Go to Post I don't remember who said it or what the words are exactly...(I think it was Hopalong Cassidy) Don't say goodbye, just say see you later. - Al Skierkiewicz [more]
Unread 24-03-2008, 13:56
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Ball Bouncing Out of Bounds?
One bot at FLR always shoots after it is disabled. During FLR, it shot at both of the refs volunteering from our team on separate occasions. Fortunately, there were no injuries, so we can have a few laughs at them dodging trackballs.
Robot Inspector
Unread 24-03-2008, 14:58
Originally Posted by Qbranch View Post
We closelined the head ref and three other refs when our gripper was holding the ball and a robot ran into ours, causing us to hold the ball outside the field and hit the had ref in the face with the trackball. When I was recovering from the hit and getting us going around the track again, I swung left, which whapped three other refs (including Stu! ) in the face.
No penalty there, I hope. You were forced into it by another robot.
L.A. didn't have to deal with that much, as trackballs only left the field once or twice (headed for the scoring table).
Unread 24-03-2008, 15:06
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
That 'bot is not complying with the safety-driven guidelines published in Team Update 5:
  • Design the mechanism so that it does not make any sudden movements
    when the Robot is powered on or off, or when the pneumatic system (if used)
    is charged or discharged.
  • Design the mechanism so that any stored energy is released in a slow,
    controlled manner (over several seconds) when the Match concludes and the
    Robot is powered off.
The team should have been required to modify the robot design so it would not launch at the end of the match or if otherwise disabled.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 24-03-2008, 15:37
Uberbots's Avatar
Uberbots Uberbots is offline
Mad Programmer
AKA: Billy Sisson
FRC #1124 (ÜberBots)
Uberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond reputeUberbots has a reputation beyond repute
I think the penalty you got was the refs actually being lenient on you. Those balls can do a fair bit of hurt to someone (often referenced as being able to break your neck if it hits you right), and firing with enough force to actually clear the opponent's driving station (even with a bounce) requires a fair bit of energy. According to rule SO1, you probably should have been DQ'd or yellow flagged for that play, but you weren't, so be grateful.
Im not trying to suggest that you purposely tried to launch it like that, but the fact that your robot could probably set it on the ref's 'to watch' list.
A few of my favorite numbers:
175 176 177 195 230 558 716 1024 1071 1592 1784 1816
RPI 2012
BREAKAWAY
Unread 24-03-2008, 18:05
Dancin103 Dancin103 is offline
The Crazy Blonde
AKA: Cassie
FRC #0103 (Cybersonics)
Dancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond reputeDancin103 has a reputation beyond repute
Send a message via AIM to Dancin103
We launched the ball out of bounds, and it was a penalty, I remember this.
Cybersonics Technology Team 103
2003 Championship Chairman's Award Winners
NEED CHAIRMAN'S HELP?? Subscribe to our YouTube Channel, we answer your questions daily!
Unread 24-03-2008, 19:36
Coredesat's Avatar
Coredesat Coredesat is offline
Wiseacre-of-all-trades
AKA: Will Weaver
FRC #0339 (Kilroy)
Coredesat is just really niceCoredesat is just really niceCoredesat is just really niceCoredesat is just really niceCoredesat is just really nice
Send a message via AIM to Coredesat
There were a few occasions at the NASA/VCU regional where trackballs that had been hurdled or launched over the overpass bounced off the field, but I don't recall any penalties being assigned. The balls were simply thrown back onto the field. This may have to do with where the ball went when it left the field (or the fact that the bouncing wasn't considered intentionally launching the ball off the field). However, on some occasions, the ball nearly went over the driver or robocoach stations.
Will Weaver - FIRST Volunteer for 5 yrs and counting!
http://willweaverrva.tumblr.com
Alumnus of Team 339 (Kilroy) - 2002
NASA/VCU Regional Volunteer 2007 (Floater)
NASA/VCU Regional Volunteer 2008 (Pit Admin/Backup Announcer)
NASA/VCU (Virginia) Regional Volunteer 2009-2011 (Photographer)
Racer26 Racer26 is offline
Well I mean, any pneumatic fired launcher could move when disabled, depending on state at disable time. Theres nothing you can do about that.
