Go to Post When I mentor other people in programming... they either get pointers or they don't. - JamesTerm [more]
  #46   Spotlight this post!
Unread 18-05-2007, 23:08
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: How to lose 6 pounds in 8 hours
Last year was the only time we actually had a weight problem
In 2005 we were over 10 lbs under and threw a massive block of steel on the bottom of our robot to lower the CG and counterbalance the arm
  #47   Spotlight this post!
Unread 20-05-2007, 00:04
jgannon's Avatar
jgannon jgannon is offline
I ᐸ3 Robots
AKA: Joey Gannon
jgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond reputejgannon has a reputation beyond repute
Structural integrity is not the only way that speed holes can come back to bite you. Today at Monty Madness, a team had some speed holes that were maybe 2" diameter drilled into the middle of their platform. The team that climbed onto them had omni wheels, and one of their rollers went down into the hole. This was the only part of the lifted robot that came in below 12", and the 15 points made the difference in the match.
Team 1743 - The Short Circuits
2010 Pittsburgh Excellence in Design & Team Spirit Awards
2009 Pittsburgh Regional Champions (thanks to 222 and 1218)
2007 Pittsburgh Website Award
2006 Pittsburgh Regional Champions (thanks to 395 and 1038)
2006 Pittsburgh Rookie Inspiration & Highest Rookie Seed
Team 1388 - Eagle Robotics
2005 Sacramento Engineering Inspiration
2004 Curie Division Champions (thanks to 1038 and 175)
2004 Sacramento Rookie All-Star
_
  #48   Spotlight this post!
Unread 20-05-2007, 12:42
cooker52's Avatar
cooker52 cooker52 is offline
Cookie
AKA: Seth Cook
FRC #4272
cooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant futurecooker52 has a brilliant future
Send a message via AIM to cooker52
Our holes were about 1.5" to 2" in diameter. We never had a problem because of the holes. Plus, we tapered them upward to give traction. It was very helpful.
I will never be able to leave 1501. Trust me, I did and I came back.
“If you worried about falling off the bike, you’d never get on.” Lance Armstrong
Monocoque, what a beautiful thing.
  #49   Spotlight this post!
Unread 26-03-2008, 07:51
Valeriedawson Valeriedawson is offline
Valeriedawson is an unknown quantity at this point
Wink Re: How to lose 6 pounds in 8 hours
Hi Storcky,
Your weight loss goal is very hard, I think to loose 6 pounds in 8 hours is difficult. But you have to work hard.
Anyway I will suggest some advises are really helpful for your weight loss goal.
Take minimum 5-6 meals instead of one big meal.
Drink lots of plenty water on regular basis, because it will increases metabolism rate in our body and try to removing lots of fat contented food items (fast food).
I suggest to take more grains and vegetables are very good for the health. One of the most powerful item to reduce heavy weight is chines green tea, you can take tea at least twice of the day then definitely get good result on losing more weight.
If you have at least 30 minutes time in the morning, you can try to walking on regular basis, because it helps to burns more calories in our body and to practice more time with weightlifting. I hope while following these minimum tips are really good and you will get better improvement on losing weight.
  #50   Spotlight this post!
Unread 26-03-2008, 08:07
GaryVoshol's Avatar
Cogito ergo arbitro
Originally Posted by Valeriedawson View Post
Hi Storcky,
I know it's spam, but it's just so funny.
(since 2004)
  #51   Spotlight this post!
Unread 26-03-2008, 11:14
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
Something like that should never be reported!
Manoel Flores da Cunha
Brazilian Machine
Team # 383
  #52   Spotlight this post!
Unread 26-03-2008, 11:18
Matt C's Avatar
Matt C Matt C is offline
FRC #1468 (J-Birds)
Matt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond reputeMatt C has a reputation beyond repute
Send a message via AIM to Matt C
Hi Storcky,
It's easy to lose that weight in such a short amount of time. But it'll probably cost you an arm and a leg.
  #53   Spotlight this post!
Unread 26-03-2008, 11:23
Mike Harrison's Avatar
Mike Harrison Mike Harrison is offline
Don't Mess with Leila
AKA: The Foof
FRC #0217 (ThunderChickens)
Team Role: Operator
Mike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud ofMike Harrison has much to be proud of
I am soooo buying some for our robot!
