Re: pic: 1625's swerve module (better pic)
Same reason we do wheels out tube and plate welded together.
If it is just standard Al tube, how thick are the walls and how true to round is the outer surface? |
Pete Edit: http://www.chiefdelphi.com/media/photos/31104? http://www.chiefdelphi.com/media/photos/31105? http://www.chiefdelphi.com/media/photos/31102? http://www.chiefdelphi.com/media/photos/31103 Pictures now up. End Edit Last edited by Peter Matteson : 27-03-2008 at 09:31. |
3.75 o.d. disc it pressed right into the side of the tube and held itself there solidly while it was welded. they're as concentric as you'll ever need for wheels. |
How are you keying the wheel to the axle. I'm planning on using that type of wheel next year and just looking to compare ideas
how is the lower plate supported? I know it used as a bearing surface, but it is sandwiched between plates or riding on small ball casters. I have always wondered how this work with swerve modules, I understand the rest of it but the lower support plate is the only gap in my limited knowledge of drive systems(I don't go into the kinematics...yet).
#7
With such an effective drivetrain, it's no wonder you guys went undefeated at Colorado. I love the way you guys keep the robot chassis facing forward through the match, but still have the swerve function to put you back into position. That's very innovative.
Keep up the hard work and military-like competing guys. |
#9
That module looks very simular to our initial idea, except we were putting the motor/transy inside the module itself.
It's very nice looking =D |
#10
This guy weighs in at 2lbs 14oz and i coulda taken a couple more ounces out of the steel sprockets. Lighter than last years
#12
Is there a girl module? ![]() |
#13
Yes i have but during the season i was too busy to find a supplier or someone to have them made.
#14
Aren, do you have a white paper on this, or at least a picture of the other side of this assembly showing the bevel gears?
I got to see this up close at IRI, & was very impressed. Not only did it perform great on the field, but it was relatively lightweight for what it consists of. I'm trying to convince my teammates to experiment with as many drive trains as possible over the summer with our upcoming test chassis, & want to show them this one as a great example of swerve assembly. |
#15
Hm, you should switch to Kevlar belting and aluminum pulleys. Then this setup would be truly frighteningly light. Out of curiosity, how many teeth does your steering sprocket have? I'm currently designing a bottom support crab, so I can finally post one that doesn't get hit with the "you're not supporting it right" complaint.
| pic: Team 148 Robowranglers: Swerve Module and Motors | Brandon Martus | Robot Showcase | 27 | 24-02-2008 22:29 |
| pic: 1625's arm control | Aren_Hill | Extra Discussion | 9 | 15-10-2007 11:55 |
| pic: stangs swerve module | Aren_Hill | Extra Discussion | 8 | 23-04-2007 08:15 |
| Swerve Module Question | adlai | Technical Discussion | 8 | 03-04-2007 21:20 |
| pic: Swerve! (Module) | =Martin=Taylor= | Extra Discussion | 13 | 09-07-2006 19:57 |
