Go to Post "FIRST is like a pizza, we all think different toppings should be on it" - Andrew Schreiber [more]
Unread 25-03-2008, 11:33
ALIBI's Avatar
ALIBI ALIBI is offline
FRC #0141
Team Role: Parent
ALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to allALIBI is a name known to all
Re: Drivetrains - How are you doing it?
Team 141 is using two cims per side with direct drive via timing belts driving custom six inch wheels. The reduction is around three to one, I do not know the exact numbers. In theory we can run 18-20 fps. When the drivers decide to run laps we can usually turn them in seven to eight seconds on a full field provided there are big enough openings on the field that we can get through. As long as there are openings we have been able to get through them without slowing down significantly.
How Are The Rookies Doing Justin1636 General Forum 3 28-03-2005 00:40
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
Registration Open - How are we doing? Andrew General Forum 83 06-01-2004 13:22
How are your Drivers and Human players doing????????? archiver 2001 2 24-06-2002 00:33
how are the teams doing so far? archiver 2001 7 23-06-2002 23:37
