Go to Post Admiration is universal, it does not exclude those who have achieved past success. - hg273 [more]
  #76   Spotlight this post!
Unread 18-03-2008, 16:35
llama llama is offline
AKA: Michael Goelz
FRC #2077 (Kettle Moraine Robotics/Laser Robotics)
llama is an unknown quantity at this point
Send a message via AIM to llama
Re: surefire ways to break you robot
allow your mentor to have a doctor pepper in the pit... ours did and he spilled it on the control board....it wouldn't have been too bad had he not immediately assumed that we had wired the robot incorrectly and spent 2 hours yelling at us to fix it and burning out our lift motor in the process
  #77   Spotlight this post!
Unread 19-03-2008, 03:22
comphappy comphappy is offline
AKA: Brennan Ashton
FRC #2605 (A2D_16)
comphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to beholdcomphappy is a splendid one to behold
Send a message via AIM to comphappy
We dont have much in the way of mentors to start with, and they certainly dont tell us what to do. I think it is better that way.
A2D Solving the Imaginary Error Function...
  #78   Spotlight this post!
Unread 19-03-2008, 10:41
A_Reed's Avatar
A_Reed A_Reed is offline
Lead Design Mentor
AKA: Adam Reed
FRC #0048 (Delphi E.L.I.T.E)
A_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to beholdA_Reed is a splendid one to behold
Keep it on display for a few years and then tell a freshman to reference an old design. They end up taking it apart and not knowing how it goes back together.
  #79   Spotlight this post!
Unread 24-03-2008, 00:00
BordomBeThyName's Avatar
BordomBeThyName BordomBeThyName is offline
AKA: Matt Golman
FRC #2102 (Team Paradox)
BordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant futureBordomBeThyName has a brilliant future
Build a robot.
Try to replace your transmission 30 seconds before a semifinals match.
Hold said transmission on with zipties.
Allow your robot to watch 330 and 1717 be on an alliance together.
Forget to add the line of code that makes the lead screw stop spinning when it gets to the limit switch.
Founder -> Build VP -> President -> Drive Team Mentor
  #80   Spotlight this post!
Unread 24-03-2008, 00:10
run the trap!!!
Team Role: Human Player
Register for the Davis Regional Defense is rough there
Brag about how your robot hasn't broke yet this season. Ours hasn't... oops do'h!
-Philip J. Fry
  #81   Spotlight this post!
Unread 24-03-2008, 00:27
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Design the entire robot to be held together using 6/32 screws*.
* 6/32 is usually the most commonly broken tap in machine shops (followed by 10/24), due to the ratio between the diameter and the number of threads per inch. I despise 6/32 with a passion and will avoid it at all costs, whether it means shrinking down to a 4/40 or increasing to an 8/32.
Art Dutra IV
世上无难事,只怕有心人.
  #82   Spotlight this post!
Unread 24-03-2008, 00:46
lasereyes's Avatar
lasereyes lasereyes is offline
College Student Mentor
AKA: Farzin Fatollahi-Fard
FRC #2551 (Penguin Empire)
lasereyes is an unknown quantity at this point
Send a message via AIM to lasereyes
We did both. This is totally true!
a) We went to Davis.
b) After the first day, we bragged about how our arm hadn't broken or been damaged. The next day, we rammed a wall and our arm got badly damaged (luckily we had all of lunch to fix it).
FRC #2551 (FTC #646): Penguin Empire
2008 Rookie Team
2008 UC Davis Sacramento Regional Finalists (thanks to 1388, 1072, and 2390)
2008 UC Davis Sacramento Regional Highest Rookie Seed (#2!)
  #83   Spotlight this post!
Unread 26-03-2008, 14:18
A_Reed's Avatar
Lead Design Mentor
AKA: Adam Reed
Rely on COTS parts that are meant for industrial purposes.
In buckeye the steel cables(inner core) in our Brocoflex belts mysteriously fell apart after one match and the only thing holding them together was a thick layer of red linatex rubber.
  #84   Spotlight this post!
Unread 26-03-2008, 14:23
BornaE's Avatar
BornaE BornaE is offline
FRC #0842 (Formerly 39)
BornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant futureBornaE has a brilliant future
Program the robot to intialize with all the pwm at 254 and all the realys on for hybrid mode.
Then put the robot in hybrid w/o unplugging the prgraming cable, or tether cable
-Borna Emami
Team 0x27
  #85   Spotlight this post!
Unread 26-03-2008, 14:26
XXShadowXX's Avatar
XXShadowXX XXShadowXX is offline
They call me Cody.
no team (None currently :\)
XXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud ofXXShadowXX has much to be proud of
-have a novice programmer program hybrid, he believes that 0 is neutral
-let some one with no programming experience program robot
-have a programer try to fix the robot
-have driver fix the robot
-fix robot on the field
-field the robot after using any of these words in staging or in the stands before you go on.
--should, work
--watch, this
--got it all working
--will, work
--your sponsoring us?
--you want to sponsor us?
--i double checked everything
--those pwm's arn't going any were
lastly attach anything with loktite it will have to be removed right after the loktite sets
Is now an engineer thanks to FIRST.
  #86   Spotlight this post!
Unread 26-03-2008, 14:31
Rupnick's Avatar
Rupnick Rupnick is offline
FRC #1675 (UPS - Ultimate Protection Squad)
Rupnick is on a distinguished road
Send a message via AIM to Rupnick
try using a little baby motor to lift a lift with so much friction that your operating at roughly 10% efficiency.
  #87   Spotlight this post!
Unread 27-03-2008, 11:13
jacob07's Avatar
jacob07 jacob07 is offline
AKA: Jacob
FRC #0397 (Knight Riders)
jacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to beholdjacob07 is a splendid one to behold
Send a message via AIM to jacob07
330 had an incident where a programming mentor was the only one in the shop and broke the robot. It was minor--an output gear on a redundant motor--but still...
Programmers....what shall we do with u?
  #88   Spotlight this post!
Unread 27-03-2008, 15:56
lasereyes's Avatar
Easy: Let us do our work so you guys can win.
2008 Rookie Team
  #89   Spotlight this post!
Unread 27-03-2008, 16:00
Just don't do our work (building/breaking) for us, OK?
  #90   Spotlight this post!
Unread 27-03-2008, 16:06
lasereyes's Avatar
We try our best not to...
2008 Rookie Team
MOEmentum FYI 2008 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 0 03-02-2008 16:37
pic: strange ways you test stuff out? DarkFlame145 Robot Showcase 1 13-01-2008 15:10
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat" Mr MOE General Forum 6 09-02-2007 08:40
What do you do when its time to take a break from building?? Leo 1529 Chit-Chat 23 13-02-2006 00:26
MOEmentum: Week 5 - "Break Robot. Re-engineer. Repeat." Mr MOE General Forum 3 15-02-2005 11:38
