Go to Post Personally, i dont see a problem, If it comes down to esentially building a computer just to run the field then that is what we will have to do, the show must go on. - Dave_222 [more]
Unread 25-03-2008, 18:15
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Re: Drivetrains - How are you doing it?
48 currently runs one A-M SuperShifter powered by 2 CIM's direct driving a 4" Brecoflex halftrack pulley on each side of the bot. Tread thickness adds .25" x 2 to that to yield a total driven wheel diameter of about 4.5".
Custom 25T:40T final drive gear ratio yields theoretical 16.2 fps in high gear per JVN's spreadsheet. No load taching of the right side gearbox output in the pit yielded 770 RPM or roughly 15.11 fps. Obviously actual performance is somewhat south of that, but it's still fast enough for our liking!
When we added the gearbox mods in Pittsburgh, the right side drivetrain gave us problems with breaker popping until we cleaned and realigned the boxes. We ran well with no major problems at Buckeye (at least in teleop mode). We were one of the fastest and most productive lappers at the event. The halftracks (with four passive outbound omnis providing stability) turn beautifully and provide excellent straight-line control.
Unread 28-03-2008, 09:12
ks_mumupsi ks_mumupsi is offline
Drive Coach...
AKA: Kinsuk Shah
None #2016
ks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud ofks_mumupsi has much to be proud of
Originally Posted by Billfred View Post
*We thought we were doing well to get seven laps in a match. Then, after packing up and sitting down to watch eliminations, 2016 goes and clocks nine. Showoffs.
Ya, we have done surprisingly well with custom gearboxes. We used two CIM motors on a 3.57:1 Gear reduction. Same as an AM Stackerbox.. but this is a double motor stackerbox.
How Are The Rookies Doing Justin1636 General Forum 3 28-03-2005 00:40
What Motors/Drivetrains are YOU using? IA-Howitzer Motors 16 27-02-2005 15:01
Registration Open - How are we doing? Andrew General Forum 83 06-01-2004 13:22
How are your Drivers and Human players doing????????? archiver 2001 2 24-06-2002 00:33
how are the teams doing so far? archiver 2001 7 23-06-2002 23:37
