Go to Post If you have a robot you don't need any more, use it for demos, or let a rookie team borrow it to learn wiring, programming, and demo around their school. - Barry Bonzack [more]
Unread 25-03-2008, 08:51
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Drivetrains - How are you doing it?
There are a handful of robots out there this year that have exceptional speed, but don't seem to have sacrificed acceleration. Team 27, Rush, is one that comes to mind, as is Raider Robotics Team 25 and Simbotics team 1114. I believe their bots are also close to the 120 limit.
My question is this - to those teams that seem to have exceptionally fast drive trains - what is your setup? I believe Rush uses dewalts, but I haven't been close to their bot to see if they use 4 cims + 4 dewalts and shift them.
To get things started, we use 4 cims and 2 AndyMark supershifters. I'm guessing around 13-14 actual fps (we were very similar to Thunderchickens speed-wise).
Unread 25-03-2008, 09:11
Mageofdancingdr's Avatar
Mageofdancingdr Mageofdancingdr is offline
Mageofdancingdragons
AKA: DJ Hoffman
FRC #0599 (Robodox)
Mageofdancingdr is an unknown quantity at this point
Re: Drivetrains - How are you doing it?
We have custom gearboxes built around two cims and dewalt transmissions (horribly inefficent and slightly unnecessary, AndyMarks next year). We have three speed shifting, but have a lot of trouble maintaining the gearboxes from breaking. Come see the design in Atlanta if you can.
3.1415926535897932384626433832
Unread 25-03-2008, 10:29
1086VEX's Avatar
1086VEX 1086VEX is offline
VA FIRST Alumni
AKA: Alex Curfman
FRC #0384 (Sparky)
1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light1086VEX is a glorious beacon of light
team 1086 is running a meccanum drivetrain with one cim and tough box on each wheel. this gives us around 12 FPS...
Unread 25-03-2008, 10:35
Racer26 Racer26 is offline
1075 uses a custom tank tread with the guts of an andymark shifter, and 2 cims that live INSIDE the track... whole thing comes on and off in 5 minutes, and nobody can outpush us... not that that really matters this year.
Unread 25-03-2008, 10:39
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
We use the toughboxes and the KOP wheels and our theoretical top speed is about 11 feet per second but we really do about 10.5 or so. The reduction we used made is so that the robot has to have almost 3/4 of the pwm value to get moving so it's kinda difficult (and loud) to get moving for low speed maneuvers. We've found that it's plenty fast for what we're using and puts very little strain in the four cims powering it.
-Dustin Benedict
Unread 25-03-2008, 11:33
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Team 141 is using two cims per side with direct drive via timing belts driving custom six inch wheels. The reduction is around three to one, I do not know the exact numbers. In theory we can run 18-20 fps. When the drivers decide to run laps we can usually turn them in seven to eight seconds on a full field provided there are big enough openings on the field that we can get through. As long as there are openings we have been able to get through them without slowing down significantly.
Unread 25-03-2008, 11:37
thefro526's Avatar
Mentor for Hire.
Also a lot the team with high tops speeds use two speed transmissions. I would also guess that some of them use automatic shifting software to always have the drive train running at max efficiency.
-Dustin Benedict
Unread 25-03-2008, 11:42
Cowmankoza's Avatar
Cowmankoza Cowmankoza is offline
KoZa
AKA: Matthew Koza
FRC #1251 (The Tech Tigers)
Team Role: Operator
Cowmankoza has a spectacular aura aboutCowmankoza has a spectacular aura about
Send a message via AIM to Cowmankoza
The problems alot of teams are having with bots that are at weight limit, is that when you gear up the drivetrain to a crazy speed (20 fps lets say) you have to factor in acceleration time and the space provided to accelerate, therefore many teams with robots capable of reaching that speed never really do. (however teams with smaller and lighter bots *cough*148*cough, have a significantly reduced acceleration time due to their lesser inertia)
To combat the acceleration problems we use 2 cims and a fp per side with a max speed of roughly 16 fps.
