Go to Post *quick grab the epoxy we can rebuild him, make him stronger than before* - amos229 [more]
Unread 26-03-2008, 16:42
gurellia53's Avatar
gurellia53 gurellia53 is offline
word up
AKA: Andrew G
FRC #1736 (Robot Casserole)
gurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to beholdgurellia53 is a splendid one to behold
drive train wearing out?
We're having some trouble with our drive train and launcher and haven't been able to determine the problem.
We were able to get an entire week of driver training in at the end of the build season, the first time ever for us. We pushed the robot hard (drove almost constantly, swapping batteries every 10 minutes or so then throwing them on the charger; only stopping when the CIMs got too hot) all week and never had a major issue and it was working great. However, at the Wisconsin Regional, we ended up with some major issues.
1) drive train didn't turn as well as it did in practice. We couldn't spin around in circles in high gear like we had been able to.
2) The robot didn't seem as fast sometimes. (posibly related to #1)
3) Sometimes the robot wouldn't move when I moved the joystick.
4) launcher (using 2 CIMs) worked well but couldn't throw it as high or as far as in practice.
We have kitbot 6wd with center wheel lowered. All IFI high traction wheels. Each side is powered by 1 CIM through an AM supershifter and a 1:1 sprocket ratio. The launcher is powered by 2 CIMs through a toughbox and an 11t chained to a 45t sprocket.
We have a list possible problems and solutions, but no one has been able to pinpoint anything specific.
Help is greatly appreciated.
Regards,
Andrew
FRC
Robot Casserole 1736: 2007 - 2008, 2013 - present
Team Neutrino 3928: 2012
Unread 26-03-2008, 16:56
thefro526's Avatar
Mentor for Hire.
AKA: Dustin Benedict
no team (EWCP, MAR, FRC 708)
Re: drive train wearing out?
Hmm, That seems very strange. Over time a motor will gradually wear out but, it should take longer than that. Perhaps greasing your transmissions will help with some of your power loss. Other than that I'm stumped. Possibly changing the motors could be an option if you have the time.
-Dustin Benedict
I have two immediate thoughts.
First, did you do your drive practice on carpet? Robot handling is very dependent on the surface it's on. Many teams find that a robot which turns okay on tile or concrete won't turn at all on carpet.
Second, the general description you give, with separate systems seeming to be affected, points to a common problem. How does your battery wiring look? It sounds like you have a poor connection somewhere in the high current path. Double-check all the contact points: the main breaker, the distribution block, the breaker panels, etc. Feel for hot spots. Look at your battery voltage while you are running the motors.
Unread 26-03-2008, 17:10
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Sounds like Alan has it pegged....carpet makes a big difference in high gear turning ability. Also go thru the electrical supply system completely, the screws that hold the wires into the distribution block and the Maxi Fuse panel need to be TIGHT, and have enough bare wire (correct strip length) to be fully inserted. This bit us at the AZ regional, the robot worked fine at home, but had all kinds of weird problems like you describe, ending with it sitting still on the field during our last elimination match (which we lost, of course). Inspection at the next regional revealed a loose and melted wire at the fuse block, replacing it and tightening all the connections properly resulted in no odd behavior during that regional.
Unread 26-03-2008, 17:18
gurellia53's Avatar
word up
AKA: Andrew G
We plan on trying that.
Yes. We had an entire practice field (a cheaper version of the real thing). During that week, we wore our treads down past the rivets, some had even fallen out. We never replaced the treads at the drive's corners, figuring it wouldn't help our problem.
I forgot to mention that the robot's on its way to Atlanta so we can't do this for a while. Also, our forks used to pick up the ball were always controllable. I'm not the electrical guy, but I think this would rule out many poor connections. Anyhow, Its on the list to check.
Also, The intermittent loss of drive response seemed to only happen when the robot wasn't moving, and it would only last a second or 2.
FRC
Unread 26-03-2008, 17:55
imdunne8 imdunne8 is offline
FRC #1736
imdunne8 has a spectacular aura aboutimdunne8 has a spectacular aura aboutimdunne8 has a spectacular aura about
I think it is important to note a few other things -
First off, the launcher and drive motors are on separate fuse panels (drive motors on 40A maxi block, launcher on 30A). I second that the problem is not an electrical connection problem, though we are going to check to make sure when we get to Atlanta.
Second, about the turning - I would say that we encountered a 75-99% loss of turning ability at the Wisconsin regional. At the practice field, we would give the robot a 100% turn command and it would turn extremely fast. In Wisconsin, we gave it the same command and it would either turn much slower or just give a bit of a jerk, then stop.
Finally, it seemed like the robot would drive better (more like it was at the practice field) when in low gear, but it just runs so slowly that we cannot waste that much time driving around the field.
I am personally leaning toward our CIM motors going bad because our lifter, which is using the Taigene motor, seems to still be functioning perfectly. Has anyone else ever run into CIMs going bad after quite a bit (I would guess at least 15-20 hours) of running their robot?