  #54   Spotlight this post!
Unread 26-03-2008, 15:58
smurfgirl smurfgirl is offline
Still a New Englander on the inside
AKA: Ellen McIsaac
FRC #5012 (Gryffingear)
smurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond reputesmurfgirl has a reputation beyond repute
Hi Storcky,
And I always joke about putting our robot on a diet...
(Our robot was 10 lbs underweight for the first time ever this year... I guess my advice really did work.)
Ellen McIsaac
Team 1124 ÜberBots 2005-2015
Team 5012 Gryffingear 2015+
  #55   Spotlight this post!
Unread 26-03-2008, 16:46
647techangel's Avatar
647techangel 647techangel is offline
K.I.S.S (Keep It Simple Stupid!!)
AKA: Tech_Angel
FRC #0647 (Cyber Wolf Corps)
Team Role: Driver
647techangel has a spectacular aura about647techangel has a spectacular aura about
our robot was so light we had to add weight to keep it from tipping over. i think we added about 40 pounds
!!!!647 HOOAH!!!!
  #56   Spotlight this post!
Unread 26-03-2008, 16:55
AnthonyN1983's Avatar
AnthonyN1983 AnthonyN1983 is offline
Skunkworks
FRC #1983 (Skunkworks)
Team Role: Scout
AnthonyN1983 can only hope to improve
Send a message via AIM to AnthonyN1983 Send a message via MSN to AnthonyN1983 Send a message via Yahoo to AnthonyN1983
If applicable take off chain drive and switch to transmission. Have two omnidirectional wheels in front and drive in back. =)
(>_<) Anthony Nguyen (>_<)
Skunkworks Team 1983, Scout, Systems Integration Member, Photographer, (Partial) *Mascot*
2008 Microsoft-Seattle: Engineering Inspiration Award Winner, Regional Winner (Accompanied by amazing alliance partners 2046 and 949), Delphi Driving Tomorrow's Technology Winner
2008 Oregon: Entrepreneurship Award and Safety Award Winner and Quarter-Finalist (thanks 492 and 2130)
  #57   Spotlight this post!
Unread 26-03-2008, 17:07
MishraArtificer's Avatar
MishraArtificer MishraArtificer is offline
Winner, Chief Delphi Insanity Award
AKA: Jeremy Marr
FRC #0240 (T.E.M.P.E.S.T.)
MishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of lightMishraArtificer is a glorious beacon of light
It would be even easier to just take off all of the team buttons...but why would you do that?
Madness?
THIS IS F.I.R.S.T!
  #58   Spotlight this post!
Unread 26-03-2008, 17:42
brentmcjunkin's Avatar
brentmcjunkin brentmcjunkin is offline
AKA: Brent McJunkin
FRC #0343 (Metal In Motion)
brentmcjunkin is on a distinguished road
well sand of any paint swiss chesse it and take of any extra stuff hallow out gears to make them lighter
2008 Peachtree Regional Winner 1319 547
2008 Palmetto Finalist 342 393/804
  #59   Spotlight this post!
Unread 27-03-2008, 23:22
arhajder's Avatar
arhajder arhajder is offline
Arkadiusz Hajder
FRC #0640 (Viro)
arhajder will become famous soon enougharhajder will become famous soon enough
Send a message via AIM to arhajder
For wrestling my friend had to lose 10lbs in an hour and a half and amazingly he did it.lol
  #60   Spotlight this post!
Unread 27-03-2008, 23:46
Lions for First's Avatar
Lions for First Lions for First is offline
AKA: Devan
FRC #2365 (Lions Robotics)
Lions for First has a spectacular aura aboutLions for First has a spectacular aura aboutLions for First has a spectacular aura about
Send a message via AIM to Lions for First
This year the robot came in at the supermodel weight of 90lbs it was quite stunning (because this is our rookie year I don’t think we could handle the stress of being 30+ over)
2008 AZ Regional: Highest Rookie Seed
5th seed alliance Cap.
Semi-finalists (thanks 125 and 842)
How to lose that extra weight (Was: Major Help!!) dagger Technical Discussion 16 14-02-2006 00:26
How many hours? Jeff Sharpe General Forum 29 29-01-2003 23:15
15 pounds not easy archiver 2000 0 23-06-2002 23:14