Ours will return to its starting configuration, which shouldn't do any real damage to anything.
Unread 24-03-2008, 20:31
The issue is about rapid motion in the mechanism after the robot is disabled. If the design is such that the motion is gradual, then there's less of a safety concern.
Unread 25-03-2008, 22:29
Tomasz Bania's Avatar
Tomasz Bania Tomasz Bania is offline
FSN Cor. Det/Pal 2006
AKA: Micro3000x
FRC #0818 (Steel Armadillos/Genesis '02)
Tomasz Bania has a spectacular aura aboutTomasz Bania has a spectacular aura about
Send a message via AIM to Tomasz Bania Send a message via MSN to Tomasz Bania
Cool Re: Ball Bouncing Out of Bounds?
Originally Posted by petek View Post
Prior to week one events the FTAs (and I believe the Head Refs) were warned to watch out for balls being launched or bounced off-field. Teams were to be given a warning and if they didn't correct it would be cited for violation of <S01>. The concern is that a bystander might get hurt by the ball (bystander bowling is a no-no), or that off-field equipment might get damaged (scoring, sound, etc.). I believe that one team got the warning at Detroit, though I don't think they got a penalty.
If i'm right that was our team (during practice day) because our ball kept falling on the refs or when we hurdled it flew out through the exiting zones by jumping over the 1ft barrier, which I'm surprised that more balls didn't bounce out.
Playstation Network ID: micro3000x
Thank You to the Rookie Teams at the Detroit Regional for accepting our invitations for the elimination rounds. Good Luck!
Team 818 Regional High Definition Video 2008,CLICKHERE
Unread 25-03-2008, 23:28
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Originally Posted by MasonMM View Post
this criteria that was not available prior to the regional
Keep in mind that in 2005, you got disabled if you broke the plane of the driver station wall with a tetra, even if you didn't let go. Even without that experience, it shouldn't surprise anyone that actually launching a game piece of comparable weight over the wall would be considered a safety issue, particularly if done repeatedly. First be grateful that nobody got hurt, and then that your team didn't have to bear the full brunt of <S01> and <T04>. Best of luck getting your robot to operate safely before Bayou... 10 point penalties hurt, but not as much as getting hit in the face with a trackball.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
Unread 25-03-2008, 23:39
waialua359's Avatar
AKA: Glenn
FRC #0359 (Hawaiian Kids)
This is a gray area that is not specifically written in the rule book.
As long as fair warning has been given to allow a team to try and correct/modify a design function for the purpose of safety, its fair.
However, I dont think off the bat, a team should receive a penalty for it. Not that it happened already or if it occurs in the future.
Unlike in '06 when teams had to control shooter's ball speeds, there were no detailed guidelines about ball trajectories, speed, etc.
Unread 25-03-2008, 23:55
dtengineering's Avatar
AKA: Jason Brett
If you use a single solenoid valve then your pneumatic launcher will automatically vent when disabled. I can guarantee you 100% that it is impossible for the pneumatic launcher on our robot to fire while disabled.
As for accidently launching the ball over the wall... just like hockey players are responsible for their sticks, robot drivers are responsible for their driving.
The alternatives to a penalty... disablement... disqualification... or even just an extremely slow return of the ball to the playing field, are such that you should be quite grateful to the referees for their lenience.
Still, it's really cool that your launcher has that kind of power.
Jason
Balls bouncing out of goal Bob Steele Regional Competitions 31 08-03-2006 13:00
Placing Tetras out of bounds Someone Rules/Strategy 6 10-01-2005 00:08
Knocking out Doubler Ball mightywombat Rules/Strategy 47 23-02-2004 15:18
10 pt. ball into/out of play Lil' Lavery Rules/Strategy 23 28-01-2004 14:17
Out of bounds... -- copy of posting in General archiver 2000 0 24-06-2002 00:11
