Go to Post Remember, FIRST is merely a means to an end - the end result being that we completely change the world for the better. - RogerR [more]
  #76   Spotlight this post!
Unread 25-03-2008, 13:56
Racer26 Racer26 is offline
Re: Hybrid Challenge-No Robot Left Behind
I liked 188's strategy against 1114's auto too.
GDC says no defensive auton. 188 makes their auton get 1 line (therefore not being "defensive") and parks right in 1114's path.
  #77   Spotlight this post!
Unread 25-03-2008, 13:58
T3_1565 T3_1565 is offline
AKA: Twitch Drive Designer
FRC #1360
T3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant futureT3_1565 has a brilliant future
Send a message via MSN to T3_1565
we had 1558 try that against 1114 as well (well it was four sec pause then drive to one line) but that failed... horribly...
But they moved!! and thus, keeps another robot from being left behind!!
  #78   Spotlight this post!
Unread 25-03-2008, 14:35
BLCamp BLCamp is offline
question everything
FRC #0079 (KRUNCH)
BLCamp is a splendid one to beholdBLCamp is a splendid one to beholdBLCamp is a splendid one to beholdBLCamp is a splendid one to beholdBLCamp is a splendid one to beholdBLCamp is a splendid one to beholdBLCamp is a splendid one to beholdBLCamp is a splendid one to behold
Of course, there are some teams that figured other robots might get in the way so they incorporated some collision avoidance, http://www.youtube.com/watch?v=6qrNdDw-YrM
Brian
  #79   Spotlight this post!
Unread 25-03-2008, 14:54
Wow... thats impressive, 79. I know 1114 was trying to do something similar, but that system sure works nice.
  #80   Spotlight this post!
Unread 25-03-2008, 15:42
bcieslak
Posts: n/a
Go to team 1675's website (www.team1675.com) and check out the autoflex program they have that will allow your drivers to train the robot to perform during the 15 second autonomous period..even better than just driving straight.
BC
  #81   Spotlight this post!
Unread 25-03-2008, 16:07
bcieslak
Posts: n/a
Originally Posted by ShotgunNinja View Post
Well, my team has shown that they wanted to go with the IR sensor controller, maybe using a TV/VCR remote. But I am in charge of the programming, and I was wondering...
Would something like this (Using ROBOTC) be usable?
task Autonomous()  { // Note: Just pseudocode, but whatever
while (bIfiAutonomousMode) /* Just in case... */
   switch(GetIRInputState()) /* Get the state of the IR sensor, in a different subroutine */
      case Button1:
         Action1; // Something like "Move forward, stop"...
      case Button2:
         Action2; // Maybe "Turn Left"
      case Button3:
         Action3; // Maybe "Turn Right"
      case Button4:
         Action4; /* Something along the lines of: "Grab ball off overpass, however possible" */
      default:
         TakeNoAction; // Just "Stop Motors" or something
   BetweenActions; // Something like "Stop Motors, Wait XX MS"
EndingAction; /* Play a sound or something. Reset motors for Human Control. Etc. */
Any comments?
You should look into using pointers to functions...it makes what your trying to do real simple...When you press a button, change the pointer to a function to the new behavior function..In your autonomous_routine just call the pointer as if it were the function. I
first decalre a couple of simple functions like: (fill in the code)
void drive_fwd(void);
void drive_bwd(void);
void turn_left(void);
void turn_right(void);
then declare a function pointer:
void (*auto_function)(void); the splat in the parens make a function pointer.
Note the format of the prototype and the fucntion pointer is the same, for the pointer replace the function name with the (*pointer_name)
Now use your code to read the IR board
but the action would assign a fucntion to the pointer.
case Button1:
auto_function = drive_fwd;; // Something like "Move forward, stop"...
case Button2:
auto_function = drive_bwd;; // Maybe "backwards"
case Button3:
auto_function = turn_left; // Maybe "Turn left"
case Button4:
auto_fucntion = turn_right; /* Something along the lines of: "Grab ball off overpass, however possible" */
default:
then by calling auto_function just as if it were a function it will perform the function you assigned to it.
auto_function(); // do what it assigned to the pointer. call this in the autonomous loop.
The function pointer will stay the same until you change it with the IR board.
BC
  #82   Spotlight this post!
Unread 25-03-2008, 16:18
Doug Leppard's Avatar
Doug Leppard Doug Leppard is offline
FRC #1902 (Exploding Bacon)
Doug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond reputeDoug Leppard has a reputation beyond repute
Send a message via AIM to Doug Leppard
Brian
We had no idea you guys were doing that, way to go very impressive.
We considred it and have the sonar up front but didn't implement it. we may still consider it.
Doug Leppard
  #83   Spotlight this post!
Unread 26-03-2008, 14:48
team2061's Avatar
team2061 team2061 is offline
Gilberto Gonzalez
AKA: team 2061 captain/mechanical
FRC #2061 (PIONEERS)
team2061 will become famous soon enoughteam2061 will become famous soon enough
Originally Posted by Doug Leppard View Post
We have easyc and were able to cross 5 lines in hybrid mode.
BUT, we have encoders and gyro and a pretty sophisticated way point software we developed over the weeks. All that would be too hard for you to start now, but with easyc you can quickly develop the ability to cross two lines for 8 points.
First of all about your robot. What sensors do you have? Do you have wheel encoders or fear counter to tell how far you have gone? Do you have the gyro onboard?
No we were unable to put encoders on our bot
2007 Las Vegas Highest Rookie Seed Award
2007 Las Vegas Regional Quater-Finalist
2007 Las Vegas Best Rookie Award provided by team 1547 Where's Waldo
2007 Las Vegas Regional Rank 7 of 51 teams, 2nd Seed
  #84   Spotlight this post!
Unread 26-03-2008, 21:51
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
done,
flint rookie pilot, our programer wrote another alliance member team's hybrid code for them or improved it, but we all crossed 1 line in hybrid.
Is now an engineer thanks to FIRST.
  #85   Spotlight this post!
Unread 01-04-2008, 16:46
One story of "no robot left behind".
At each regional we have helped several robot teams. At our last match at Bayou I visited our partners trying to make sure their auto mode would not run into us. Neither team had an auto mode so I sent our lead programmer to work with them.
He got both of them going with a basic go straight and make 4 points after a three second delay.
Both of their auto modes worked each getting 4 points. They were excited because it was the first time they had an auto mode that worked. As it turned out we won by 6 points and without their 8 points we would have lost. That win ended putting us in the top 8 and allowed us to pick our partnership. So it was a win for all!
Doug Leppard
  #86   Spotlight this post!
Unread 01-04-2008, 19:53
Tottanka's Avatar
Tottanka Tottanka is offline
It isnt about bots,its about humans
AKA: Liron Gurvitz
FRC #3211 (The Y Team)
Tottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond reputeTottanka has a reputation beyond repute
That is a great story! good job guys =]
Oink Oink...
My FRC record: 10 Years,FTA (2008-9), 3 Teams(1947,2669,3211).3 RCA, 1 Championship EI(2016), 1 Divisional finalist (2016), 1 Regional winner.
Israeli 2016 Volunteer of the year.
Left behind??? A scary story... meaubry Championship Event 4 04-04-2007 21:32
Left or right handed robot? DjAlamose General Forum 13 06-02-2006 15:51
Robot veers left when driving backwards! xxmaddjxx Technical Discussion 3 19-02-2005 04:57
Pa robot challenge Dave_222 Off-Season Events 77 16-01-2004 22:18
PA Robot Challenge VI cbudrecki Off-Season Events 1 29-03-2003 22:19
