgrade for that before Atlanta. The lexan should absorb any wall impact the forklift receives instead of transferring it to the mount points, which is the goal for Philly. The inspiration came from 2106 (Junkyard Dogs) at VCU.
GitHub
G14 & a difference between start & end of match Elgin Clock Rules/Strategy 6 09-01-2008 20:26
G14 - ball on rack at end ericand Rules/Strategy 5 09-01-2008 08:00
Controlling a "fork lift" type mechanism. Brad Voracek Programming 4 18-01-2007 22:53
The end of Doom & Quake? Raven_Writer Chit-Chat 6 13-09-2004 20:35
Rutgers J&J MidAtlantic- THE Regional to End the Season With Wayne C. Regional Competitions 14 31-03-2003 20:59
