Go to Post One career isn't really more prestigious than another; not in and of itself. More than anything it depends on what you do with it. - Matt Leese [more]
Unread 26-03-2008, 00:20
Aren_Hill's Avatar
Build Nifty Things
Re: pic: 1625's swerve module (better pic)
Originally Posted by Peter Matteson View Post
You're the only other team I've seen do welded tube construction wheels. I thought we were alone with that because everyong else seems to hog them out of a billet.
these are faster to make and are also most likely lighter and stronger in the places the force is applied.
its really easy to just waterjet the sideplates and weld them on, these wheels are 1.75" wide
Originally Posted by thefro526 View Post
I like how you used snap-rings instead of collars. That has to save a lot weight.
I LOVE SNAP RINGS!!! lol also the custom 7068 hex axles....not overkill at all...
A guy who likes robots.
Unread 26-03-2008, 07:22
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Same reason we do wheels out tube and plate welded together.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 26-03-2008, 10:01
AdamHeard's Avatar
Lead Mentor
How easy is it to hold the plates and tube concentric while rounding?
If it is just standard Al tube, how thick are the walls and how true to round is the outer surface?
Unread 26-03-2008, 10:07
We cut a relief pocket in the plate so that it over hangs the tube and tube literally snaps into the plate. This gives us wheels as close to concentric as possible to make. I'll dig up some pictures and grab a few of the evolution of the design when I'm at the shop today so you can see what I mean.
Pete
Edit:
http://www.chiefdelphi.com/media/photos/31104?
http://www.chiefdelphi.com/media/photos/31105?
http://www.chiefdelphi.com/media/photos/31102?
http://www.chiefdelphi.com/media/photos/31103
Pictures now up.
End Edit
Thank-you 294 & 67
Unread 26-03-2008, 12:09
Aren_Hill's Avatar
Build Nifty Things
We just used 4" o.d. 1/8th wall tube, and waterjetted the sideplates, due to the nature of a waterjet it puts a slight taper on things so when i had it make a
3.75 o.d. disc it pressed right into the side of the tube and held itself there solidly while it was welded.
they're as concentric as you'll ever need for wheels.
Unread 26-03-2008, 12:54
sdcantrell56's Avatar
AKA: Sean
FRC #2415 (Wired Cats)
How are you keying the wheel to the axle. I'm planning on using that type of wheel next year and just looking to compare ideas
Mentor 2415
Unread 26-03-2008, 14:12
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
how is the lower plate supported? I know it used as a bearing surface, but it is sandwiched between plates or riding on small ball casters. I have always wondered how this work with swerve modules, I understand the rest of it but the lower support plate is the only gap in my limited knowledge of drive systems(I don't go into the kinematics...yet).
Unread 26-03-2008, 14:30
hillale's Avatar
hillale hillale is offline
Formerly a Winnovator
AKA: Alec Hill
FRC #3617 (Cold Logic)
hillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to beholdhillale is a splendid one to behold
Send a message via AIM to hillale
The lower plate isn't necessarily a support plate, just a bearing surface like you said. Due to the nature of friction, it does a little support, but mainly it just rubs against flat plastic patches (lubed up to reduce friction) on the frame to aid in steering the modules. The face of the contact between the plastic and the plate is purely vertical. No horizontal contact is made between the plate and the frame. It is welded, in the corners, to the square tube that makes up the vertical body of the module.
Unread 31-03-2008, 03:21
Un Luchador's Avatar
Un Luchador Un Luchador is offline
Electricity is my pastime
AKA: Gustavo
FRC #2543 (TitanBot)
Team Role: Electrical
Un Luchador is an unknown quantity at this point
Send a message via MSN to Un Luchador
With such an effective drivetrain, it's no wonder you guys went undefeated at Colorado. I love the way you guys keep the robot chassis facing forward through the match, but still have the swerve function to put you back into position. That's very innovative.
Keep up the hard work and military-like competing guys.
Unread 31-03-2008, 06:29
Jimmy Cao Jimmy Cao is offline
AKA: Jimmy Cao
Jimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant futureJimmy Cao has a brilliant future
That module looks very simular to our initial idea, except we were putting the motor/transy inside the module itself.
It's very nice looking =D
Jimmy Cao
Team 469 2006-2010 Student/Alumni
Team 830 2011-2012 Mentor
Unread 31-03-2008, 09:59
hillale's Avatar
AKA: Alec Hill
That's what we did last year, we had a cim mounted vertically through a dewalt on each of the modules. This coaxial design made maintenance much easier (though it has gone through 3 regionals and hasn't broken once). Here is a pic of our underbelly, http://www.chiefdelphi.com/media/photos/28596. I guess we don't have a closeup of the module from last year.
Unread 15-04-2008, 13:31
Aren_Hill's Avatar
Build Nifty Things
This guy weighs in at 2lbs 14oz and i coulda taken a couple more ounces out of the steel sprockets. Lighter than last years
Unread 15-04-2008, 16:42
in between teams
AKA: Luke Van Oort
Have you thought about going to aluminum drive sprockets to save a touch more weight?
This guy module weighs in at 2lbs 14oz
Is there a girl module?
Team 1219: 2009 - Mentor
Unread 15-04-2008, 17:38
Aren_Hill's Avatar
Build Nifty Things
Yes i have but during the season i was too busy to find a supplier or someone to have them made.
Unread 15-04-2008, 17:37
CraigHickman
Posts: n/a
This guy module weighs in at 2lbs 14oz and i coulda taken a couple more ounces out of the steel sprockets. Lighter than last years
Hm, you should switch to Kevlar belting and aluminum pulleys. Then this setup would be truly frighteningly light. Out of curiosity, how many teeth does your steering sprocket have? I'm currently designing a bottom support crab, so I can finally post one that doesn't get hit with the "you're not supporting it right" complaint.
pic: Team 148 Robowranglers: Swerve Module and Motors Brandon Martus Robot Showcase 27 24-02-2008 22:29
pic: 1625's arm control Aren_Hill Extra Discussion 9 15-10-2007 11:55
pic: stangs swerve module Aren_Hill Extra Discussion 8 23-04-2007 08:15
Swerve Module Question adlai Technical Discussion 8 03-04-2007 21:20
pic: Swerve! (Module) =Martin=Taylor= Extra Discussion 13 09-07-2006 19:57
