Go to Post As usual, I mistakenly look for a technical solution to a social problem. - MrForbes [more]
Unread 25-03-2008, 09:49
CraigHickman
Posts: n/a
pic: Coax Crab, another variation.
Unread 25-03-2008, 09:57
SgtMillhouse648's Avatar
SgtMillhouse648 SgtMillhouse648 is offline
AKA: Malhon Godwin
FRC #0648 (QC Elite)
SgtMillhouse648 has a spectacular aura aboutSgtMillhouse648 has a spectacular aura about
Send a message via MSN to SgtMillhouse648
Re: pic: Coax Crab, another variation.
looks very nice! what are you making the yokes out of that hold theh wheels? This looks very similar to our setup, and we made our yokes out of .25" steel plate, and had numerous problems with them bending right below the uppermost axle. There are 2 ways around this:
1: Go to more of a wildstang setup and support the system on the bottom as well
2: Run a pair of straps around the wheel right where the lower axle is. This would join the forks together, and give you more support on the bottom side where it would be prone to bending
Also, how do you plan on on tightening the chain to drive the wheels themselves, or do you plan on using spur gears like the beast does?
I would personally swap your setup between the steering and the drive: aka, use the timing belt for the drive of the wheels, and the chain for the steering, but that's just my opinion. Good Job, that is a real nice looking setup though.
Malhon
Midwest Regional-
Regional Finalists with 1000 and 447
Rockwell Automation Inspiration in Control Award
Regional Woodie Flowers - Ed Wegscheid
Unread 25-03-2008, 11:08
CraigHickman
Posts: n/a
Malhon
About bending of the wheel forks: There are three standoffs there, not easily visible. The whole thing would be made of 1/4inch hard anodized 7075, so it'd be pretty strong.
As for tensioning, ever seen 118? Floating idler is all I have to say.
Unread 25-03-2008, 11:31
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
I used a floating Idler before after seeing one in one of 118's videos and it worked great, my mentor looked at me and said "how the heck is that gonna work" and I replied just watch. But, yeah nice cad work. Are you only using one motor to turn all of the modules. If so how do you steer or is it that you don't?
-Dustin Benedict
Unread 25-03-2008, 12:10
Vikesrock's Avatar
Team 2175 Founder
AKA: Kevin O'Connor
The robot can't rotate, which is why he said it would need a turreted manipulator
Unread 25-03-2008, 12:44
CraigHickman
Posts: n/a
Yep.
Yeah, the floating idler is pretty awesome. I do, however, have a backup tensioner designed in case the floating one doesn't work.
Unread 25-03-2008, 15:09
AKA: Malhon Godwin
I think you misunderstood me on the tensioning. Let me see if I understand how this works correctly to drive the wheels:
1: motor turns chain which powers the drive sprockets on top of modules
2: drive sprockets turn a shaft going through the center of the module which has a bevel gear on the other end
3: bevel gear meshes with another bevel gear, turning the rotation along the vertical axis to the horizontal axis
4: This second bevel gear powers a chain drive which goes down the interior of the module directly to the wheel.
I realize how easy it is to keep tension on the 1st step, what I am worried about is in the 4th step, especially if you are using #25 chain. With #35, you don't have near as big of problem, but there's still a problem.
Nice work though.
Malhon
Midwest Regional-
Unread 25-03-2008, 15:18
run the trap!!!
Team Role: Human Player
Why the massive wheels?
-Philip J. Fry
Unread 25-03-2008, 18:25
CraigHickman
Posts: n/a
Nice work though.
Malhon
Ah. It's close enough to not need tensioning, and may even be changed to use kevlar belting if I ever end up making the thing.
They're not massive, they're only 4 inches in diameter, and 2 inches wide. The whole robot actually isn't that big...
Unread 25-03-2008, 21:04
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
FINALLY! I've been asking you for quite a while for your version of the 118 Crab and I finally got it! Awesome job!
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 25-03-2008, 21:46
run the trap!!!
Wow! That is small. Looked more like 6" to me.
-Philip J. Fry
Unread 25-03-2008, 22:44
CraigHickman
Posts: n/a
Yeah, the whole robot is only 26x26, and about 10ish inches tall. It's really quite small.
And yes, Pavan, this is ONE of my 118 type crabs. There are more. IM me sometime and I'll send you a render of another one.
Unread 26-03-2008, 00:24
AKA: Malhon Godwin
Ok, good to know, If you do plan on making it sometime, 648 used a similar setup as far as the individual crab modules go. The whole yoke was extremely tight clearance. The bevel gear cleared the tread on the wheel by about 1/16", and we had a real PITA trying to tighten up the chain. What we ended up doing though worked pretty slick once it was set. In our setup, the bearings which you have on the yokes, were actually on the wheels, and the sprocket was bolted to the wheel. This let us mill a slot where you currently have your bearings, and attach a small threaded block to which had a bolt and jamb nut in it. The axle was milled flat at each end, and the bolt was tightened down equally onto the axle on each side until the chain tightened. It worked real slick. 1625 had a similar crab setup, but used a small cam tightener to tighten the chain. Needless to say, some sort of chain tightening device is a necessity if it is to see the floor.
Malhon
Midwest Regional-
Unread 27-03-2008, 10:30
Richard McClellan's Avatar
Richard McClellan Richard McClellan is offline
Engineering Mentor
FRC #0254 (Cheesy Poofs)
Richard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud ofRichard McClellan has much to be proud of
Send a message via AIM to Richard McClellan
Nice work though.
Malhon
Is there any reason to use chain in the 4th step instead of two spur gears? Seems like gears might be more reliable option to connect two shafts that are so close together. But, I've never built a crab drive system.
~ Richard McClellan ~
Former Student on 1477 | Northside Roboteers | 2004-2005
Former Lead Mentor for 2158 | ausTIN CANs | 2007-2010
Current Mentor for 254 | Cheesy Poofs | 2013
Unread 27-03-2009, 13:51
BenX02's Avatar
BenX02 BenX02 is offline
FRC #2655 (The Flying Platypi)
Team Role: Driver
BenX02 has a spectacular aura aboutBenX02 has a spectacular aura about
I just love crab drive, and I'm thinking of designing my own for our team next year, but I'm not sure I completely understand the concept. Do you think you could maybe give me a short explanation of the basics.
Also, how many CIMs are on there? It looks like four on just the one side, and if so is it possible to use less?
pic: Coaxial Crab CraigHickman Extra Discussion 14 15-11-2007 16:44
pic: Crab Drive Joe_Widen Extra Discussion 3 23-04-2006 15:49
pic: Tytus's Coax Crab Module CD47-Bot Robot Showcase 8 17-11-2003 10:08
pic: Crab Concept 6 CD47-Bot Extra Discussion 13 14-11-2003 22:03
pic: Tytus Coax Crab Fender CD47-Bot Extra Discussion 9 28-09-2003 00:17
