Go to Post It's a hunch, based on engineering intuition; there are too many hard-to-quantify variables to do any accurate calculations. Looking for some experimental corroboration or refutation. - Ether [more]
Unread 25-03-2008, 07:56
Aren_Hill's Avatar
Build Nifty Things
pic: 1625's swerve module (better pic)
Unread 25-03-2008, 07:59
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: pic: 1625's swerve module (better pic)
You're the only other team I've seen do welded tube construction wheels. I thought we were alone with that because everyong else seems to hog them out of a billet.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 25-03-2008, 18:04
wowmuffin's Avatar
wowmuffin wowmuffin is offline
FRC #1529
wowmuffin is an unknown quantity at this point
Thumbs up Re: pic: 1625's swerve module (better pic)
Wow... those are beautiful. Are those wheels driven throught a screw gear or am I not understanding how the motor drives those wheels?
Chomp Chomp Chomp
Unread 25-03-2008, 18:26
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
It is done by changing the axis of rotation with a set of miter gears.
Nice setup, saw you guys on the MWR webcast, good looking robot.
Unread 25-03-2008, 18:32
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I like how you used snap-rings instead of collars. That has to save a lot weight.
-Dustin Benedict
Unread 26-03-2008, 00:20
Aren_Hill's Avatar
Build Nifty Things
these are faster to make and are also most likely lighter and stronger in the places the force is applied.
its really easy to just waterjet the sideplates and weld them on, these wheels are 1.75" wide
I LOVE SNAP RINGS!!! lol also the custom 7068 hex axles....not overkill at all...
A guy who likes robots.
Unread 26-03-2008, 00:27
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Yes, I loved your guy's setup when you brought over the spare module to compare to ours at MWR. It is a real slick setup, not to far from ours. Great job on the wheels, and I absolutely love the sprockets you guys use to steer. That is an amazing setup on that. Hawging out the middle of hte sprocket also has to save a ton of weight, and I liked the slotted holes in the sprocket (if I remember right) to fine tune each wheel's tracking before you went out onto the floor.
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 26-03-2008, 02:24
Chris Herold's Avatar
Chris Herold Chris Herold is offline
Autodesk Inventor Guy
FRC #1983 (Skunkworks Robotics)
Team Role: Student
Chris Herold has a spectacular aura aboutChris Herold has a spectacular aura aboutChris Herold has a spectacular aura about
Send a message via ICQ to Chris Herold Send a message via AIM to Chris Herold
Hey, I like it. They look great! Swerve drives are for me as a rookie pretty impressive just because of their advantages. I'll probably test my cad abilities during the off-season by designing one myself... I'll see but it's a nice piece of metal!
Chris
Oregon Regional, Portland: Kleiner Perkins Caufield & Byers Entrepreneurship Award; Underwriters Laboratories Industrial Safety Award; Quarterfinalist (thanks to 492, 2130)
Microsoft Seattle Regional, Tacoma: Engineering Inspiration Award; Regional Winner (thanks to 2046 and 949); Delphi “Driving Tomorrow’s Technology” Award
Autodesk Inventor Award Finalist: Finalists
Make sure to check out the finals and vote at Firstbase!
Unread 26-03-2008, 07:22
Same reason we do wheels out tube and plate welded together.
Thank-you 294 & 67
Unread 26-03-2008, 10:01
AdamHeard's Avatar
Lead Mentor
How easy is it to hold the plates and tube concentric while rounding?
If it is just standard Al tube, how thick are the walls and how true to round is the outer surface?
Unread 26-03-2008, 10:07
We cut a relief pocket in the plate so that it over hangs the tube and tube literally snaps into the plate. This gives us wheels as close to concentric as possible to make. I'll dig up some pictures and grab a few of the evolution of the design when I'm at the shop today so you can see what I mean.
Pete
Edit:
http://www.chiefdelphi.com/media/photos/31104?
http://www.chiefdelphi.com/media/photos/31105?
http://www.chiefdelphi.com/media/photos/31102?
http://www.chiefdelphi.com/media/photos/31103
Pictures now up.
End Edit
Thank-you 294 & 67
Unread 26-03-2008, 12:09
Aren_Hill's Avatar
Build Nifty Things
We just used 4" o.d. 1/8th wall tube, and waterjetted the sideplates, due to the nature of a waterjet it puts a slight taper on things so when i had it make a
3.75 o.d. disc it pressed right into the side of the tube and held itself there solidly while it was welded.
they're as concentric as you'll ever need for wheels.
Unread 26-03-2008, 12:54
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How are you keying the wheel to the axle. I'm planning on using that type of wheel next year and just looking to compare ideas
Mentor 2415
Unread 26-03-2008, 14:12
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
how is the lower plate supported? I know it used as a bearing surface, but it is sandwiched between plates or riding on small ball casters. I have always wondered how this work with swerve modules, I understand the rest of it but the lower support plate is the only gap in my limited knowledge of drive systems(I don't go into the kinematics...yet).
Unread 26-03-2008, 14:30
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
The lower plate isn't necessarily a support plate, just a bearing surface like you said. Due to the nature of friction, it does a little support, but mainly it just rubs against flat plastic patches (lubed up to reduce friction) on the frame to aid in steering the modules. The face of the contact between the plastic and the plate is purely vertical. No horizontal contact is made between the plate and the frame. It is welded, in the corners, to the square tube that makes up the vertical body of the module.
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
