Go to Post When fun is outlawed, only outlaws will have fun. - Gadget470 [more]
Unread 26-03-2008, 11:47
Molten's Avatar
Molten Molten is offline
AKA: Jason
FRC #1766 (Temper Metal)
plasma cutter/liquid nitrogen
Is it possible to combine the two? Would it cause an explosion. Plasma is technically just super-heated particles, so could you super heat liquid nitrogen to turn it into plasma? Would it still have it's freezing effect? Just curious about this. Seeing as nobody will give me liquid nitrogen or a plasma cutter to play with, I was wondering if anyone knew any of these answers.
"Curiosity. Not good for cats, great for scientists."- Numb3rs
"They can break your cookie, but... you'll always have your fortune."-T.W. Turtle, Cats Don't Dance
"Tell my tale to those who ask. Tell it truly - the ill deeds along with the good, and let me be judged accordingly. The rest... is silence."-Dinobot, Beast Wars
"Though the first step is the hardest and the last step ends the quest, the long steps in between are certainly the best."
–Gruffi Gummi, Disney's Adventures of the Gummi Bears
Unread 26-03-2008, 12:06
REVving up for a new season
FRC #2848 (All-sparks)
Re: plasma cutter/liquid nitrogen
the simple answer is no It won't explode. Liquid nitrogen is just nitrogen that is in it's liquid state. I know that seems like circular logic but basically if you super heated liquid nitrogen you would just get hot nitrogen.
I don't know the specifics of making something plasma but my guess would be no considering Nitrogen is an inert gas.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 26-03-2008, 12:16
Jeff Pahl's Avatar
Jeff Pahl Jeff Pahl is offline
likes to look at shiny things...
FRC #5148 (New Berlin Blitz)
Jeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond reputeJeff Pahl has a reputation beyond repute
At the temperatures involved with plasma cutting of 10,000 degrees C or greater, the liquid nitrogen would become gaseous nitrogen very quickly.
From http://www.mwsco.com/kb/kb_frameset.asp?ArticleID=64 which is a pretty good explanantion of the plasma cutting process: "The different gases used for plasma arc cutting include nitrogen, argon, air, oxygen, and mixtures of nitrogen/hydrogen and argon/hydrogen." So yes, you can use straight gaseous nitrogen for plasma cutting, although most of the "garden variety" units I have used over the years have used plain compressed air (which is still mostly nitrogen). The other gasses tend to be used for specialized applications.
Team 5148 - 2014 Wisconsin Regional Rookie All-Stars!!
Mentor: 1379: 2004-2008 / 2530: 2008-2013 / 2861: 2009 / 5148: 2014-??
Lead Robot Inspector: 10,000 Lakes '09 - '11 / Lake Superior '11-'12 / Northern Lights '13, '15 - '16 / Championship '09 - '12, '14 - '15
Attending/Inspecting 2017: TBD, Wisconsin, STL Championship
"Sometimes the questions are complicated and the answers are simple" -Dr. Seuss
gas nitrogen springs comwiz7 Pneumatics 3 12-01-2008 21:42
Making a plasma cutter go. Madison Technical Discussion 1 08-11-2006 16:34
Plasma Cutter M. Enns Technical Discussion 7 17-12-2005 21:49
pic: Sheet steel resting on CNC plasma cutter Jay H 237 Extra Discussion 3 11-01-2005 05:46
Liquid Nitrogen Ice Cream Ian W. Chit-Chat 12 11-08-2002 19:05