Unread 26-03-2008, 17:59
Originally Posted by imdunne8 View Post
First off, the launcher and drive motors are on separate fuse panels (drive motors on 40A maxi block, launcher on 30A). I second that the problem is not an electrical connection problem, though we are going to check to make sure when we get to Atlanta.[...]
An electrical problem could be farther up the line. Check the distribution block.
I don't think you can kill a CIM in a mere 15-20 hours. 330 has been running their practice robot for I don't know how long and hasn't killed a CIM yet that I know about. Wheels, yes, motors, no.
One other thing--did you change the code at all?
Unread 26-03-2008, 18:09
JimWright949's Avatar
JimWright949 JimWright949 is online now
The Owen Day of Seattle
AKA: Jim Wright
FRC #4542 (Titanium Talons)
JimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to beholdJimWright949 is a splendid one to behold
One of our joysticks was wearing out and not sending solid(ish, well as solid as these joysticks can) signals. Double check your Joysticks for your drive issues.
-Jim
Unread 26-03-2008, 18:28
gurellia53's Avatar
word up
AKA: Andrew G
-Jim
We're getting a full command sent to our victors (solid LEDs)
FRC
Unread 26-03-2008, 18:34
Kevin Sevcik's Avatar
(Insert witty comment here)
FRC #0057 (The Leopards)
I'm really leaning towards a sneaky electrical problem in the high current path as well. As noted, it's really rather difficult to kill CIMs, especially to kill them as much as you claim to have done. Having a robot act strange under high current draws is pretty darn easy, though. The fact that your other motors are working fine doesn't really change anything, as they don't sound like they're drawing very much current at all.
I'd really, really recommend checking you connections, as it's really the only thing those two systems have in common. I can't imagine your launcher motor was running for the exact same time your drive motors were. I'd bet it was running 25% of the time or less, so it should have deteriorated much more slowly.
If you really can't be bothered to check all the connections first, you can do a quick check with a pair of multimeters. Measure the voltage across your battery and across the V+/V- terminals of your launcher's speed controller while the launcher is loading. I'd recommend doing the drive wheels as well, but you need some way to safely load them while the robot isn't moving. The difference you see is entirely dependent on how much wiring you have and how good your connections are, but I don't think it should be more than 1.5V. Maybe 2V. I'm sure the other experts in this thread with have good suggestions for values, but you're dropping 2 or more volts on the way to your speed controller, you definitely have a problem in the power path.
Unread 26-03-2008, 18:50
MrForbes's Avatar
AKA: Jim
If you really can't be bothered to check all the connections...you probably should not have asked for help????....
Seriously, just because you don't think this is the problem, until you actually check the connections (really check them), you won't know if they are OK or not. You have described symptoms which are commonly caused by poor power distribution connections, so it would be time well spent seeing if that is the cause, even if you have never experienced this situation before--others have, and several folks here zeroed in on this as the most likely culprit.
Unread 26-03-2008, 19:03
Erich & Posse's Avatar
Erich & Posse Erich & Posse is offline
Will Forever!!!!!!!!!!!!!!!
AKA: Safety Dork
FRC #1504 (The Desperate Penguins)
Erich & Posse is an unknown quantity at this point
We had a similar problem, robot would work fine but sometimes it would stop then jerk once in a while. found out that our battery connections were bad. between the AM cables and the actual battery terminals, make sure the bolts are very tight and wrapped in a lot of electrical tape.
I am a strong advocate of the B.I.G. philosophy (Beth is ...)
Erich is amazing
Unread 26-03-2008, 19:36
gurellia53's Avatar
word up
AKA: Andrew G
Sorry if I seemed ignorant of the power distribution. Like I said, I'm not even on the electrical team. It's definitely something we'll look at.
It sounds like its an electrical problem which hopefully wont be too difficult to fix. If I'm understanding this right, a lose connection would increase resistance in series with the motors and dropping the voltage available to them. Also, it might lose contact and cause a momentary loss of power to the motors. Is this correct?
Thanks to everyone who has responded so promptly!
FRC
Unread 26-03-2008, 19:53
MrForbes's Avatar
AKA: Jim
Yes, that's correct. The result is bizarre behavior from the robot.
Unread 26-03-2008, 20:06
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
You can easily kill a CIM in 30 minutes if it gets too hot.
Lot's of practice without proper cooling time will greatly shorten the life of your motors.
But I would agree that it's more than likely a connection problem.
Motors on drive train Zoheb N Motors 3 16-01-2007 12:25
drive train Adama Technical Discussion 30 14-12-2006 20:56
pic: Jester Drive:Mecanum Wheel Drive Train Ken Delaney 357 Technical Discussion 64 29-03-2006 22:16
Drive Train Thunder360 Motors 5 21-03-2003 20:41
Drive Train archiver 2000 1 24-06-2002 00:37