Team 1251 The Techtigers
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award (The real winner)
Unread 25-03-2008, 12:32
tanmaker
Posts: n/a
On 1986's drivtrain, we use mecanum wheels that are connected to the CIM motors with a simple 6:1 reduction using sprockets and chain. Each wheel has its own suspension assembly that is easily removed and replaced, and only 2 wires and 2 bolts need to be removed. This set up gives us a theoretical speed of 23 fps but in reality, its closer to 20fps.
To keep our speed so high and still have insane acceleration, our robot weighs under 80 lbs with bumpers and the battery. We could also lower this another 10-15 pounds by removing our modular ball knock-down device.
Unread 25-03-2008, 15:23
Mike Schreiber's Avatar
Mike Schreiber Mike Schreiber is offline
FRC #0067 (The HOT Team)
Mike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond reputeMike Schreiber has a reputation beyond repute
You were close. We use 2 CIMs coupled into one dewalt per side. This direct drives our middle wheel, and we have chain running from there to our front and back wheels (6WD). We use AndyMark off the shelf 6" wheels and the middle one is lowered about an eigth inch for turning. We also use servo shifting. Our problem has been our drive shaft breaking. It happened in the quarters and semis at detroit, thank goodness for 47 and 453 winning one on their own. We have a plan to fix this for GLR and hope to be working much better.
Unread 25-03-2008, 15:32
T3_1565 T3_1565 is online now
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
We use 6 inch omni wheels and a CIM + banebot 12:1 transmission for each wheel, because they make for good pods lol (our famous linkage and all). and we reach roughly 10.5ft/sec
Unread 25-03-2008, 16:29
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
We have a 4x6 differential (tank) drive system. There are 2 cims/side mated to supershifters. The maximum speed in a straight line on a linoleum floor (observed) is 18ft/sec, but with the shifters our track speed (with traffic) is still a good haul at about 12.75ft/sec.
Don't believe me for speed? Just watch our rear data center. It displays the robot's overall vector velocity in ft/sec by default in teleoperated mode.
-q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 25-03-2008, 17:03
Billfred's Avatar
Billfred Billfred is offline
For us, it was AndyMark Super Shifters and 6WD. Off the gearbox, we went 24:22 (or was it 25:22?) to skinned-and-treaded AM FIRST wheels (diameter about 5.5" in the end). I realize it's a little counterintuitive to gear back up in chain and sprockets, but it was a little cheaper than fiddling with extra shafts and we wanted to use the onboard encoder. The end result was around 13 fps (could've sworn it was 14, though a re-check of the spreadsheet says otherwise), enough to be one of the fastest robots at Chesapeake*.
*We thought we were doing well to get seven laps in a match. Then, after packing up and sitting down to watch eliminations, 2016 goes and clocks nine. Showoffs.
Unread 25-03-2008, 17:42
run the trap!!!
Team Role: Human Player
I'd venture to say that teams 254 and 968 have the fastest drivetrains this year; both in terms of max speed and acceleration. They are running 4 CIMs and 2 FPs through a modified AM transmission.
254's robot was so fast at SVR that it was actually hard for their drivers to control it. After they removed the FP's it became more controllable and their game-play improved.
As for us, I can tell you were not going to do 2 CIMs again. Acceleration is horrible.
-Philip J. Fry
Unread 25-03-2008, 17:55
DarkFlame145 DarkFlame145 is offline
That guy
AKA: Dennis
no team (None this season)
DarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud ofDarkFlame145 has much to be proud of
Send a message via AIM to DarkFlame145
4 CIM motors 2 in each KoP gearbox with a 4X4 tank drive IFI 2 inch wide traction wheels. 2 up front, 2 in the mid, and ball casters in the back.
TR-X 145 of Norwich, NY: Student 2005-2008
Exploding Bacon 1902 of Winter Park, FL: Mentor 2009
US Navy Corpsman 2011-????
How Are The Rookies Doing Justin1636 General Forum 3 28-03-2005 00:40
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
Registration Open - How are we doing? Andrew General Forum 83 06-01-2004 13:22
How are your Drivers and Human players doing????????? archiver 2001 2 24-06-2002 00:33
how are the teams doing so far? archiver 2001 7 23-06-2002 23:37
